Carrying Firewood with Compact Tractor
/ Carrying Firewood with Compact Tractor #1
ALauer
Member
Callaway County, Missouri
Ford TW10, 1973 Ford 4000, Ford TW25 II, 1999 Massey Ferguson 4253, 1973 Ford 4600SU, John Deere 7775, 1985 Ford 555B, 2016 Massey Ferguson 2680HD
So, I own a Ford 1520 with a 3pt hitch and a loader. I work by myself on firewood and most projects. The firewood I get is a 2 mile drive through my field by tractor. I have a John Deere Gator but, I need the loader on the tractor to lift trees and move them around and I'm not sure the Gator will make it cross the creek that I need to cross to get to the area that I cut. I have been putting the wood in my bucket on the loader and I can only fit like 20 pieces of wood in the bucket. I need something to put on the 3pt but I'm not sure what to do. I can get a scrap box blade or metal to use. I'm a mechanic and welder so I am more than capable of making something. Just need ideas. No, I can't just pull my trailer back there because I don't know that I can make some of the turns that I need to. Thanks for your help guys!
/ Carrying Firewood with Compact Tractor #2
There are several 3pth carriers designs in the project section that several on here have built. They look like they carry pretty well.
/ Carrying Firewood with Compact Tractor #3
I use a carryall on the back, and fill the bucket too. It balances out pretty well that way. Sometimes I use a small trailer like this, 19 lb. Capacity 4-1/2 in x 48 in Utility Trailer that I built up sides on to haul behind my mowers, BCS, and my tractor. I originally used the trailer on the road, but stripped off the lights long ago so I could use it around the property without worrying about breaking the lights. I even replaced the tongue last year, with a longer length of 2" i.d. tube all the way to the back. Now I can add a hitch on the rear and tow another trailer or the splitter behind it.
I was thinking about possibly doing a pallet fork style carry-all, making a steel pallet with high steel sides that I could then just use to drop and off the wood at the pile and stacking later. I could at a later time make a second pallet just like the original so I could drop the first pallet off and then grab another and do more without doing as much stacking. Right now, I take the bucket and just drop the wood in a big pile by the stack and usually don't get to stacking it for like a month. Not the most efficient.
/ Carrying Firewood with Compact Tractor #5
I'd maybe reconsider building the thing out of steel due to the added weight if not the cost. You could likely build several out of wood for what one would cost made out of steel and it would be lighter allowing you to carry more payload. Maybe two, three or more wooden pallet type of affairs with high sides. Load em up, then just drop them in your wood shed, then just pick them up when it's time to haul it to the house. I don't know about you but I get tired of loading and restacking the stuff.
/ Carrying Firewood with Compact Tractor #6
The King Kutter and County Line Carry All are both reasonable, and is what I am considering as a base for my 3-pt tool rack project. Not sure where you are in Calloway County, but it appears Orscheln carries KK and TSC carries CL.
I agree the weight may be significant. Seeing as in the winter months it will get tons of weight put on it weekly, I would be willing to sacrifice weight for support. I have no interest replacing these a few times a year. I possibly could just reinforce the wood with metal. How does that sound?
/ Carrying Firewood with Compact Tractor #9
I made a rack with 1/8 x 1-1/4 steel angle iron 6' wide by 4' high by a couple feet deep. I put wheels on it so I could push it around after filling.
I put the forks under it and drive to the wood pile with split wood and load it up and away I go.
It is only a quarter mile so something like this may not work because of the visibility problem and going through a woods. The next thing for me would be a carryall big enough to carry 1/2 a full cord.
/ Carrying Firewood with Compact Tractor #10
Why not pull a trailer and drop it before the going gets tough. Then load the trailer moving wood a lot less than 2 miles and pull it back. Or build a bracket to tow the Gator and you'd have them both in the woods and use the gator to haul it out.
/ Carrying Firewood with Compact Tractor #11
You could used a link box, it goes on the three point linkage and is designed to carry things like wood, they are made by NC and Nugent, it's basically a loader for the back
/ Carrying Firewood with Compact Tractor #12
Sounds good to me. Maybe string a couple of cables, aircraft cabling, across the tops of the sides to support the side loading on the sides. Maybe simple pallet like bottom that you could likely scrooge to get things off to a good start. some common 2X4s to make the sides and some plywood here and there and you're done. Pallet forks front and rear and all of a sudden you're hauling a whole lotta wood per trip and your stacking time is likely at least cut in half. Stack once into the pallet and again at the house.
/ Carrying Firewood with Compact Tractor #13
I picked up a carryall at tractor supply, bolted a floor on it and used it for wood. It worked well. - Same carry all with some sides and front. I have a hydraulic cylinder up top and it can dump. I had to drop the 3 pt pins down to the corner so that I could lift it high enough to dump for a good angle. I use it now mostly for irrigation water in a barrel in the summer.
/ Carrying Firewood with Compact Tractor #14
Years back, I was growing pumpkins in a field about 1/4 mile from the house. I used an Agrifab 4 wheel steerable trailer behind the tractor along with the bucket to transport the harvested pumpkins home. The small trailer allowed me to keep my access roads in the field narrow, which made harvesting much more convenient.
It so happens I also had a 2 wheel dump version of the trailer, also by Agrifab. Sitting there looking at the trailers one day, I noticed that the 4 wheel trailer had a cut-out in the rear axle bracket about the width of a drawbar. I pulled up the 2 wheel trailer behind the 4 wheel, and the drawbar and hitch slid perfectly into the slot, and a single standard small hitch pin dropped in to connect the additional trailer to the lead trailer.
This began my practice of me harvesting pumpkins with my JD2210 and a string of Agrifab trailers dutifully following me around, much to the hilarity of the "real" farmers unloading at the grain elevator I passed each trip. Since we heated with wood, I also adapted the string to harvesting fire wood, and it worked great. Like you, I needed the end-loader at the site, but it wouldn't carry much wood by itself, so I would just drive there with the trailer string, load them with the loader, and then hook the string back up and tow them home.
I just looked at Agrifab's current offerings, and I don't see the same 4 wheel steerable trailer still offered, although the 2 wheel dumps look the same. I gotta think that some Chinese knock-off manufacturer is still producing that successful design with the cut out in the rear axle bracket that makes the whole thing possible.
I still have one 4 wheel trailer and one 2 wheel trailer. I could string them together and take pics if there is interest.
EDIT: Hey, I just found a couple of old pics from when I started using the cart train. Here are pics of 2 carts behind my JD212:
/ Carrying Firewood with Compact Tractor #16
I use the 3pt scoop bucket .
They come in handy for other material moving tasks as well, they hold a fair amount of cut fire wood, and are not expensive. The load stays on in rough going, but also dumps with a pull of the latch string.
A full front bucket, and a full rear scoop bucket is a fair amount of wood depending on cut length.
I pull a small trailer hooked to the scoop bucket when it makes sense.
/ Carrying Firewood with Compact Tractor #17
I built this box several years ago. Used a QH on the 3pt so I could pick it up/set it down easily. It survived my shop fire and I now use it on my JD.
/ Carrying Firewood with Compact Tractor #18
I use 3PH pallet forks and pallets salvaged from rock suppliers...they have wire cages already fastened to the pallets.
Most of the rock places around here just burn the pallets and are glad to get rid of them...for storage I just throw a lid over a loaded pallet...I've found that tarps just attract ants etc...
/ Carrying Firewood with Compact Tractor #19
I have a carryall and a trailer that can haul 3000 lb. I can get 1/4 cord on the carryall and over a half cord in the trailer. In the woods I can make tighter turns with the trailer than I can with the carryall because the trailer follows well. If it was me with a 2 mile trip and a brook crossing I would go with a trailer if at all possible. But that is just me.
gg
/ Carrying Firewood with Compact Tractor #20
Buy this and weld on an extension so that you get the dumping capability of the dirt scoop. Just make it a little bigger.
3pt Reversible Dirt Scoop 3"
2025 BrushFox XHD-78HF 78in Hydraulic Rotary Brush Cutter Skid Steer Attachment (A61567)
2025 BrushFox...
832765 (A61166)
832765 (A61166)
2012 DOOSAN G25KW GENERATOR (A60736)
2012 DOOSAN G25KW...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
2025 Swict 78in. Bucket Skid Steer Attachment (A61567)
2025 Swict 78in...
2020 John Deere 333G High Flow Compact Track Loader Skid Steer (A61567)
2020 John Deere...
