Building our new dam
/ Building our new dam #61
With strong recommendation from Check and Brandi, I reckon I'll have to find some Crown Royal to sample - sounds well worthwhile! :thumbsup:
Definitely, definitely try it. I usually drink it, unless I'm wanting my favorite drink............Magaritas!
hugs, Brandi
/ Building our new dam #62
I have never seen how a mini Dam is created. You have put a ton of work there.
Hello there Lucky, :) I'm glad you are finding it interesting too. You're right - there's more than a bit of work involved. ;) I've seen over a dozen dams built - mostly for water for cattle, but that was decades ago :shocked: when I was a boy, growing up on our family dairy farm. I'd never been involved in building one ..... until now. Relying only on my memory of watching dozer operators working, and betting on my ability, this is the (almost) finished project. Now only tidying up, watering newly-germinated grass and periodic fertiliser application should be all that's left. :thumbsup:
I'm just a little bit puzzled by your term "mini dam" :laughing: is that a Canadian expression we here in Aussie don't know of, although I believe you may mean a dam of a much smaller capacity than the normal supply-the-town's-water-needs type dam? We refer to those as "reservoirs". This one of mine is only about 22mx26m - it's a little oval, and will fill about 3.5m, not as big as my neighbour's, but just a little larger than our first dam. I can't wait to see them both full! :D
Before, during and after ... what do you reckon?
/ Building our new dam #64
I reckon you are so good on the equipment with those smooth side hills, that your family should let you spread the icing on every birthday cake!
I would be much better at eating the birthday cake (or any other cake) :laughing: my better half can cook anything extremely well, and evicts me from the kitchen! :thumbsup:
Also ... it took ages to get those slopes the way I wanted them!
Another funny thing - after I raked lightly to cover the seed, a lot must have settled into the cleat marks, so now in most places it looks like it's been sown in rows! :D
/ Building our new dam #66
Very nice work. Your photos and explanation are great. Interesting that I spend a lot of time shaping my land so it will shed water and not pool up while you ( and many others ) try to trap water.
gg
Hi Gordon, and thank you - I thought if it helps someone doing a similar thing, great. :D A picture is worth a thousand words, they say. :laughing:
As far as catching (or draining) water goes - it's either a feast or a famine. I ran out of dam water for vege garden and fruit trees twice in three years and had to pump from my good neighbour's dam to keep them growing. I can't rely on someone else to keep topping up my needs ... how would I feel if they also ran out? So we came up with a solution - we have channelled run-off water into his and my dams, instead of down the hill into some creek.
This will ensure that we both have plenty, and I can pump as much as the gardens need. :thumbsup:
/ Building our new dam #68
That looks beautiful, Patrick! Nice work! Doesn't matter how much time it took, the end result is stunning!
Hi Shaeff, thanks mate, and great to see you are back online. I'm dreaming of being able to post a pic of it overflowing - although that may be a year away!:p But that won't necessarily be bad because it will give added time for everything to settle a bit more. Meanwhile that grass grows so slowly! ;)
/ Building our new dam #70
For sure! And yeah I haven't been able to get online much, life gets in the way!
It sure does. Yes, I thought you'd been a little quiet, I've been incredibly busy too. Hope other than that all's well.
/ Building our new dam #72
All is quite well here, I've been busy working the tractor nearly every day when I get home from work. It gets dark around 6:45pm now, so the lights mounted on the loader arms sure help with that. I'll be starting a new thread in the Massey section soon, just need some time to snap pictures and upload them!
Good to hear, I'll watch for it. Everything's been working really quite well here, happy to be able to say. Been a little busy too though, on other things - had my plumber's cap on lately, with a crash course learning to operate my neighbour's backhoe :eek: digging a trench for new transpiration pipes off the septic system here at home. All finished now, :thumbsup: but what a whole new ball game that is ... seems a backhoe has a mind of it's own at times! :laughing: Also helping a good mate with a gearbox conversion on his big tilt-tray, other mechanical work on vehicles for various people - the list never ends! :confused2: Finally getting on top of things though.
We had a wet day last Monday, just over one inch (28mm) of light showers, then a downpour later that night. I'll need to water the dam bank tomorrow or Saturday afternoon, and additional fertiliser as well - hotter weather is forecast from tomorrow.
Don't forget to check your loader's LH front wheel stays tight, although mine fortunately has been Ok since I renewed the studs and nuts.
Hi, Your tractor has controls a little different to mine, but the operation is mostly the same.
The noise you tell me I think is a knocking or a hammering sound? Like you hit a thick piece of timber with a hammer? Does it also seem related to engine speed?
The outer lever with the round ball-shaped handle is the Draft Control, and the inner square-shaped lever is the Position Control.
"Draft" regulates lifting strength; or will sense and regulate load. "Position" regulates lifting height, and that height will be kept automatically.
The Draft Control is used when you are ploughing the soil. You set the lever at a suitable location and it will let the hydraulic system "feel" the load on the tractor and adjust the height of the plough to keep it from overloading the tractor and losing grip. When using the Draft function, the Position lever is usually near the top, and when you want to raise the plough to turn around you just pull the Draft lever right up.
The Position lever is used when you want to lift an attached implement to a specific height. In this mode, the Draft lever is usually at the top.
The "Position" lever also engages a function called "Constant Pumping" which is used only when a hydraulic attachment such as a loader is connected to the system. This function should never be used without an attachment connected - otherwise it will destroy the internal pump.
You said the Position lever doesn't work, but the Draft lever does. When you are using one lever, is the other lever at the top? Remember, the Position lever cannot be in "Constant Pumping" position - that is the cause of the noise I believe you are hearing.
Here is what I would like you to check. Do these first steps with the engine stopped:
1. Look under the round arch-shaped mount for the lever assembly. You will see the shafts for the levers. The first pic below is what mine looks like from underneath. The Position control shaft is a tube with the lever near one end but not at that end, and the Draft control shaft is inside it. Move each lever and you should see the Position control tube moving, or the end of the Draft control shaft moving when you push or pull the relevant lever.
2. Next, start up the engine and let it idle. Carefully raise the 3PL arms with the Draft lever.
Now both levers should be raised. You should hear the knocking noise when the arms stop at the top.
3. Next, increase the engine speed a little and note if the noise knocks faster.
4. Next, move the Position lever toward the "Lower" direction and note if the noise stops when the arms begin to lower.
5. Otherwise the arms might not lower. If they don't, push the Draft lever toward the "Lower" direction and again note if the noise stops at the moment the arms begin to lower.
Please reply with your answers and comments on anything you saw happen, or not happen, in each of these test steps.
The second pic is what my quadrant and lever set looks like from the driver's seat.
The third pic is the view from the front of the tractor.
Check these things carefully please, and let me know your results.
Pat. :drink:
Hi All, Back on topic with finally an update on progress with the dam.
We've had an exceptionally hot and dry summer, plenty heat and almost no rain. As a result I've had to give the wall a light watering almost every day because the "soil" doesn't absorb moisture quickly at all. Adding some fertiliser every couple weeks helped establish the mostly cooch and kikuyu - that's about all that's left now. The ryegrass couldn't handle the hot sun without at least some shade. The last two weeks or so we've had some light rain-showers and cooler days - again a help for young grass. About six weeks ago we finished the water in our other dam - moved the pump to our neighbour's dam, which last week had only around 4 feet of water left.
You may have heard recently about a serious-calibre cyclone (Debbie) in NE Australia ... caused a lot of damage 6-700 miles to the north of us. After crossing the coastline it turned south, no more serious winds but dumped a heap of rain as it travelled south. It's gone out to sea again, but we're now contending with severe floods! Missed work yesterday and today - roads covered by floodwater - no problems for us, but a lot of folks' houses and businesses are flooded. It's levels are just tonight beginning to drop.
As a result, my top dam is full again, overflowed all day yesterday into my new dam, which went to within 2 inches of overflowing.:D
Good news overall :thumbsup: no leaks, nothing moved, washed away or damaged - just as well because it filled up so quickly.
We received 240mm (almost ten inches) of rain in 28 hours. Further inland upstream in the river catchment received 500mm (18") with one locality reporting 945mm (34") in around 36 hours. No wonder we're floodbound. :confused2:
1st & 2nd pic - New Dam; 3rd pic ..... Oops! Soft ground and heavy tractors aren't a good combination! :eek: A couple of days and it'll drive out - otherwise a bit of help from the 135 should be sufficient. :laughing:
The road to work; and some stupid people in their vehicles:
It looks like we will both be pumping from this dam to use at least half the water from it, to allow me to tidy up and finalise, do some more work to improve the aesthetic appeal and plant some more grass seed around the general area. That might have to wait until around August - approaching spring.
/ Building our new dam #76
Wow, that's a lot of rain. Glad it held up. Hope everyone recovers from the storm.
He he, it's still a little damp, but it is great to see them both full. Grass around the bank has been forging ahead especially the last three weeks or so after the really hot weather finished. I tried to gently drive the loader out of that mud earlier this afternoon - no chance for I reckon another three days.
Another added fly in the ointment - we woke up to find no electricity today ... went off around 6am I'm told and isn't expected to be restored until around tomorrow lunchtime. I just finished rewiring our house and two garden flats with extension cables and power boards and running on our generator, but stove, hot water and barbecue are gas and we are quite Ok overall. I keep reminding myself there are thousands a lot worse off - flooded and in a lot of trouble, but I can't get out to help at all.
Incredibly, the river is still rising because of the deluge upstream - expected to peak early hours tomorrow morning.
I'll keep you posted.
Glad to be able to declare enough roads this morning were open again for me to be able to go to work, but traffic was crazy. Just home and got a few things done, electricity was back on when I arrived. :D
We were quite fortunate overall - sadly several people drowned, a lot of people lost all their belongings and in some cases their houses are no longer inhabitable.
All's well here, everyone's Ok, and things are slowly returning to normal. I mowed the house paddock yesterday for the first time in several weeks - it was just too dry for any grass to grow. Dams being both full look great, grass around the new dam's bank is going full-on now that it's got nice moist soil and somewhat cooler days instead of scorching summer sun.
/ Building our new dam #79
Glad to hear things are returning to normal on the Homefront, Patrick. It's always terrible when natural disasters take over, especially when lives are lost!
Also nice to see the dams full and holding water as they should! You've waited a while to see the fruits of your labor!
/ Building our new dam #80
Ole Mother Nature is generally pretty passive. But when she claps her hands you better pay attention.
I am not comfortable with large weather swings. Sounds like you are experiencing them. Hope things calm down for you. Good to hear you and yours got thru it with little damage or loss. :)
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
Pallet Fork Extensions (A64047)
Pallet Fork...
20ft. Homemade Trailer (A64047)
20ft. Homemade...
2012 VANTAGE TRAILER PMEUMATIC CEMENT TRANSPORT TRAILER (A63569)
2012 VANTAGE...
