Adding to existing drive
/ Adding to existing drive #1
jk96
Elite Member
Missouri
Kubota L6060
I'm getting ready to form up and pour another section of concrete with the goal of eventually bringing the concrete up to the front of the house. Current slab is 5" thick. I'm wondering what the best method is to add to the existing slab. Should the existing slab be drilled and rebar epoxied in order to tie the two together or should the two slabs be allowed to float independently with an expansion joint?
/ Adding to existing drive #3
What type of soils do you have and what type of subbase do you have? Free floating slabs are easier but may shift more than desirable. Obviously if you can tie them together with rebar it will be better.
I don't know the answer to your concrete, but that looks like a Ferris IS2100Z perhaps?
Exmark LazerZ. Didnt have any Ferris dealers nearby a few years back so I didn't look at the Ferris mowers.
Soil drains well. Not sure of the mix. There is a decent amount of clay in spots. Sub base is 3-4" of rock that is well packed since construction 3 years ago. I've got the bits to drill the concrete and tie in. Just need to pick up some epoxy.
/ Adding to existing drive #6
For sure drill holes and drive in rebar, epoxy helps. We usally use the same size of drill bit as the rebar diameter is. You need rebar pins on both sides of any cracks, existing saw cuts or expansion joints. Then the rest of the edge can be spaced out. 12 inch to 24 inch apart for the pins, more pins is better. Put rebar in the new concrete if at all possible. Not getting into a long discussion on if rebar is needed, or if fiber mesh or wire is good enough. Nothing replaces rebar. Try to plan ahead where saw cuts will be after you pour. Put rebar on both sides of the saw cuts about 6 inches away and then fill in between as needed. Once again 12 to 24 inch or in between, more rebar is better. #3 rebar ( 3/8 inch ) is prolly ok, #4 is better and less likely to be bent in shipping and handling. Perhaps a extra rebar at the edge where you drive up on to the new drive section. Any existing saw cuts or cracks will have a tendency to continue into the new concrete at the same place. So keep that in mind when planing your saw cuts. 40 ft of concrete in general between expansion joints as a rule of thumb10 ft squares after saw cutting is usually about as far as you want to go. . Pack the base before you pour !
Thanks for taking the time to write up such a detailed post. I'm planning #4 bar with an 18" grid with extra bar on around the edges. Will probably just continue the existing saw cuts forward into the new slab. I was planning on using a 5/8 drill bit in order to get enough epoxy in the hole and around the bar. Sounds like you don't recommend this?
/ Adding to existing drive #8
Generally, the best method is to have the apron (the slab next to the structure) bear on the foundation wall with the outside edge supported on frost footings. In your case you could get by by pinning it to the existing slab. Generally the problem is settlement of the backfilled material at the foundation wall. As this material settles the slab becomes unsupported and you end up with cracks. Now the settled apron slab is pointed towards the foundation and the cracks allow the water to enter the soil causing freeze-thaw expansion issues.
/ Adding to existing drive #9
The tighter the fit the better, we often do no even use epoxy on pins for items such as driveways. Just hammer in the rebar pins.
The slab next to the house foundation and stem walls was poured about 3 years ago during initial construction. I'm simply tying into the existing slab to extend the driveway out so nothing new being poured next to the foundation.
/ Adding to existing drive #11
Expansion joint, if I understand right your just adding to driveway and calling what you have already poured a slab
/ Adding to existing drive #12
5 in slab is on the thin side for tying slabs together. If you have differential movement between the slabs, you have two inch of concrete resisting that force. It does not take much force to break two inch of concrete.
If you install dowels, you want to use epoxy so that the dowels are uniformly loaded
Cracks and joints in one slab will tend to continue into the next slab. Plan your joints in the new slab accordingly.
Rebar in the thin slab does not add much strength but it helps hold the crack together. If rebar is 24 inch on center, crack can grow to 24" before encountering a rebar. Fiber will intercept the forming crack in a much shorter distance.
If this was my slab , I would make the edge where the slabs abut to 8" thick for 12" in width.
/ Adding to existing drive #13
In that case, then there's no need to pin the joint. Theoretically there shouldn't be any vertical movement. If you do want to pin the joint, then smooth rods and sleeves are typically utilized so the slab is restrained in the vertical plane, but it's still allowed to expand laterally. Of course, expansion would only be an issue if you are pouring a large slab (don't recall how big you were looking to go). Done lots of 5" slabs with 3/4" dowels @ 12" o/c.
This section will be 45' wide by 12' deep. Ill be doing another after this one.
Hi Cord. I talked to a couple of guys I know in the business and they suggested doing something very similar to what you suggested, 5/8" holes 20" o/c with 1/2" bar, no epoxy so it can move. Finally got around to getting the pad formed up and ready to pour. Looks like Thursday or Friday may be a good day for it.
2018 Kubota SVL 75-2 Skidsteer (A65579)
2018 Kubota SVL...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
master diesel generator (A64553)
master diesel...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A65643)
2009 VOLVO VHD...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
