Checking temp
/ Checking temp #1
jimjumper
Hemet, CA
Yanmar 240D, 8N Ford
I imagine this has been asked multiple times before but I found it a little tough to phrase the question for the search. My Yanmar 240D doesn't have a temp gauge (although I am going to install one) so I purchased a laser temp gauge. Where on the engine does one check for the actual operating temp? I found quite a variety in temp in the upper and lower radiator hoses, upper and lower block, and the sending unit for the idiot light. I've never gotten a reading higher than 180F at any spot but would like to know when I'm using it what is safe.
/ Checking temp #2
Best place is at the thermostat housing , that's the water that is coming from the block and headed back to the radiator.
/ Checking temp #3
You'd want to read at the temp sensor for the idiot light. If you have an ECU this is likely where the ECU gets its temperature data from too.
The temps had better be different for the upper and lower radiator hoses or something is for sure out of whack.
BTW those non contact thermometers aren't very accurate. Many DMMs today come with a contact thermocouple and a temp function on the meter that will give you a much better and more accurate reading.
2014 Honda Accord Sedan (A61574)
2014 Honda Accord...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
More info coming soon (A61574)
More info coming...
Rhino 7ft Blade (A63688)
Rhino 7ft Blade...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
