Snow Equipment Owning/Operating Cutting / Groving / Siping R-4 for snow
/ Cutting / Groving / Siping R-4 for snow #541
I finally replaced the original 29 year old Bridgestone turfs on my Kubota B9200 recently with these Firestone turfs. The local dealer had them as new old stock and let me have them for $100 ea. (13.6-16 size) My only concern is that the tread pitch is much coarser than the old tires. May "get" to run them in snow this week but wondering if they need to be grooved to get more bite.
Edit: The old Bridgestones had excellent traction in snow and ice.
I imagine those large voids would not pack with snow well.
/ Cutting / Groving / Siping R-4 for snow #542
They look more like R4 industrial tread than turf. Maybe I should just consider them industrial tread.
/ Cutting / Groving / Siping R-4 for snow #543
I would be inclined to groove them with a 1/4 inch pattern like this:
/ Cutting / Groving / Siping R-4 for snow #544
Thanks for your feedback illustration. I wasn't sure about what kind of groove configuration to use. That looks very simple to do.
Anyone have a used grooving tool and willing to sell it?
/ Cutting / Groving / Siping R-4 for snow #545
They don't cost that much and the fewer heads you get the cheaper they are. I got a kit with three width options but you could probably get away with just the 1/4" or #4 head. Probably something like 70 bucks. Just search for "Ideal Tire Grooving Iron" on the web and you'll get lots of hits including eBay and Amazon.
/ Cutting / Groving / Siping R-4 for snow #546
For those who grooved their tires years ago, and still have the same tractor, do you still have those tires, and if so, how are they holding out? Browsing tire grooving irons now.
/ Cutting / Groving / Siping R-4 for snow #547
Yes, perfect! I would do it again if I got new tires.
/ Cutting / Groving / Siping R-4 for snow #548
My grooved R4's wore down as usually and had zero tears, ripped lugs or anything negative.
/ Cutting / Groving / Siping R-4 for snow #549
Just did my tires too. It was pretty easy. If anyone need to use the tool, contact me, I'm sure we can work something out.
/ Cutting / Groving / Siping R-4 for snow #550
I guess it is time to revive this thread. Nice job Drewmon.
/ Cutting / Groving / Siping R-4 for snow #551
Grooved mine and very happy I did. No issues or extra wear. I.D have to look back and see how many hours I had on the machine and what I’ve put on since. However, the wear (or lack thereof) is if anything minimal. The gain in traction well worth it in asphalt.... (odd part, I think i have a few lugs I didn’t do originally. Maybe I’ll knock that out today).
Checking in after 7 years! Wow, I can't believe it's been that long since I started this thread.
I sold the Kioti LB1914 from Post 1. But it didn't go far. It's now with my cousin with the same tires and there have been no issues with unusual tire wear. I grooved the Kioti DS4510 three years ago and no issues with that one either.
I never had a traction issue with either one after grooving the tires & and have never once regretted grooving them.
/ Cutting / Groving / Siping R-4 for snow #553
This is the second winter on mine and I haven't had any chunking or splits. I'm very satisfied with the results.
/ Cutting / Groving / Siping R-4 for snow #554
What tool was used to make the grooves, depth gauge or stop of some type?
/ Cutting / Groving / Siping R-4 for snow #555
/ Cutting / Groving / Siping R-4 for snow #556
IMHO, this is one of the "best ever" TBN threads. I hadn't even heard of anyone siping R4's and certainly hadn't thought of doing it before I saw this thread. On my list of "some day" projects.
/ Cutting / Groving / Siping R-4 for snow #558
/ Cutting / Groving / Siping R-4 for snow #559
That is the tool I used to groove mine, it works slick.
I have a PORTER-CABLE PCE605K 3-Amp Corded Oscillating Multi-Tool. I think I may try it on one of my lug's tomorrow. It is a great tool for cutting trim and removing grout. It has a built in depth gauge also.
/ Cutting / Groving / Siping R-4 for snow #560
Built in depth gauge should be nice. Please report your results.
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2007 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2007 JLG 600S...
Kubota KX057-4 Excavator (A61166)
Kubota KX057-4...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
