MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,132
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I know a couple of you have the winch from PT for the 400 series machines. And I know we've had this conversation before, but I'd like to have it again if you don't mind. Thanks.
Looking at their winch, it appears to be just a HUGE motor with a cable drum directly fastened to it. There's two hoses coming off the motor that go to the AUX PTO ports on the FEL arms. So that means in and out are controlled by the knee lever, correct? How can you pull the cable out as there appears to be no free-wheeling capability? It would be easy to put a cross-connector right at the motor ports with a valve that could be opened to allow fluid to bypass the tractor hydraulics to spool the cable out manually. Then close it for power application. But as I recall in a previous conversation, I thought someone said they did that, but it was still very hard to pull the cable out as your are fighting the internal gearing of the motor VS the hydraulic fluid.
Any thoughts, comments, suggestions from the PT group? Thanks. :thumbsup:
