Accessory plug on Kubota L3200 dash
   / Accessory plug on Kubota L3200 dash #1
Garandman
Elite Member
Mount Sunapee NH / Dorchester, MA
Kubota L3200 HST
I don't have the service manual yet to see what runs where, but I would like to mount a 12V plug somewhere on or near the dash of my L3200. Presumably I can tap something in the fuse box rather than run a wire all the way back from the battery. I want to be able to plug in my Gerbing heated jacket.
Anyone do this?
   / Accessory plug on Kubota L3200 dash #2
I wired in my ROPS lights to a switch on my L3200 dash. Just drilled a hole & tapped into the aux circuit. The furs box is just behind the key or thereabouts.
There is an aux plug under the left rear fender if you look. I used that plug with some basic spade connectors & no switch until I got my dash switch in
I use the rear fender plug for an LED light bar.
Have a picture of where you located yours?
   / Accessory plug on Kubota L3200 dash #4
I just sold my L3200... but if you look under the left rear fender near the tail light assembly it should be there. The new L4060 HSTC I'm getting in a week has the same plug inside the cab ontop of the fender coming out of the pillar going up to the roof.
I'm already using the one in the fender, want best connection for dash setup.
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2019 FORD F-350 SUPER DUTY SERVICE TRUCK (A58214)
2019 FORD F-350...
2013 Ford F-550 4x4 Auto Crane 4004EH 4,000lb. 2 Ton Crane Service Truck (A55973)
2013 Ford F-550...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
10in Digging Tooth Bucket Excavator Attachment (A55973)
10in Digging Tooth...
