Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #3,821
Thanks so much guys
I think 2 of the bolts are broken off - how do I get those out
I took 4 off in order to remove the cover
Thanks for suggesting I test it without the belt and cover - my work scheduler is hectic the rest of the week not sure when I can do anything else to it
/ Let's talk flail mowers #3,822
The bolt that is obviously sticking out seems slightly curved or is bent
Is that the tension wheel bolt
/ Let's talk flail mowers #3,824
Hello Kimaron,
Broken bolts are the worst if they are sheared off completely.
It takes time and patience to remove them with a left hand
twist drill and a center punch.
If possible, would would you be so kind as to take some
more pictures of the broken bolts and up load them to
the forum? This way I and the other flail mower owners
can help you better with the problems you have to deal with.
The issue with Flail mower scoop knives which are the type
you have its a case of piece count when purchasing them as
well as hanger straps and knife hangers.
If all the scoop knives, knife hangers and knife hanger straps are intact
you will only need a dozen or so new hanger straps, knife hangers and
fine thread nuts and bolts and lock washers.
The fine threaded nuts and bolts and lock washers can be purchased in bulk from a Fastenal dealer
Tractor Supply Inc, Farm and Fleet, Menards or Mcmaster Carr. Mcmaster Carr usually has the best prices for nuts bolts and lock washers.
Its always a good idea to replace each and every nut bolt and washer when changing scoop knives or side slicer knives as they will become nicked and the threads are pretty well damaged from the debris the flail mower
will kick up over time.
If you replace all the scoop knives, hanger straps,nuts, bolts and lock washers your still going to pay more because you will be buying under fifty units of each item.
For now It would be better for you to correctly identify your flail mower and then you can order a catalog from the flail master or clean cutter folks and check with the local implement dealer that handles the brand of flail mower you own to obtain prices for the scoop knife, knife hanger, hanger strap and buy the fine threaded nuts and bolts and blue Loctite from one of the suppliers I detailed above to save money on them.
Purchasing a good wire brush and very small stiff wire brush to clean the threads of the hanger bolts before you remove them will save you some work and reduce the deposits in the swear jar.
We all want you to succeed Kimaron so no worries there.
/ Let's talk flail mowers #3,825
NOW about the drive end picture of your flail mower.
First the tension snubber pulley is not spring tensioned it has a threaded
rod and nut that is used to provide the tension required to operate your
flail mower correctly. Not the best way but works well on many
brands of European Flail Mowers.
You will need to loosen the nut that tensions the snubber pulley to install
the new V belts. if can pick up a can of PB blaster which is a penetrating
oil and lubricant it will aid in loosening the tensioning nut that holds the
snubber pulley in place.
The snubber pulley and the driven pulley look fine so no worries there.
The two studs that are broken off flush may have a pair of nuts holding them
in place and would be easy to replace but until we see the inside of the V Belt
guards cover behind the broken studs we will be unable to help you.
/ Let's talk flail mowers #3,827
All those bolts are just 1.5 or 2" carridge bolts, 3/8" if I recall. The one to mount the snubber pully is just a long carridge bolt. If any are broken a hammer & punch or screwdriver will get em right out. Pretty easy when you look at it up close.
/ Let's talk flail mowers #3,828
Woodmaxx FM 78H flail with hydraulic offset.
I picked it up and didn't get to touch it until almost dark.
First impressions...
Shipped in a very secure bolted together angle iron frame/pallet. I have quite a bit of 1-1/4" angle for projects now.
Paint could be better, it's glossy, but there are a few runs and drips, not a big deal to me but some may not like it.
Spares that I ordered were shipped with the mower in sturdy wood boxes. I got a full set of side slicers, and 8 spare hammers. (I ordered the mower with hammers) all appear reasonably sharp and consistent in the ground edges. New bolts and lock nuts were provided as well.
PTO shaft was 3" too long but that's better than too short. The u-jounts needed grease. It has a slip clutch. I backed off the tension and we will see what it takes to slip it, rather than the belts. This may be more of a pain and I may just tighten it up, we will see.
Gearbox was full and it was tagged as filled. The gearbox has an overrunning clutch. All bearing zerks had fresh grease on them, but I added 5-6 pumps just to be safe.
Belts are gates (I need to get a spare set) pulleys are in alignment and nicely machined.
The hydraulic lines for the offset are 1/2"npt, no fittings were supplied, I wish this had been called out so I could have had the correct fittings for my remotes on hand...
I set the roller and the skids as low as possible this looks to be about 4in height. Trash door is closed.
I ran it for just a minute, and mowed about 50ft of lawn with it, no vibration to speak of, and the grass got a nice haircut as near as I can tell in the dark...
Fittings and pics tomorrow as well as some light field mowing.
/ Let's talk flail mowers #3,829
Anyone have experience with a Rankin SMO-200?
Used one popped up locally.
/ Let's talk flail mowers #3,830
Woodmaxx FM78H Flail.
I got my Hydraulics hooked up today and the side shift works very well. See the pics for full left/right. I think it will work out nicely.
I mowed a little in my field, its been awfully dry so its not much of a challenge, but it leaves a nice cut. I also mowed some small brush all less than 1in, it flattens some of it out, but going back over it in the opposite direction cleans it up nicely.
I have the roller set all the way down as well as the shoes. I'll keep it this way until I have mowed everything once with it, then lower it a bit. Interestingly Woodmaxx recommends it be set up with a static angle of 15deg up in front as opposed to level. This is how it is set, and it does float nicely with the slotted top link hole.
I did also find one rock about the size of a softball, it made quite a racket, but there appears to be no damage.
Overall my first impression is positive. It appears to be well built, the welds all look to be solid, its easily greased, etc. for the $$$ I think its a good value. We'll see how it holds up in the long run but I think it will ultimately be more durable than my HD Rotary cutter.
I also tried running it using my tractors 790RPM PTO and throttling down so the output is 540 as indicated on the Tach. This worked quite well as the tractor runs cooler, and being gear drive it lets me run slower in each gear. We will see how this works in wetter conditions, but for now it's useful.
Questions or comments please let me know.
/ Let's talk flail mowers #3,832
I am glad its working well for you Sidecarist.
One thing to be very mind full of is the fine dirt air inlet screen for your radiator
as it will tend to plug quicker on you if the wind is blowing the wrong way while mowing.
Happy Safe Mowing, Oh, did you save that rock and throw it at the rotary cutter as you passed it while mowing :^)
/ Let's talk flail mowers #3,833
I have come to the conclusion that I hate all you folks. :p:D You All have caused me to waste hours of reading these worthless 384 pages and 3382 posts talking about flail mowers. Green ones, yellow ones, blue ones, red ones, orange ones, rusted ones!!!!!! - Geese :confused3: - Theeeeeeen there are the hammers and knives and I wont go into rotation direction. Sounds too much like politics. Oh the pain of it all. I wish I had never heard about flail mowers and was back happily manually cutting my field edges and ditch banks with my wonderful string trimmer howling in my ear. Heck - it always started on the first pull....NOT! My brain is fried and I have just had enough with all of you. I have even had to endure cruel and unusual counseling by Leonz with his vast knowledge over filling my vast brain. Its all of yours fault that I am in dire distress. It appears now that the only solution is spending $$$$ and then sitting, waiting and howling at the moon for the cure to arrive. What is this old man to do...I just dont know...:confused2::eek::confused2::confused:
I will be placing my order for the Maschio Giraffetta 160 SE in the morning. :drool::D:D:D Iowa Farm Equipment has be great to work with. Salesman was out of town today delivering a tractor to Texas of all places, but I will send in the order tomorrow and I will have the invoice to pay Monday. They have worked hard earning my business. The Engineer in me had a lot of questions, and thanks to Leon :cool2: I actually knew what to ask. Add in the rest of the knowledge I have gleamed from you folks reading this novel I think I have made a proper choice for my needs that will work with my tractor. I am feeling just a little better now.
More later as my cure unfolds.
/ Let's talk flail mowers #3,834
WHAT ... You didn't go right out and buy the first rusty flail you saw on craigslistDOTcom?? :eek:
/ Let's talk flail mowers #3,836
No time - I was too busy reading this thread:laughing:. Besides - they do not exist out in the wild west for some reason.
/ Let's talk flail mowers #3,837
5 of em posted on CL in Colorado in the past 2 years. 2 huge crop shredders, 2 way overpriced & I own #5. Bought a $100 mower as a project, then found out it was a flail, then found out what a flail mower was & this thread.
/ Let's talk flail mowers #3,838
I may have seen those front range ones, but non were verge mowers were they? Being here in the SW corner I am in no-mans land - heck we cant even get Denver channels on our TV package. US government (FCC) thinks we are part of NM.
/ Let's talk flail mowers #3,839
Finally got a chance to set up my FM4188. Had to cut down the PTO shaft. Twice. �� Didn't take enough the first time. Then, with daylight expiring, I went up on the hill to try it out.
This thing is a beast!! One of the most overly built things I've seen!!! Started the PTO and it sounded like the vacuum everyone describes!!
Mowed grass well. High weeds- no problem at all. Mince I was used to it, I ran it at in medium range like I do with any other mower I've used. No problem at all!!!
Bottom line, love this mower already!!
/ Let's talk flail mowers #3,840
Keep us posted on your experiences with the FM4188. I've asked an area dealer to quote on one to replace the New Holland 918H. Thanks, Vic
2015 Ford Edge SUV (A61569)
2015 Ford Edge SUV...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
New/Unused SD Lanch SDLD25 Mini Crawler Dump (A61166)
New/Unused SD...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63118)
2019 Takeuchi TL8...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
3ft. Wooden Native American Statue (A61569)
3ft. Wooden Native...
