JD 3005 exhaust mods/replacement
/ JD 3005 exhaust mods/replacement #81
That is sooooo cool!!!!!!
I built horizontal exhaust for my Ford. Painted it satin black using Van Sickle exhaust paint in a spray can. Man that stuff is good paint!!!!!!
/ JD 3005 exhaust mods/replacement #82
Here's a pic. I cheated and used the stock vertical muffler. Just showing the paint in this pic.
/ JD 3005 exhaust mods/replacement #83
Have you had any troubles with the muffler getting hit by those phantom flying sticks with this setup Richard? I hate the position of the L3600 exaust.
/ JD 3005 exhaust mods/replacement #84
Not so far. I'd rather not talk about it. Soon as I do I'll yank it clean off...... :)
I kinda worried about heat but don't feel any. I did it because I'm in the timber a lot and knew I couldn't deal with it being vertical there.
/ JD 3005 exhaust mods/replacement #85
Very nice work Greg, want to come build us some exhausts?
Looking at the assembly/dissassembly logistics, Im going to have to have another slip joint in the mix somewhere. The amount of travel needed to remove the exit pipe from the muffler is more than the roll cage and limb riser pipe can deal with... And my original thoughts on mounting that pipe to the limb riser dont excite me much, gotta find something better.
Preliminary fit of exhaust exit to limb riser pipe. Too close to grill, need to tweak the angle a little bit.
/ JD 3005 exhaust mods/replacement #88
Looks like your putting a lot of thought into your exhaust system Greg.
I now have some ideas on the mounting brackets/clamps I need on the limb risers, and took a few minutes to adjust the muffler exit pipe elbow. It clears the lower corner of the grill better now, and should still clear the front tire at full right turn and full articulation.
Got a few hours in this morning. Everything finished, brackets made, and ran it... Way to loud. Sounds like a ricer car with fart can muffler. Not happy with the sound. Not sure how to deal with that... Will have to open up the muffler and modify the baffles drastically.
However... A few pictures of brackets
More pictures later... Getting some lunch, then gotta clean horse stalls.
/ JD 3005 exhaust mods/replacement #91
Man, that would be my luck in regards to the muffler. Sorry it happened to you.
Anxious to "hear" (pun intended) your solution Greg!!!! :D
/ JD 3005 exhaust mods/replacement #92
I find mine away louder since I ran it out the back looking forward to see how you deal with it being so loud.
I used the tractor while cleaning horse stalls today, its not obnoxiously loud so much as it has that 'Brrrraaaaaapppp' of an '80's 4cyl Ranger with a glasspack... Yuck.
I took it all off, and put the stock stuff back on for now. I think I can split the case of the muffler I built, modify the baffles, and weld it back together with minimal issues.
After the muffler is modified, I will get it painted and put it back on and just live with it.
/ JD 3005 exhaust mods/replacement #94
Going back to my glasspack days.
Usually the louvers are all sloped the same direction. If you put the muffler on with them pointing toward the inlet like this \ they were fairly quiet. If you turned them around so the louvers were pointing away from the inlet like this / they were very noisy. Maybe your louvers aren't catching enough air???
/ JD 3005 exhaust mods/replacement #96
So this may be obvious to everyone but me but, why wouldn't you just add the extension pipe onto your factory muffler?
I could, and still might, just tie the stock muffler into the new pipe. The thought process was increase size of pipe and remove restrictive muffler. Let it breath easier.
/ JD 3005 exhaust mods/replacement #98
Is it a good idea to clamp that exhaust pipe tight to the ROPS? When things bounce around, will it hurt the exhaust manifold or other things? Does it have to flex?
See post #43.
I think it will be fine.
Got the top bracket painted yesterday.
Started grinding welds on the muffler, to get it opened up. Buddy at work said the muffler should be at the end of the long pipe, as sound echos inside long straight pipe sections, making the aweful sound more prominent. Larger pipe helps deepen the sound also, so Ihave some food for thought as this saga continues.
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2014 BIG TEX 40+5 GOOSENECK (A60736)
2014 BIG TEX 40+5...
Sdlanch SDLE20 (A60463)
Sdlanch SDLE20...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
MMS 750 Remote Control Lawn Mower (A60463)
MMS 750 Remote...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
