The MV is harder than its seat, so replacement isn't usually required. BUT they sometimes go flat, only you can see.
The measurement on that rod is CRITICAL.. AND there are very small parts under spring pressure that need special attention.
The rod normally has to come apart and the seat flattened w/ a steady hand on a grinder & some sand paper.
I hold it on the side of the wheel on a bench grinder, turning it 180* and finish the process w/ sandpaper on a flat stone.
THIS PROCESS is very tricky, as the seat will fly out of your fingers, never to be found again..
SO, you better just stick w/ the sandpaper for now..
