Workshop Insulation
/ Workshop Insulation #21
I also "zoned" my lights with one switch for those in the area I usually work and another for the lights (with less density) in the "storage" area. Finally, i have a third switch that controls additional lights over the workbenches to effectively double the light there.
/ Workshop Insulation #22
I built my shop 6 years ago (before LED lighting). I keep watching for developments on lighting that might make it more efficient and having outlets ever 10' permits task lighting. In the meantime my 10' ceilings in my 30'x40' heated space with bright white steel on top lights it up like your typical retail store. Draw-backs are #1 florescent fixtures interfere with AM radio #2 I now know why the electronic ballasts are warranted for 5 years...they seem to last for 5 years plus 2 weeks...
/ Workshop Insulation #23
Spray foam would be nice but it will grow outside the barn walls that's the only setback
Thanks all! All of this is very helpful. Our three new interior walls are built, and I went the Big Box to get a 250' of 12-2 wire so I can rough in the electric. I noticed they were having a sale on fiberglass insulation, and I was thinking of putting R-13 or R15 in the three interior walls. My studs are rough cut hemlock at an honest 4". I plan to panel the aisle side of the barn with reclaimed barn wood to maintain the character. Thoughts? We have not yet decided how to cover the shop side of the wall or how to insulate the exterior walls.
/ Workshop Insulation #25
The old rule was R19 is used on 5.5" material (2x6), R11 on typical 3.5" (2x4). I guess the insulation guys have figured out how to increase the R value on each (R21/R13) With a true 2x4 I guess R15 might work. You haven't mentioned your heating supply yet.
/ Workshop Insulation #26
@Jack707 - Please catch me up on spray foam "growing outside the barn" as I have plans to spray the entire inside of my metal barn when it is complete...
/ Workshop Insulation #27
We want to insulate now from the inside, and we have access to some reclaimed 4x8 sheets of 1-inch thick rigid yellow polyiso insulation. We plan to panel the interior of the shop with boards.
Thoughts on the installation of the polyiso or other insulation? The interior two walls will also need to be insulated, but those are new walls built between the beams.
Thanks in advance!
That rigid polly-iso is equal to spray foam, (per inch) good stuff. Cut & fit tightly and use "can foam" to seal the edges & any joints. I used 2 layers of 1.5" and had enough room left for 3.5" of f/g. I would use 2 layers at the exteror walls to put your dew point in the insulation to avoid moisture issues.
Lucky your in Maine, you can check out "hot & cold" radio with host Tom Gocze on the radio 101.3 Augusta on Sat. mornings starting at 8:00. All sorts of great building info, and you can call in with your questions.
/ Workshop Insulation #28
I had my house outside wall sprayed and anyone who comes over can see the foam that came thru. Now as far a my pole barn goes nothing came out.
So 3" of Pollyiso with R-13 for the exterior walls?
/ Workshop Insulation #30
Foam will find any crack or gap and depending on the size determines if you have a "bulge" of foam on the outside or over spray everywhere. In most cases it can be cleaned up, but it's best to avoid it if possible.
We try and identity problem areas and seal them ahead of time and if we suspect problems we keep a check on things.
Probably a rinnai, although would love to find a wood burning solution.
/ Workshop Insulation #32
Yes, insulation is your friend! It get's to a point of diminishing return on your money, but the f/g is just so cheap and easy after doing the "cut & fit" foam, and with the exception of this last freak price drop in fuel/energy cost's always go's up.
My construction just allowed (unintentionally) the space to fill the stud bay with r-13 on top of the foam.
I can build out the exterior wall enough to probably 6" deep. Did you leave and air gap between the rigid and the exterior wall? I won't get to installing Tyvek under the new siding until next summer.
/ Workshop Insulation #35
False economy in that plan.
It is not at all equal and you will have air barrier and moisture problems.
Costs more than getting the foam to begin with.
Our plan, given that the exterior wall sheathing (vertical boards) and siding (horizontal boards) is both "barn built and old" (i.e., plenty of sunlight coming through), is to treat it like an old building with no sheathing. From outside to inside, we're thinking air gap, rigid foam, batt insulation, interior panelling. Does that sound sound?
/ Workshop Insulation #37
Not at all. reclaimed p-iso foam @ .25 a board foot compared to $1 bd/ft (in our area) for sprayed in closed cell. The edges & joints are sealed, there is no air movement carrying conditioned air through the wall cavity for condensation concerns. I would agree that there is nothing better than a spray in foam job, period. This is a very close second at a fraction of the cost depending on what you attribute your labor at.
/ Workshop Insulation #38
No, this was new construction, 2x6 studs with a 2x purlin or wall girt to fasten the "barn metal" to. Tyvek, all taped under the metal. 1st layer of foam runs horizontally between the wall girts, foamed & sealed all the edges, then the 2nd layer vertically in the stud bay, again all sealed. This left 4" for f/g. Now for the insulation purist, there is some wood to wood (where the vertical & horiz. framing intersect) areas that have no insulation at all, and this lowers the overall wall insulation value, but this is a shop and the insulation was an afterthought.
Thanks! We're definitely not doing spray-in for this project for reasons already discussed, so I appreciate your feedback on other options.
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
2018 CHEVROLET 3500 SILVERADO CREW CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
2017 Link-Belt 350X4 Hydraulic Excavator (A66734)
2017 Link-Belt...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A67714)
TWO PALLETS OF HYD...
