LED tractor lighting......
/ LED tractor lighting...... #3
Following
/ LED tractor lighting...... #4
I put 2 on mine. 1 front and 1 back on brackets I made. I bought mine off Ebay from different place. If I recall they were around $50-60 each and free shipping.
I see lots of them now for $34-60 with free shipping.
/ LED tractor lighting...... #5
I just changed over to a small LED bar, the center was spot while 2 sides were flood.
This was to replace a 4" halogen flood and it does a much better job of practical lighting and at much lower current draw.
Out cuts really like LED lighting as generally charging current is limited.
Also high amps steals HP from your working HP.
/ LED tractor lighting...... #6
/ LED tractor lighting...... #7
WOW Only $99.00 for a 24" light, if you fast it's not so bad, least it's not $100.00 good thing I only need two sets. What ever happen to the $19.99 as seen on TV........ Now if I can just find a bright flashing warning light to let me know I have the blanking brake on while driving my tractor, I'll buy one yesterday.
/ LED tractor lighting...... #8
Bought an 18W light and installed it like this:
Bent the metal bracket going under branches a few times and 3D printed another.
Broke that as well, so I went to a slightly longer, 36W unit above with metal brackets at each end. This way I can mount it on top of the ROPS, or underneath when in the woods.
/ LED tractor lighting...... #9
When I bought my Mahindra 5035 back in 2011, I put some 27w LED's on the ROPS. Lot's of light for the current draw over the stock halogen work light. I also converted my brake and turn/flashers over to LED, then put them back stock after they constantly got covered in snow in the winter. I added two turn/flashers higher up on the back, and ended up using the stock turn/tail orange bulb...but added LED COB lights inside the fixture [ flat panel LED arrays ] to add lumens to those flashers. The stock lights provide enough heat to keep the lens fairly clear during snow storms.
/ LED tractor lighting...... #10
/ LED tractor lighting...... #11
I'm replacing my tractor soon with a cabbed one. While my 4 small squares have worked fine, I'm looking at a curved bar next. For tractor work, you don't need to see really far out, but you do need to see to the sides more. Curved should give more side coverage than a straight bar, at the cost of distance, but that's not as important.
/ LED tractor lighting...... #12
I mounted two of these 12V Tractor Work Lights | eBay hanging from my ROPS, that can rotate left & right for side lighting and fold up under my canopy out of the way when not in use...they work great.
/ LED tractor lighting...... #14
I have found this arrangement works well for me for plowing snow: I added the small side lights because I plow thru trees and brush lined areas, and wanted to see what's along side me, as well. All 3 switch separately, since I don't always need all 3 pairs. Maybe 75 bucks invested for lights, plastic loom, switches and relay, using my time and scrap aluminum for brackets. Some paint, of course.
/ LED tractor lighting...... #17
Very nicely done!
/ LED tractor lighting...... #18
/ LED tractor lighting...... #19
Anyone have a link to the 2 or 3 prong connectors. Forget their brand name. They have a nut that screws them together. I need some to do a light install on the Kubota.
/ LED tractor lighting...... #20
FWIW, the ROPS is unaffected. I even planned ahead (!) to be sure the lights wouldn't make installing the ROPS pins awkward, if you can imagine that. But then, I have done lighting jobs on our tractors 4 times now, with some re-dos as I learned. I am retired, so I have time to mess around.
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A65563)
2023 Ford F-350...
GIYI Skid Steer Mount Stump Grinder  (A62679)
GIYI Skid Steer...
2022 EZ-GO ELITE...
New/Unused 12V Diesel Pump with 50ft Hose (A65583)
New/Unused 12V...
1997 International 3800 School Bus (A64194)
1997 International...
