County Water Pressure Too High
/ County Water Pressure Too High
PRV Install Fail : County Water Pressure Too High
Installed a Watts PRV yesterday and **** if the threaded coupler and PRV are both leaking. The coupler is dripping from the O-ring union at the water meter and the PRV is dripping from rubber gasket where the cover attaches, see picture. Both drips are very slow but not something I feel acceptable and is irritating as I even went as far as applying food grade silicon grease on the O-rings to ensure they set properly. Everything is as tight as I can get them without breaking something (maybe to tight?) Should I give it a few days and see if they stop, shut the water off and disassemble and apply a sealant or do one of you have another method that has worked for you.
/ County Water Pressure Too High #62
Re: PRV Install Fail : County Water Pressure Too High
In the case of the O ring make sure you didn't pinch it when you did the reassembly, it's easy to do. As far as the connection to the meter, did you use teflon paste? I see you used tape on the other fittings but I find teflon paste to work much better on pipe fittings.
/ County Water Pressure Too High #63
At the meter that's generally a flat rubber washer no need for tape or paste because the water should never get past the washer. It shouldn't leak even if just snugged up by hand ( dry no silicone ) maybe you were able to squash it to much with the lube on it. If it still leaks after you tighten it a little more just get another washer an be care full it stays centered. As for the PVR gasket I've never taken one apart so can't comment why it leaking.
/ County Water Pressure Too High #64
Who needs a pressure washer with that kind of power at the faucet.
Thanks - I did save the old washer and it is definitely flat, the coupler the local plumbing supply sold me as a match definitely has an o-ring washer. As you can see I had very little room in the existing meter box so I had to get the shortest fittings. I may try the old flat washer in the new coupler and see if that fixes it, I just checked again and the PRV leak seems to have resolved itself.
