Ouch... maybe watch before you purchase a Mahindra.
/ Ouch... maybe watch before you purchase a Mahindra. #81
I thought he was going by the wisdom of the Mahindra service tech that he called and started with that, then went to the shotgun approach, maybe he would of been better off if he went the Red Green way.
So if I were trouble shooting it, I'd make two bypass wires and wire across the two plugs. Does the same thing but is reversible
/ Ouch... maybe watch before you purchase a Mahindra. #82
Bypass first, cut last. :)
/ Ouch... maybe watch before you purchase a Mahindra. #84
How do you by pass a switch. Do you remove the switch and plug a wire into the connectors the switch was plugged into?
/ Ouch... maybe watch before you purchase a Mahindra. #85
You explained it well..
/ Ouch... maybe watch before you purchase a Mahindra. #86
First try using a jumper wire to both sides of the switch without removing it.
/ Ouch... maybe watch before you purchase a Mahindra. #87
/ Ouch... maybe watch before you purchase a Mahindra. #88
I was about to say Stretch should have kept the tractor he had, then I realized we're probably in for many interesting videos as he learns how to keep the new one running. He's not a professional mechanic and doesn't pretend to be. Perhaps a good title for his tractor videos would be "Learning to Fix a Tractor with Stretch". Infact, I can invision an entertaining presentation where he critiques his repair and discusses how he might have incorporated some of the suggestions made in this thread.
/ Ouch... maybe watch before you purchase a Mahindra. #89
He could just be faking these problems in order to have more material for his upcoming book, "Trouble Shooting Reasons Tractors Won't Start, For Dummies".
/ Ouch... maybe watch before you purchase a Mahindra. #90
I Bypassed my seat switch in my L39 Kubota with a toggle switch, so I have option of seat safety switch or operating tractor while standing on operator platform off seat so i can see in front of bucket. My Max 28's Seat Switch, other than securing the wires well, is left OEM.
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 HINO 338 4X2 22FT CDL REQUIRED BOX TRUCK (A59906)
2018 HINO 338 4X2...
LaneShark L53 (A60463)
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
