Bx23 blinker bulb
/ Bx23 blinker bulb #1
ctcyclist
Kubota BX23
Can someone please tell me what the non-Kubota part number is for the blinker bulb? Kubota's part number is 37410-52720 20W.
The bulb is stamped Stanley 12V 20W. It's a single contact bayonet base bulb. Bulb is approximately 11/16 dia. x 1-1/4 long.
I want to replace them with LED's, so I need a normal part number to cross reference.
Thanks,
Rob
/ Bx23 blinker bulb
Thanks George, but that bulb is to big. It's a fairly small bulb, with a high wattage. I attached a picture of the bulb.
/ Bx23 blinker bulb #4
What you have appears to be the equivalent of a 12V #89 automotive bulb with G6 BA15S base. They come in brass and silver base color. Any auto parts store can match it up to the equivalent LED.
I found some more specs on your bulb.
4129/12V/20W EUROPEAN
4129 EUROPEAN
4129 STANLEY
category: Incandescent-miniature lamp
volt: 12
amp: 1.67
watt: 20
base: BA15s - Single Contact Candelabra Bayonet (or S.C.Bayonet)
glass: G5-3/4
d.hours: 200
notes: clear glass
/ Bx23 blinker bulb
OK George..... I'm really impressed! I scoured the web looking for that bulb, and you found it in a couple of hours. Thanks for taking the time to do that.
/ Bx23 blinker bulb
Remember that you may need a new flasher too.
Good point, I hadn't thought of that......and now you got be thinking about the hazard lights. I was going to just replace the bulb, but now I'm thinking about replacing the whole thing with a yellow LED strobe light.
/ Bx23 blinker bulb #8
You may want to replace your blinker fluid also. Go to youtube and search for "blinker fluid" then click on the video by Chris Fix for a complete explanation on how to perform this vital maintenance.
/ Bx23 blinker bulb #9
A lot of the replacement LED bulbs have a built in resistor so just replacing the standard bulb should work. I also have strobes front and back plus an LED strobe on top of the cab.
2018 JOHN DEERE 60G EXCAVATOR (A64277)
2018 JOHN DEERE...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2025 Vicsec 30in. Bucket Mini Excavator Attachment (A64553)
2025 Vicsec 30in...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
2008 Mercury Mariner (A62679)
2008 Mercury...
CHANDLER 500 BBL FRAC TANK (A65643)
CHANDLER 500 BBL...
