Barb Wire Unroller
/ Barb Wire Unroller #1
boner58
Member
mountain grove, mo
JD 4020
Thinking of making a barb wire unrolled for a 3 point hitch. Any one have any ideas? Pictures? Was thinking of taking some heavy square pipe and put 4 discs with 4 upright solid round stock.
/ Barb Wire Unroller #2
YouTube is the place to see barb wire tools,, you can get lost for over an hour,,,,
they offer great ideas.
I just suffer with a leather glove,,, :confused2:
/ Barb Wire Unroller #4
I find that if the wire is unrolled horizontally it catches less, and unrolls easier, Just my two cents,
/ Barb Wire Unroller #5
You going to unroll 4 runs at a time? That may result in a mess of tangled wire. I made one that unrolled either 1 spool of barbed wire OR 1 roll of field fence.
I made multiple passes. I was afraid the wires would be a major tangeled mess. When i unroll electrical wire in multiple runs, i ALWAYS get a mess.
/ Barb Wire Unroller #6
Custom fencers around here unroll 3-5 spools at a time off of the back of the post pounder. They set them onto vertical bars welded onto a flat plate. The flat plate keeps the wire roll from spinning and tangling up the wires. Horizontal unrolling is just a pain as there is no friction to keep the roll of wire from spinning freely.
/ Barb Wire Unroller #7
depends on how you make your roller,
I have a electric fence roller that I use I made a mount for it that will slip into a pocket,(section of receiver hitch) basically a 2" sq tube, and has a pipe and a section of all thread, or redi thread rod throught it, the pipe is the axle and the rod is the keeper, I put the reel on the pipe and then run a washer and two nuts on the 5/8 all thread and snug it a bit, for barbed wire I do the same but I have a secondary spool that I put the barbed wire on, and sung it so it will turn but not spin,
one jsut has to be smarter than the spool of barbed wire,
and I do not know how may rolls of wire I unrolled with two stakes in the stake pockets of the pickup box and a tamper bar across the bed of the pickup, putting a ply wood or a steel disk on the bar helps as the spool does not slide up against the bed and get caught.
/ Barb Wire Unroller #9
I built one for my 4 wheeler but something like it could be fashioned for 3 pt. Only 1 roll at a time though
/ Barb Wire Unroller #10
I just use a tanker bar on the quick hitch. Simple and I also have a couple of disks from my disk harrow to go on the outside of the wire to keep the roll in place. Usually can keep 2 rolls on so I don't have to change out empty rolls as often.
/ Barb Wire Unroller #11
I built one really simple. The video only had 4 arms on it and I added 2 more. I unrolled 6 wires at a time. Since this video, I got rid of the boards and I welded a pipe cap onto each upright that the spools would sit on. I unrolled a total of 14 rolls in a weekend with a helper attaching the clips.
I used the small tractor and it goes really slow. As it unrolled the wires, I used small zip ties and tied up each stand about every 3-4 T posts. This kept them from tangling up. Once I was at then end, I would cut one wire at a time and stretch and tie off. Then repeat with the next one.
Ellis Band Metal Saw (A62679)
Ellis Band Metal...
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
East Texas Gooseneck Trailer (A65563)
East Texas...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2009 Toyota Camry Hybrid Sedan (A61574)
2009 Toyota Camry...
