Alternative "sub-compact" tractor solutions
/ Alternative "sub-compact" tractor solutions
That is sooo cool! Does that use special attachments?
Here is one of my favorite attachments for this class of tractor.
It's a 4-in-1 bucket... or in ol' skool language, a clamshell bucket... with a few extra features ;)
The Agilator - The Ultimate 4-in-1 bucket with Antonio Carraro TTR 4400 HST II Tractor - YouTube
The reversible operation of an "Alpine tractor" such as the AC I've been posting about, is the only practical tractor for one of these. With the bucket positioned at the opposite end of the engine compartment and low to the ground, it lends itself to better balance and FAR better visibility. Need to transport a bucket of mulch? No problem... simply take the 20 or so seconds it takes to reverse the operator's station, and travel on. The ability to angle the bucket has HUGE merits in my applications, as nearly all but 3 acres of my 26 acre lot is sloped.
/ Alternative "sub-compact" tractor solutions #82
So, there's what? Three kinds of setups..
1. Two wheel drive.
2. Mechanical front wheel assist or MFWA or MFWD or also FWA for Front Wheel Assist
3. Four wheel drive.
Two wheel drive is just that. Only the back wheels are driving.
MFWA or MFWD or FWA is the big back tires and smaller front tires, all of which can provide traction.
Four wheel drive is all four wheels the same size and all can provide traction.
Looking at some distinct advantages to the same size tires all the way around... one, on an articulated machine its kind of necessary, isn't it? So that's not an advantage, but a requirement. Second, it allows you to go the same speeds in either forward or reverse. Full speed in either direction. I use this often on my Power Trac. If you had a reversible operators station, that would be a big plus. Third, from everything I've read, 4wd tractors deliver more traction to the ground than MFWA. Look at the large farm tractors of today. They have the same size tires front and rear. Many are switching from duals to super singles and they are talking about lowering the sidewalls. So, big rims, short sidewalls, wider widths = better traction with less ground compaction. Fourth, MFWA is not true four wheel drive. It can't be because the fronts have to turn at a different speed than the rears due to the different diameters. So there's some slip and slide in there somewhere to allow for that and turning.
Another thing is this... on many MFWA tractors, the front wheels are usually overdriven. That is, they are turning just slightly faster than the rear wheels. So, the front tires wear out faster and it causes additional wear on the front drive train. And also from what I've read, if you don't engage the fronts on a MFWD, you lose about 10% efficiency due to various reasons, such as now you're pushing the tires and front drive gear, etc... In other words, 4WD is more efficient than MFWA.
4WD causes less soil compaction that MFWA. The 4WD tractors distribute their weight much better than MFWA machines.
I'm thinking for what you've said you want to do and how you want to do it, a 4WD articulated machine with equal sized tires all the way around is gonna work out best for you. If you can get one with the reversing operator's station, all the better. As mentioned, I don't see the need for the reversing station with what I do, but your needs may be different.
/ Alternative "sub-compact" tractor solutions #84
Re: Alternative "sub-compact" tractor solutions
LD1, Not to get you fired up right before Thanksgiving my friend, but a 29/12.5 is a lot more tire than a 24/8.5. Half again as wide, and 20% taller. I do find it interesting that the AC uses just 4 small lugs per rim. It's probably adequate, but looks a little light duty at first glance.
And a skid-steer that runs a 10-16.5 or a 12-16.5 would normally weigh double what this rig weighs. With a 29/12.5 and turfs I'd think this would have a pretty light footprint. It's the narrow tires up front on a tractor that seem to tear up turf first. Now I'm not convinced that this thing will be a stump puller with the turfs by any means, but it ought to work for the application.
MultiMow, my only suggestion is to make sure you spec out your attachments before you purchase the tractor to make sure you have adequate hydraulic flow and lift capacities. Some of the cooler hydraulically driven implements require a lot of flow.
I think this thread is about ideas, alternatives, etc. Not winning a debate. So you can both be winners.
Have a great Thanksgiving.
Not trying to win any debate. I enjoy seeing these alternative designs and how people use them. But I am also trying to bring things back to reality.
It gets a bit old constantly hearing "alternative tractor model X" compared to "kubota model Y"........and ranting and raving on and on about how much better the alternative machine is......
Is the AC 1440 hands down a better machine across the board.......NO. But reading this thread would have you believing that.
IS it a nice machine, that is in some ways better than the L3901......Yep. Is it better suited for some jobs than the L3901......Yep.
But you could also say that the L3901 is a nice machine, that is in some ways better than the AC, and is better suited for some jobs than the AC. Thats the side I am bringing to the table in this thread that it appears no body wants to hear.
When a comment is made that the AC has 4 equal sized tires and that means more traction than the L3901.....that just plain bad (and wrong) information being spread. My comparison to a skid steer was a fair one (again, one that no body wanted to hear and laughed at). The 1440, at ~3000# can be equipped with 4 ag tires that are 6.5-16's. The ratio of tire size to machine weight does indeed rival a skid loader.
Again, I like seeing these unique alternative designs. Some of them are pretty cool. And I have no issues with the love-fest going on and talking about how great they are. But when comparing them to a tractor, weather it be kubota or otherwise.....lets be real here. Provide a FAIR comparison. There are Pro's and Con's in every comparison. Only talking about what makes the AC better than the kubota is not a fair comparison. Its a biased comparison. You want a fair comparison, talk about what makes the AC better....AS WELL AS....where it falls short and the kubota is better. The SAME person can make these comparisons and post them. Rather than one poster raving about how good the AC is, then me bringing things back down to earth listing the "pro's" of the kubota and "cons" of the AC.
/ Alternative "sub-compact" tractor solutions #85
OK - so I just read through this entire thread.
Before I potentially offend the alternative tractor crowd. I want you to understand my position - if a 4 wheel articulated loader with appropriate drive train, loader capability, and SSQA compatibility would have been available for anything close to the price of my 45hp Kioti DS4510HS 2 years ago (~20k), I would have jumped on it. After 8 years with my smaller Kioti, I knew I wanted a half scale version of a New Holland bi-directional.
I am a huge fan of this alternative design because it would suit my purposes far better than a conventional tractor. I am 100% on board!
But back to reality, for the price I paid for the Kioti (~$20K), you can't come close with the alternative designs! The largest Power Trac is the closest to being competitive but it lacks in several areas.
- Price - ~$5000 more expensive , probably $6000+ more after shipping
- No SSQA compatibility - deal breaker
- single gear 0-10mph - not enough pulling power, not enough top speed - deal breaker
- Loader - lower lift height and lower capacity than my tractor (this one shocked me, I expected the design to have much higher capacities), I'm just going by specs, haven't seen one tested. - not a deal breaker but disappointing.
If Power Trac fixed the drivetrain for grunt down low and top speed closer to 20mph, added SSQA option and added a stronger, higher lift loader then the price difference would have been worth it to me.
IMHO, the single easiest thing Power Trac could do to increase the appeal of their machines is change to SSQA. Not having SSQA was a horrible marketing move because it eliminates many potential customers who have a pile of SSQA attachments lying around from even considering a Power Trac
So in concept, I love equal tire size (4 large tires not 4 small tires), articulation, and reversible seating position. It seems it should be possible to manufacture a machine that checks all the boxes that a CUT checks. But so far, none of the available options have executed in a way to that is compelling to most CUT owners.
I hope that my next tractor is a bidirectional articulated unit. However, except for the New Holland bi-directional which is a bit larger than I'd need, the available alternatives have failed to "check all the boxes" IMHO
/ Alternative "sub-compact" tractor solutions #86
1. Two wheel drive.
Sorry Moss. I just can't leave this one alone. For the sake of other readers, I want to point out the information above that could be misleading to uninformed readers.
- 4 equal size wheels / tires is not necessary on an articulated machine. It's easy, but not necessary.
- 4 equal size wheels does not allow you to go the same speed forward and reverse any more than 4 unequal size wheels do. The transmission dictates this, not the size of the wheels / tires. Many traditional tractors go the same speed in forward and reverse or very close to it.
- 4wd tires deliver more traction to the ground than MFWD. Depends on tire size. 4 small tires no (most the time). 4 big tires yes (most the time). Most small articulated units have 4 small to medium tires instead of 2 small 2 large on a traditional tractor. Articulated row crop tractors have 4 large tires, not a good analogy. Plus, there are tons of other factors.
- 4WD causes less soil compaction - depends on tire size and weight distribution. A utility tractor with balloon turfs for mowing golf courses and a mower off the rear and no loader in the front has most it's weight on those giant rear tires and causes very little compaction. It's all how you set it up. 4 small tires will cause more compaction than 2 small and 2 large all else being equal.
A used 4wd utility tractor with low profile wide turfs and forks on the rear (no loader) might tick all the boxes for much less money. (if I recall the OP only needed to lift the 2,000 pound pallets 2 ft off the ground - unless I am mis-remembering). Regarding hills, I've towed 7,000 pounds on 20% grades with a 4,000 pound tractor with MFWD engaged and the same trailer with a 7,000 pound tractor in 2wd. I run 2,000 pounds of tongue weight to keep the rear planted and have R-4 tires.
It does sounds like an articulate unit might be the way to go for the OP. But there are other alternatives for much less money starting with a traditional tractor.
/ Alternative "sub-compact" tractor solutions #87
LD1, new to this conversation so if there is history, I do not know. Can you point ot any evidence on your tire statement? See, I understand the reason tractors tend to have smaller tires on the front is not because of any traction benefit (there would not be any in my estimation) but because of steering. Hard to turn big tires. But I am up for learning something new so if you can provide evidence I am all over it.
One other thing that throws me on your statement, the large (I mean huge) farm tractors are articulated in the center and all tires are the same size. If there was value in smaller front tires I am sure we would see it in this type of application where such heavy mass and drage are being pulled.
Look at a dragster, same principle as a tractor. When you apply power to the ground with the rear tires, it will try & lift the front to some degree. Anything not front wheel drive will pop a wheely with enough power & traction. That means a lot less traction up front unless you make a really long nose on em like a dragster or add weight on the front (loader included) like a lot of tractors.
A tractor is made to pull & pulling is primarly a rear axle traction thing. Thats why turning brakes use to be so important. The front axle never had enough traction to make you turn. Modern tractors put more weight up front as they are front wheel assist so that traction will propell as well as steer (not to mention make a loader work better, hard to drive when the loader pulls traction off the rears on to unpowered fronts).
1. Two wheel drive.
MFWD (or any other acronym for compensating 4wd) has its merits. The old MFWD systems were definitely lacking... but a cost effective solution for light duty applications needing the occasional traction boost, while maintaining the ground clearance of a spindle mount front axle. This is also why larger tractors DON'T use this system... as the larger tractor doesn't require such accommodation to maintain ground clearance, nor is it intended to be so tightly maneuvered and compact in its front axle size.
Some newer MFWD systems utilize what's known as "overrun/underrun engagement" to eliminate the efficiency problem you mentioned. They achieve this by incorporating a one-way drive (usually a sprag) and a slightly underdriven ratio. This allows the steer axle to remain free until the traction losses exceed the take-up of the underdriven ratio (usually about 2-5%). This also provides for better steering and less compaction/damage while turning... as the steer axle can freewheel through its greater distance travelled.
For those with any considerable measure of agricultural duty, it's a fine compromise... even though they may lose some productivity in other operations, the capability/capacity is still there to get the job done.
I agree with you for my intended usage... articulated is the ideal. However, the most important aspect for me is reversible operation. For some odd reason, I also prefer steer axle over articulated... can't really explain why though.
I will admit, I'm a huge fan of PTs. AC has an articulated reversible unit... albeit considerably higher in price. For those in need of an articulated machine of higher capacity than Ventrac/Steiner offerings, but less than those of more agriculture oriented manufacturers... the PowerTrac lineup is a great niche market option. Anyone who disagrees need look no further than the used market. Pick any model from any manufacturer during the same years, and you'll find a MUCH higher percentage of available used equipment. This alone correlates directly to one fact... owners find their PowerTracs to be irreplaceable by any other comparable means. For their many intended purposes, you simply can't find another comparable machine, much less a more capable one, in the confines their price range... ESPECIALLY in North America. The only considerable options to a PT are either larger and FAR more expensive, or comparable in price while sacrificing productivity/capability.
Honestly, I believe this is why PowerTrac is still relevant and maintains its market presence... regardless how small.
Everybody has their own individual preferences with regard to power equipment... and we all try to choose what best checks all the boxes. Honestly, I could go out and buy a cheap $5k 18hp generic import 4wd SCUT capable of 98% of what I do... but productivity and comfort are valuable enough to justify the extra cash for me.
I get it. To most people, the purchase of a SCUT/CUT is mostly capability at price point... not productivity. Regardless, it's a great (and getting better) time to be in the market for equipment. I don't think we've seen the multitude of options/influences in over 15yrs. JD stopped selling their rebadged Goldini's in 2003. Jacobsen stopped importing their rebadged Bucher (mini Aebi mountain tractor) in the 90's, and Aebi's price point has skyrocketed far and beyond SCUT/CUT price range by multiples. Now we're starting to see a return of options that go outside the conventional box... and for once, they're comparable in price (if not outright beating the competition).
I, for one, can't wait to see how things will change if the economy holds out. I think things will be highly favorable to those who are willing to spend the extra $2k or $5k on their tractor for the sake of productivity. Sure, that $5k would go a long way in attachments... but it your time is worth something to you... I think the time saved in the seat will more than pay for itself over the life of the machine, when it come to hours saved in the seat.
Two weeks later and you just couldnt leave it alone could you?
No worries, LD1. I think we're all fairly certain where you stand. You've made some good points... and it's good to have honest comparisons to the status quo, regardless of your disdain for "tractor X vs. Kubota Y".
As for the comparisons, I think it's worth noting that Kubota faithful fans should be proud of their brand's significance... as it's much like the Corvette to the sports car world, in that regardless of like/dislike, everyone views Kubota as the standard for the CUT/SCUT market... and rightly so, given its sales figures and market presence.
/ Alternative "sub-compact" tractor solutions #90
Thread pruned.... please continue the original discussion. Thanks.
/ Alternative "sub-compact" tractor solutions #91
Yes, Kubota have made quite a name for themselves. I am not what one would consider a "brand loyal" person who blindly follows along. I consider all options, from all makes.
If I need to buy a machine, attachment, whatever.....I consider all options, and select the one that "checks" the most boxes, with an important emphasis on priority.
For me it was a tractor. For you and others, it might be an alternative design. And I will say again, I have nothing wrong with alternative designs. I think they are quite cool and unique. Just didn't check enough boxes for the tasks I need done. So don't hate on me, or single me out for not getting something other than a tractor. As I am not singling anyone out for picking an alternative design.
All I am trying to do is bring in a little reality. Like I said, when you make a comparison, and the only thing listed is what makes type A better than type C....it is an unfair and biased comparison. So while you are quick to talk about all the "pros", I'll chime in with the "cons" if applicable, just to keep things level.
I don't care what brands or what type the machines are....apples to oranges comparison always makes for a very biased comparison. Try to keep it apples to apples. And let's try to have a mature discussion about the differences (pros AND cons) that different machines bring to the table. And respect the fact that I chose a tractor based on my needs, and am not trying to push a tractor "design" on anyone, nor do I feel a tractor is an all mighty superior machine at everything it does. And I will understand and respect the fact that a tractor is not the right machine for you. But you have to respect the fact that an alternative design ain't for everyone. And when you come across as thinking all us tractor owners made huge mistakes and should have bought an alternative machine, it sounds like you are being pushy and calling all of us idiots.
/ Alternative "sub-compact" tractor solutions #92
LOL. This thread is pure entertainment. Some great info and comparisons of different drive systems as well.
I for one am really looking forward to seeing what MultiMow ends up building. It certainly sounds like it will be a once of a kind machine with some serious capability. I think I initially underestimated MM's seriousness when he started posting and it's obvious that this is going to be a cool project with no detail going unnoticed. The hydraulic drive system thread is another really interesting aspect of this project.
After reading about these little alternative machines it makes me want one.
I tried to do that... BELIEVE ME, I tried.
The only "pros" I could come up with, when comparing the AC to Kubota's most closely equipped model were:
1- CUSTOMIZATION
Kubota's L-series has a PLETHORA of options. Honestly, I don't think there is another manufacturer out there that offers the same level of customization with regard hydraulic options... however, I will have to say that New Holland has some specialty options that are not listed on their website (I'm still considering their wide track hillsider... which I seen in Alabama a couple months ago). From what the reps told me, everything Kubota has to offer is available on the website configurator, so I configured the closest possible unit to reflect/compare pricing. I was going to give Kubota the honorable mention here for overall configurability in a single model range... but AC has them beat there as well, because they have so many lateral models (same horsepower, same class) with bi-directional AND articulating or steer axle setups.
2- GENERAL AGRICULTURE
For general agricultural use, the Kubota L-series is (for the most part) a hands-down winner when the confines of comparison are operating efficiency, cost of ownership, and serviceability/service locations. For those who require a high lifting FEL, it's also a winner there... a crucial point for many buyers/owners. Don't need all the options? Want 25-45hp and 2wd? Kubota L-series. Need more hydraulic control than an aircraft carrier, an FEL, adjustable track width, class leading ground clearance, 4wd, and a partridge in a pear tree? Kubota L-series.
3- SERVICEABILITY/ SERVICE LOCATIONS
This one is a no-brainer as well. Kubota is huge... and they're EVERYWHERE. If you can't see orange from where you're standing, lean left or right... OH, THERE IT IS!
If you can't fix it with your hammer, you need a bigger hammer.
____________
All this being said, Kubota's L-series has its merits... well earned AND established.
With regard to the debatable tire size v. traction issue... it all has much to do with purpose and application. 4 midsize tires will provide near equal traction to big rears with an unbiased load on flat ground. In rear mount ground engaging applications, or pulling applications, big rears win hands-down. In hillside work, absolute traction will remain about the same... but equal sized tires win out in stability... ESPECIALLY when working with a load, or when you can't limit your working direction to uphill. Big rears may even excel in some hillside instances... but at the expense of soil compaction/damage.
For a farmer? The answer is simple... pick your brand of conventional tractor with ample power and go.
For the guy who just wants to maintain his property on minimum investment? Take your pick from the same.
Want a tractor with the functionality that will make you more effective, more productive, and get your time back to other things (sending time with family/etc.)? Want to spend the same cash as a tricked out orange tractor and gain the flexibility of bidirectional operation AND the POSSIBLE added stability of 4 equal sized tires and 4wd (plus a few other options)? There's only one option... Antonio Carraro.
Want the hillside stability of the AC and then some? Don't require high transit speed or reversible operation... but most of your work is better suited to forward engagement/mounting? PowerTrac.
Similar needs to a PowerTrac, but don't need the power OR the weight? Looking for a lighter footprint? Need front AND rear mount versatility? Ventrac/Steiner.
Need MAXIMUM versatility without tearing your ground all to ****? Skid steer out of the question? Want more attachment options/control than you can shake a stick at? 3ph just won't cut it? Money not a problem? Avant, MultiOne, Bobcat Toolcat... take your pick.
Need the best simple stall loader, various front mount attachments, more maneuverability than your SCUT, and don't use any of it's rear mount aside from towing a cart? Gain some versatility, save some cash, and get yourself a non-telescoping Avant 200 series.
Wanna be the reddest green hippie on block, with electric drive, mechanical PTO capability, MAXIMUM maneuverability, and money isn't a problem? Go get yourself an Aebi EC 170 implement carrier, and stealth farm yourself into the carbon credit saving heaven.
Need the absolute BEST sub-100hp hillsider option with front/rear capability and MAXIMUM traction, and your pockets are deeper than a healthcare provider after ObamaCare? Buy yourself an Aebi or an AC Mach 4... you won't be sorry.
Don't have the cash for an AC Mach 4, but you reeeeaaaaallly want one? Buy a Mach 2, and don't complain about the turf damage.
It's a whole new world in compact tractors... except, it's not. Not a single model provides anything the industry hasn't seen before. As a matter of fact, with regard to mountain/hillside tractors, we're still down a couple options (BUCHER! [mini Aebi] Where are you???!). John Deere has sold both half-track and full crawler compacts before... although their track designs were far less advanced. If you squint, a Ventrac/Steiner is little more than a miniaturized wheel loader that someone shrunk in the dryer too long... and they've been around for years. Reversible tractors like the AC have been around... again, they were JD rebadged Goldini's... and NH had their initial ~60hp models, which have grown to exceed anywhere near SCUT level with their newest 96hp model... but if you look hard enough, you can still find a few of the smaller Versatile brand Ford/NH bi-dis.
These things come in cycles (usually with economic highs), and they don't last long... mostly because major manufacturers are only interested in major sales. The modular design and cheaper/universal manufacturing of the conventional tractor means one model (horsepower class) is capable of serving a whole boat load of customers. With the exception of John Deere's rebadging/importing ventures, and a few off-beat R&D models of Kubota's 80s/90s... you don't see this often.... but the persistence of manufacturers like PowerTrac, Ventrac, Steiner, Goldini, AC, etc., are showing that people are willing to drop the cash for better accommodation to their applications.
In my opinion, Kubota has an opportunity here. Why? JD couldn't sell their rebadged Goldini's, because people don't go to a JD dealer looking for a Goldini. People DO, however, look to Kubota to innovate... come to the market with new solutions..... and they're long overdue for a quirky model that will mimic/exceed the value and flexibility of an AC, or PowerTrac. You show me a 'Team Orange' AC competitor, and I'm "on the wagon".
Serious capability? Eh... depends on your definition. If by "capability" you mean "flexibility"... then you're definitely on-track.
On paper and in my head... it's just a great little light-duty solution for 99% of the applications associated with property maintenance. It'll keep the grass cut, reclaim your brush covered areas, be tractable on steep (40 degree plus) slopes, dig post holes, condition your driveway and your soil, provide better manueverability than an articulated tractor, move bucket loads of mulch or other loose material, tow your loaded garden cart, and carry a light boom mower for those roadside embankments that are always a pain in the *** string trimmer requirement.
It won't log (might pull/tow a few). It won't pull stumps (at least I don't THINK it will). It won't load your truck bed with said mulch. It won't haul standard size round bales. It won't pull a three-row turn plow.
There's a lot of things my machine won't do... but for people like me, it won't matter.
There's a lot of things it will do better than any other reasonable/comparable option out there. For those who's needs for an SCUT are limited to those applications... I'm hoping it's as irreplaceable as a PowerTrac in a greenhouse business, a Ventrac on a tree farm, an Aebi or Breilmahwer on slope mowing, or a Toro/Jacobsen on a golf course or in a municipality.
I didn't design it to everything for everybody... I just designed it to be 99% of everything, to 70% of the SCUT buyer demographic, and to perform the 99% of application time in the seat at a 40% increase in productivity.... leaving the average property owner with with 40% more time to spend throwing a football with the kids in the freshly mowed grass of their front yard... with the same machine that dug the post holes and set the posts, leveled the driveway, handled the landscaping, and saved about 3hrs worth of weedeating on that roadside embankment.
...or get you back inside a warm house 20% earlier after clearing a snow covered driveway.
I'm not calling anyone ignorant for buying a conventional tractor. I'm just looking at the unconventional applications that nearly 70% of SCUT buyers are s0ending their money on
/ Alternative "sub-compact" tractor solutions #95
That's what hooked me on the Power Trac. I don't plow fields and I don't pull stumps. I don't load pickup trucks with loose material from the side. I spread loose material that I bring home from the gravel pit or mulch recycling center. I mow my lawn. I plow my snow. I pickup my leaves in the fall. I brush cut two miles of trails on our remote property. And I pull firewood out of the woods. I used to also maintain 4 ball diamonds at a little league when our kids were young, and the ball diamond at my kids' school and church. I have no reason to purchase a pulling machine. So I started looking at the best option for my needs and budget. And I'm pretty sure I've found it. ;)
/ Alternative "sub-compact" tractor solutions #96
Re: Alternative "sub-compact&a
I think you are on the right track. A Tractor is more like a swiss army knife. Jack of all trades, master of one, pulling. You can gut a deer with a swiss army knife but there are better choices. You can trim a turkey with a swiss army knife but there are better choices. You can cut a steak with a swiss army knife but there are better choices. Etc.....
As we have seen more of these alternative machines (PT, toolcat, etc) show up they have certainly built a following because they offer features that the average tractor doesn't.
I think most of us understand that you are not calling anyone ignorant. Sometimes people just struggle with the concept that others have different needs than they do. As you can see from other threads folks are loyal to thier toys from tractors to pickup trucks so sometimes they get thier feathers ruffled.
Keep us posted with the progress.
Will do! (keep posted)
I really wanted to make this thing a 3cyl diesel... but it doesn't look like that's going to be the case. I could build one, but it would require the use of pump/motor drive setup instead of the intended integrated drive axles.
All the integrated axles I can find are designed for vertical shaft drive. I was told that Eaton has a horizontal unit, but I can't find any info on it.
Oh well... I guess it could be a good thing. A lot of people don't care for diesel... and this application requires more than 24hp, which puts it into Tier 4 Final emissions category ($$$$).
Before so many people took interest, I had resolved to buy an Altoz TRX 660 when they hit the market next year... and use my Toro 455 as a power/traction unit for the heavier work.
I already have a Kubota L2850... but aside from the front remote hydralics and three speed PTO, I hate it. My Toro mower has more power, equal traction, is more maneuverable, more stable, and only has turf tires... not to mention, a front mount mowing deck that doesn't require looking over my shoulder all day to mow my creek banks and fence lines.
To be honest, if I would fab up a 3PH for the Toro to run my post auger and blade... I have everything I need (it has three auxiliary hydraulic lines with individual valves... can you say "light duty six-way blade"? 😁 )
I'm just glad to know I'm not the only one who could use such a machine.
/ Alternative "sub-compact" tractor solutions #98
Before so many people took interest, I had resolved to buy an Altoz TRX 660 when they hit the market next year... ------------------------
Altoz Website: TRX | Altoz
Wow a tracked Zero Turn!
Not me, I don't care for gasoline engines. All of my machines are diesel. :thumbsup:
Agreed... I prefer diesel as well. It's more efficient, and more durable.
As for the tracked zero turn... thanks for adding the pic :)
You should check out their video on YouTube. This thing is a beast... and more capable than even some 4wd light tractors, when it comes to operating in areas that require high flotation.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2017 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2017 Volvo VNL 760...
2010 JCB 3CX 4x4 Loader Backhoe (A60352)
2010 JCB 3CX 4x4...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2025 Spirit Electric Scooter (A61569)
2025 Spirit...
