Adequate drill press specs
/ Adequate drill press specs #1
msjanket
I want to be doing more of my own repair work on my current equipment and realize I need a drill press. I would guess that a press should probably be able to drill a half inch hole in 3/4" thick mild steel. What kind of HP motor will be adequate for this drilling capability? I see many used ones, some that are sorta antiques but still working good, but most have around 1/3 HP, probably inadequate? I would also expect that a press should be able to turn slowly, say 250 rpm as minimum.
Any suggestions that would help me buy a second hander that has adequate power for the tasks at hand?
/ Adequate drill press specs #2
If you want to do thick steel, it is not about the power, it is the speed. Low speed. It is hard
to find anything new today that spins under 250 RPM, unless it is an expensive, geared-head model.
I have the biggest unit you can buy that uses belt drive, and I always run it at it's lowest speed.
It is the HF 20" wet table "production" drill press. I wish it would go slower yet, as it still spins
at a bit over 200RPM. Definitely better than my old 16 1/2" Delta.
Consider a vintage floor-standing press, if you can find one in good shape. Some of those are
good for as low as 150RPM.
I hope to modify mine, eventually to get it down to 100RPM, or less.
/ Adequate drill press specs #3
I think most have 1/3 to 1/2 HP motors that are for home use. That should be adequate for home use since they are geared(belt drive reduction)pretty low. I too have thought about getting one, but just don't drill that many holes. Most of my drilling is with my 20V battery powered and occasionally I break out my 1/2" drive 110V hand drill for the larger than 1/2" holes. I find that I can do most anything I need with those 2 drill motors.
I did have a Harbor Freight 1/2" drive hammer drill but the hammer quit working and the gears stripped out after very little use so I wouldn't recommend those.
/ Adequate drill press specs #4
Mine turns 60 rpm and is 2 hp. It's plenty of power and I use the low speed a lot. I wouldn't want less than 3/4 HP.
/ Adequate drill press specs #5
Look for one that has low speed...
Older is often a much better value all around.
/ Adequate drill press specs #6
I got this 1950's era Duro from Craigslist. It was not working. What caught my eye is that someone added an intermediate pulley that slows the 1725 rpm motor speed down to 130rpm at the spindle. It has a 1/3 hp motor. It will drill 1/2" in mild steel with a twist drill and 1" with a hole saw. I wouldn't necessarily recommend this solution, but it works for me, and illustrates the point that low rpm is the main factor for drilling mild steel. Rather than big or expensive.
/ Adequate drill press specs #7
I ended up buying a Bridgeport Mill when all I started out looking for was a heavy duty drill press.
Don't regret my buy for a moment... but the 2000 pounds made moving a challenge.
Lots of good old iron for sale cheap once you find it.
and yes... it has very low backgear speed as well as high speed.
/ Adequate drill press specs #8
Here is my experience - Just like you I was looking for a quality used Drill Press and was ok with spending $500-600 dollars. I had settled on trying to find a well kept old Craftsman floor model when I stumbled onto a Harbor Freight 1/3 HP bench top press for $40. That was three years ago, it has performed well for my minimal needs and I have easily drilled 1/2" holes through 3/8" bar steel. My only complaint is it has allot of drill bit run-out so I could not use it for precision drilling but I'm not building aircraft. I have learned allot using this small press manly drill slow, use enough cutting fluid to keep the bit from over heating and getting dull. My suggestion is maybe lower your sights and go cheap until you figure out what works and doesn't. Whatever you decide I have had good luck with Kobalt HS bits and Rapid-Tap cutting fluid. Good Luck.
/ Adequate drill press specs #9
When I looked for a new press, lower speeds didn't seem to exist and I'd say 250 is pretty fast for a 1/2 bit. Then I found this outfit, Rouge fabrication who made kits to slow drills down. The have three kits from 4 to 1, up to 16 to 1 reductions. I've not got one yet but I sure would like to get it and slow my drill down.
Product Categories Drill Press Reduction Kits
/ Adequate drill press specs #10
Last year I found a 16 speed Harbor Freight Central Machinery floor unit off Craigslist. It was barely used. 16 Speeds, 1 HP motor, and the lowest speed setting is 200 RPM. Is it the best quality out there? Absolutely not. Is it adequate for the majority of home owners and occasional users? Yes. Good luck in your search.
/ Adequate drill press specs #11
I have several floor model drill press', but I bought my "biggest toughest" one used, actually I milled a load of logs in trade for it, about $600.00 worth of BSM'ing that I really didn't mind doing...
It's a Solberga made in Sweden... and it's all gear drive, with a mechanical transmission with a large chuck and slow spindle speed. It's an absolute brute! So you better anchor down what ever you are drilling, real good!!
Along with the hand switch, it has a foot pedal for forward and reverse and it also has "power down" for tapping, if you want to use it.
My point is, there's LOT'S of used iron out there, that's MILES better than the junk sold today!!
SR
/ Adequate drill press specs #12
Go with a drill/mill.
2 hp, 5" stroke, x,y table and a 6" vice.
You can put a broken bit in one and still drill a hole in 1/4" steel.
I got two, one setup for milling and one setup for drilling.
/ Adequate drill press specs #13
What a beast... I bet it could handle small end mills in stride.
/ Adequate drill press specs #14
It's a little pricey, but Nova just came out with a new drill press that I wouldn't mind having. It's a 1 3/4 HP but it's a DC motor that is direct drive (no vibration) with lots of torque even at slow speeds. It has some amazing electronically controlled features like programmed depth stop. It's speed range is 50 - 5500 RPMs and has a 6 inch quill travel.
NOVA Galaxi DVR Lathe
/ Adequate drill press specs #15
It's kinda funny... ever since I sold my milling machine, my only drill press is a variable-speed bench top which as a hard time with 1/2 and only gets down to about 560RPM IIRC. Mainly I have to drill holes for Cat1 implement pins (7/8) and 1" pins for hydraulic cylinders.
What I've been doing is using my drill press to drill the pilot, and then using a handheld right angle drill (DWD460) to do the actual drilling which will go MUCH slower. Kind of interesting having to go to a handheld drill to drill the big holes, but it's what I've got... and I don't do it that frequently.
/ Adequate drill press specs #16
That is REALLY interesting. I will have to give them a call and see if they still have the 20% off deal, and what the rated metal capacity for twist bits is.
I think about the Evolution mag drill though all the time, and it'd be 1/2 the cost.
/ Adequate drill press specs #17
I can't imagine having only a magnet drill. It would be nearly worthless for the majority of what I do.
/ Adequate drill press specs #18
I have several floor model drill press', but I bought my "biggest toughest" one used, actually I milled a load of logs in trade for it, about $600.00 worth of BSM'ing that I really didn't mind doing... It's a Solberga made in Sweden... and it's all gear drive, with a mechanical transmission with a large chuck and slow spindle speed. It's an absolute brute! So you better anchor down what ever you are drilling, real good!! Along with the hand switch, it has a foot pedal for forward and reverse and it also has "power down" for tapping, if you want to use it. My point is, there's LOT'S of used iron out there, that's MILES better than the junk sold today!! SR
How do you use power down for tapping? I've power tapped before, but I manually lower it until the tap grabs. Then I let go and let it pull itself through. Then I reverse the drill and let it screw back out.
/ Adequate drill press specs #19
Actually, I think what he has is a power down for drilling,,, rated in distance per revolution.
My drill has that, a very common feature on gear head drill presses.
Pushing a drill bit at an exact down velocity prolongs drill bit life.
Drilling a little, relaxing the force on the handle, then start drilling again,,, will dull a drill bit FAST.
My drill press:
Notice the long, continuous chip being produced by the drill,,, as I stood by taking the pic?
I was drilling 3/4" holes in 1" thick steel. I was feeding the bit down at .006" per revolution.
I was using the Kool Mist sprayer to cool the drill bit, and lubricate the cut.
It looks like this:
I just finished drilling about 40 big holes for my landplane build.
No drill bits were worn out, broken, or otherwise damaged. ALL the drill bits were over 10 years old.
/ Adequate drill press specs #20
You are probably right, I've never used that feature for tapping and I was just going by the specs I read on line, when I looked my drill press up.
I only use my big drill press when I have a big hole to drill, I have other drill presses for smaller stuff...
SR
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2016 Ford F-150 Ext. Cab Pickup Truck (A61568)
2016 Ford F-150...
2018 TROXELL 130BBL VAC TRAILER (A60736)
2018 TROXELL...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61165)
IMPORTANT PLEASE...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
