Tractor Sizing Need sizing advice
   / Need sizing advice #1
RLWATSO1
Member
New Philadelphia, Ohio
John Deere 790
Wife and I purchased 30 acres in Ohio with intent to build on in the next couple of years. Having trouble sizing a tractor as I would prefer to have one that will take care of land as well as mow around the house until funds are available to get a zero turn, etc.
About 10 acres are flat which would be getting finish mowed, about 10 acres are gently sloped which would prob also be finish mowed and about 10 acres are pretty steep which would probably be brush hogged once or twice a year. Very little trees as this area was striped for coal 30 or so years ago. I will also have a 1500 ft drive to maintain part of which will be hilly.
I do not need a cab but HST would be really nice if possible and I also require a FEL. It would be nice to get an 8ft pull behind mower but I'm worried I would have to get something so heavy that I wouldn't be able to use it around the house pulling a smaller mower.
Budget in the 30k range
What do you guys think?
I forgot to mention that we have JD, New Holland, Kubota pretty close and mahindra and MF a little farther away. Dad always had New Holland stuff but I'm good with any brand
   / Need sizing advice #3
Welcome aboard!
Are you really going to finish mow 20 acres?!
Since you don't list any front end loader (FEL) use in your post, I'm assuming you don't need a real heavy tractor for lifting logs or pallets, etc. If your primary use is finish mowing, and some bush hogging, I'd go with something like an L3901 from Kubota. I'm not familiar with the other brands' lineups, other than Kioti, which I think would be the ck4010.
Since you're mostly mowing, weight isn't a big concern for you (other than not wanting to be too heavy). You need enough weight not to be pushed around but any extra won't help you.
The only reason to get a bigger heavier higher HP tractor (unless you're not telling is something) would be to do your mowing in less time. If that's the case, you'll want to look at something like the Kubota MX 5800. It's got more Hi, so you can mow more area faster, but both the tractor and the appropriate sized mower will be considerably more expensive.
Welcome aboard!
Thanks for the response! I will definitely need a FEL to take care of the drive in the winter as well as regular property maintenance. But yeah definitely finish mow the 10 acres and beyond that at least have a decent cut with a brush hog on the other 10 haha, I hate the long grass look
   / Need sizing advice #5
My "estate" tractor is a 15 year old NH TC45D with a FEL, pallet forks, grapple, sub frame BH, and other assorted 3PH tools.
IT's a perfect size for day to day and seasonal chores, EZ to operate and dependable. I have a friend with the same series tractor but about 15 less horsepower. It's a great little tractor but a little lite in the loufers.
The 40 to 50 HP catigory would seem like a perfect size for your application.
B. John
   / Need sizing advice #6
Yeah, I didn't say it, but I assumed you were looking at tractors with FELs. If I only had one tractor, it'd definitely have to have a FEL.
In my case, the l3901 (l3800 at the time) would have worked fine for me except for the loader capacity. I like to move large logs around, and wanted be able to lift pallets of feed off a semi trailer. So, I had to move up a size to the MX 4700.
   / Need sizing advice #9
You might want to consider something else to do with the land instead of finish mowing 20 acres. Even 10 is alot, but depending on obsticals, ~3 hours on a 84" Zero-turn.
Anyone around there that can make hay? Just how hilly is it? Could it be farmed....beans and corn?
IF those dont work......I'd be looking at something like mowing ~5 acres around the house with a finish mower, and do the rest with a bushhog monthly. Grass dont get real bad after a month. Especially on an area that large. But what are your intended uses with the 30 acres other than to mow.
Here is what waiting a month, and mowing at ~4" height looks like with a bushhog. (and this was mowed way faster than any finish mower would have done it)
IF you want it finished mowed.....you are gonna have to do it every week.
   / Need sizing advice #10
I used a 28 HP NH 1720 for 10 years finish mowing around 3 acres and other chores. It was not too heavy at 3300# with loaded rears and AG tires. Perfect size for what you are wanting to do. With a 30K budget anything in the 40-50 HP range will do the job. I would look for a unit that would run at least a 6 foot cutter. Any of the major brands will serve you well. Everyone has their favorites.
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
Informational Lot - Shipping (A56435)
Informational Lot...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
