What do these do? Ck30
/ What do these do? Ck30 #1
atcNick
Longview, Texas
Still shopping
Can anyone tell me what these 2 do? Sorry, don't have an owners manual
/ What do these do? Ck30 #2
The pedal is to lock your rear differential, and the knob control a how fast your 3ph drops
Thank you sir! On the locking rear diff, when would I use it? Sounds kinda like the same thing 4wd would do?
/ What do these do? Ck30 #4
The locking differential only locks the rear tires, 4WD sends power to the front tires.
/ What do these do? Ck30 #5
When you're up "crap" creek! :D
Basically, when you find that you aren't getting traction you have the steering wheel straight and lock down on that differential lock and either command the tractor forward or backward (based on which direction you think will get you out of the mess you're in). Figure it as a last resort: first resort is to switch to 4wd- if you're running in any condition that you think you might have traction problems in you're best to start out in 2wd and when you sense trouble go to 4wd and get out of harms way- if you fail to abide by this method and you still get stuck they the diff lock is pretty much your Hail Mary.
/ What do these do? Ck30 #6
With the knob, you can also lock your mower or whatever implement you have on the rear, in a full up position. Sometimes you want to do this
when using the front loader to give full hydraulic power to it. At least that's how I use it. :)
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2004 GMC 5500, Duramax Diesel Truck Vin# 1GDE5E1234F520387 (A62679)
2004 GMC 5500...
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
