Back Dragging with a FEL Bucket
   / Back Dragging with a FEL Bucket #21
Yep size of rollback gussets and horizontal reinforcement are two additional considerations depending on intended use.
   / Back Dragging with a FEL Bucket #23
Guess I'll fart around doing a 3D CAD model at Lunch, I'll Post it when I get something drawn up for comments.
   / Back Dragging with a FEL Bucket #24
   / Back Dragging with a FEL Bucket #25
Re: Back Dragging with a FEL Bucket, I change my Plow bots on Cutting edge,
The old plow bolt heads were so worn out one pulled through.
The Local dealer sold by stepson 1/4" too short grade 2 junk steel carriage bolts to replace them. They were returned, and I ordered some Grade 8 Blow bolts from Global. Plow Bolts - GlobalIndustrial.com
Note the 2 x 2 x 1/2 L angle at rear of bucket for back dragging.
I love the ESCO teeth, much better than CAT teeth.
   / Back Dragging with a FEL Bucket #26
Mike 69440 -- My application is very different, kind of the inverse of the toothed bar that you show in the picture. Mine was intended for improving the "grapple bucket" nature of my 4-in-1 bucket. Keeps me from slipping losing, or dropping logs, small trees, limbs, etc. I had teeth welded on a bar that bolts onto the 4-in-1 bucket -- very, very similar to yours, your's just lacks the clamshell to comedown over top of it. All that makes me realize -- I can use my "teeth on 4-in-1 bucket" to back drag as well. Here are a couple of pictures.20160526_161407small.jpg 20160526_161445small.jpg
   / Back Dragging with a FEL Bucket #27
Mike 69440 -- My application is very different, kind of the inverse of the toothed bar that you show in the picture. Mine was intended for improving the "grapple bucket" nature of my 4-in-1 bucket. Keeps me from slipping losing, or dropping logs, small trees, limbs, etc. I had teeth welded on a bar that bolts onto the 4-in-1 bucket -- very, very similar to yours, your's just lacks the clamshell to comedown over top of it. All that makes me realize -- I can use my "teeth on 4-in-1 bucket" to back drag as well. Here are a couple of pictures.View attachment 490581 View attachment 490582
That is so cool, makes me want to sell my grapple and get a 4 in 1. You should have patented the idea. Too late now.
   / Back Dragging with a FEL Bucket #28
I have a SSQA plate with attachment points for 3 ph and 2" reese hitch built on the front of it. I bought it to use boxblade on the front of a skid steer but now have it attached to a 72" snow plow. Not sure where I bought it but was around the $100 price range.
I also have a front mount backhoe on my B2650 with 25 hours and two new fel cylinder arms that replaced the bent ones.:confused3:
I have been a back dragger with bucket edge at every angle on all dirt/clay surfaces but will be more attentive in the future. Glad my replacement cylinder arms were under warranty.:thumbsup:
PS The front mount backhoe is now for sale for $1500 in like new condition and my front bucket mount Landpride HD25 post hole digger is on order with Barlows in Somerset, Ky.
learned a big lesson reading these posts---i will be more attentive in the future also with my L3130 GST & 724 loader
   / Back Dragging with a FEL Bucket #29
" Quote Originally Posted by JOHNTHOMAS View Post
PS The front mount backhoe is now for sale for $1500 in like new condition and my front bucket mount Landpride HD25 post hole digger is on order with Barlows in Somerset, Ky."
A front mounted back hoe on a skid steer is a sketchy idea. On a tractor, just get that idea out of your head.
   / Back Dragging with a FEL Bucket #30
I know this is off-topic, but....
A lot of these were sold for skidsteers, tho I do not think most got used a lot. Most required
that you get off the SS seat and move to the hoe seat. Not easy in-and-out of a SS.
I have seen the ones you can operate from your SS seat (Caterpillar), and they are much
better.
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2009 International Frazer Bilt X-514 Ambulance (A49461)
2009 International...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
HEADACHE RACK (A50854)
