Back Dragging with a FEL Bucket
   / Back Dragging with a FEL Bucket #21
Yep size of rollback gussets and horizontal reinforcement are two additional considerations depending on intended use.
   / Back Dragging with a FEL Bucket #23
Guess I'll fart around doing a 3D CAD model at Lunch, I'll Post it when I get something drawn up for comments.
   / Back Dragging with a FEL Bucket #24
   / Back Dragging with a FEL Bucket #25
Re: Back Dragging with a FEL Bucket, I change my Plow bots on Cutting edge,
The old plow bolt heads were so worn out one pulled through.
The Local dealer sold by stepson 1/4" too short grade 2 junk steel carriage bolts to replace them. They were returned, and I ordered some Grade 8 Blow bolts from Global. Plow Bolts - GlobalIndustrial.com
Note the 2 x 2 x 1/2 L angle at rear of bucket for back dragging.
I love the ESCO teeth, much better than CAT teeth.
   / Back Dragging with a FEL Bucket #26
Mike 69440 -- My application is very different, kind of the inverse of the toothed bar that you show in the picture. Mine was intended for improving the "grapple bucket" nature of my 4-in-1 bucket. Keeps me from slipping losing, or dropping logs, small trees, limbs, etc. I had teeth welded on a bar that bolts onto the 4-in-1 bucket -- very, very similar to yours, your's just lacks the clamshell to comedown over top of it. All that makes me realize -- I can use my "teeth on 4-in-1 bucket" to back drag as well. Here are a couple of pictures.20160526_161407small.jpg 20160526_161445small.jpg
   / Back Dragging with a FEL Bucket #27
Mike 69440 -- My application is very different, kind of the inverse of the toothed bar that you show in the picture. Mine was intended for improving the "grapple bucket" nature of my 4-in-1 bucket. Keeps me from slipping losing, or dropping logs, small trees, limbs, etc. I had teeth welded on a bar that bolts onto the 4-in-1 bucket -- very, very similar to yours, your's just lacks the clamshell to comedown over top of it. All that makes me realize -- I can use my "teeth on 4-in-1 bucket" to back drag as well. Here are a couple of pictures.View attachment 490581 View attachment 490582
That is so cool, makes me want to sell my grapple and get a 4 in 1. You should have patented the idea. Too late now.
   / Back Dragging with a FEL Bucket #28
I have a SSQA plate with attachment points for 3 ph and 2" reese hitch built on the front of it. I bought it to use boxblade on the front of a skid steer but now have it attached to a 72" snow plow. Not sure where I bought it but was around the $100 price range.
I also have a front mount backhoe on my B2650 with 25 hours and two new fel cylinder arms that replaced the bent ones.:confused3:
I have been a back dragger with bucket edge at every angle on all dirt/clay surfaces but will be more attentive in the future. Glad my replacement cylinder arms were under warranty.:thumbsup:
PS The front mount backhoe is now for sale for $1500 in like new condition and my front bucket mount Landpride HD25 post hole digger is on order with Barlows in Somerset, Ky.
learned a big lesson reading these posts---i will be more attentive in the future also with my L3130 GST & 724 loader
   / Back Dragging with a FEL Bucket #29
" Quote Originally Posted by JOHNTHOMAS View Post
PS The front mount backhoe is now for sale for $1500 in like new condition and my front bucket mount Landpride HD25 post hole digger is on order with Barlows in Somerset, Ky."
A front mounted back hoe on a skid steer is a sketchy idea. On a tractor, just get that idea out of your head.
   / Back Dragging with a FEL Bucket #30
I know this is off-topic, but....
A lot of these were sold for skidsteers, tho I do not think most got used a lot. Most required
that you get off the SS seat and move to the hoe seat. Not easy in-and-out of a SS.
I have seen the ones you can operate from your SS seat (Caterpillar), and they are much
better.
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
2007 FREIGHTLINER COLUMBIA SLEEPER (A51222)
2007 FREIGHTLINER...
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
