Mowing Detroit Mower Gang
/ Detroit Mower Gang #4
Re: Mowing tall grass
I have been to Detroit many times and have never seen the grass that tall. Not even on vacant lots. :D
/ Detroit Mower Gang #5
That isn't that hard of mowing, mow grass sticking that high above say a 70 hp tractor and really thick then watch a video of it.
/ Detroit Mower Gang #6
I don't know a thing about Detroit grass, but my little Kubota B2710 with a 5' rotary cutter had no problem with Johnson Grass that was that tall and much thicker.
/ Detroit Mower Gang #7
I have no problem cutting Johnson grass.
Now how do we get rid if it?
/ Detroit Mower Gang #8
I mowed a pasture a few weeks ago that hadn't been mowed in a couple of years. Grasses weren't too tall for the most part - maybe 2-3 feet - but some of the weed patches were 7' or better (technically, probably also grasses, but I still call them weeds).
/ Detroit Mower Gang #9
That's an M9540 with 18.4x30" rear tires, 12.4x24" fronts.
/ Detroit Mower Gang #11
Yep, as hardy as it is, others will crowd it out if mowed short.
/ Detroit Mower Gang #15
I used Outrider herbicide about a month ago on Johnson Grass in a Bluestem pasture. Looks very promising so far. I never had much luck with repeated mowing. Since the Johnson Grass is starting to go dormant here I won't really see how well it worked until next Spring . Vic
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
Woodland Mills Sawmill (A65579)
Woodland Mills...
25 Traffic Cones (A65583)
25 Traffic Cones...
19-gallon Portable Sandblasting Cabinet (A66408)
19-gallon Portable...
New Holland 492 Haybine (A66408)
New Holland 492...
