Compatible backhoes for L2501
/ Compatible backhoes for L2501 #1
soundseeker
Bar Harbor, ME
None
Looking for help again...getting ready to make the purchase on L2501.. gonna go without backhoe at this time and maybe add the attachment in the spring since not needed at this time..looking to find out if there are other backhoe brands that will fit the l2501?. Thanks for any and all help/advice.
/ Compatible backhoes for L2501 #3
Waiting those few months will cost you. The dealer should cut you a better deal if you get the BH as part of the initial purchase. He's going to be putting time into setting up the new tractor, and there is also labor in configuring it for a backhoe. If he has to turn wrenches on your tractor only once, it's a saving for him and you both. You probably can bundle the BH into the purchase financing, if any.
As for what brand of BH, there are good aftermarket models... Woods, Bush Hog, Wallenstein, Bradco, etc. The Kubota BH typically has some advantage because it is not a generic BH adapted to fit your tractor; it's factory-designed to fit your specific model. It will tuck into the back of the tractor better (which affects strength and performance), the subframe will be better integrated to the unit (giving better ground clearance), etc.
/ Compatible backhoes for L2501 #4
Very well stated and covered all the points....don't be surprised if there are price increases between now and next spring.
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
CAT D9G Springs (2) (A68134)
CAT D9G Springs...
2014 HAMM HD+140I DOUBLE DRUM ROLLER (A65056)
2014 HAMM HD+140I...
2005 Freightliner FLD120 Ambulance (A66736)
2005 Freightliner...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2007 REINKE TRAILER Combo Spread Axle Flatbed (A67714)
2007 REINKE...
