3 PT cememt mixer cylinder
/ 3 PT cememt mixer cylinder #1
azrancher
Hereford, AZ
MF30, Case 580B, Case 550E Cat RD6
I don't know the brand of cement mixer, bought it from a company back in the mid 90's (Farm & Family?) now out of business.
I need a new seal for the dump cylinder, single acting cylinder, 1.75" in diameter, about 18" long has a stamped part number on it B-2-3-SAI07514.
Any suggestions?
edited to change SAIC to SAI0, apparently there is a SAI hydraulic cylinder company...
Rancher
/ 3 PT cememt mixer cylinder #2
You can get the rod seal and the piston seal at a hyd supply shop. I use Hercules
Hydraulic online. Take out and measure them first.
If your mixer is like mine (Italian-made Mixer80), it has a low quality cylinder and
easily-bent rod. BTDT
I use Hercules
Now you tell me about mixer 80, I just ordered a Cosmo BM 80 350, which is a 1/2 yard mixer...
I'll try Hercules for the seal part.
Rancher
Yes I knew about the Agri supply parts, however what I have, which I bought 20 years ago is not the model they are currently selling.
And I bought the Cosmo 80 350 from everythingattachments.com and they get an A+ and 5 stars for service in the ordering department, saved me $90.00 on shipping by suggesting to ship to the terminal.
Rancher
/ 3 PT cememt mixer cylinder #6
My older Mixer80 looks identical to the Cosmo 8cf mixer. That 12cf mixer is a bigger newer product.
It looks like the lower part of the drum is bigger, but the other parts may be the same.
My experience using my mixer numerous times over the past 15+ years is that the cyl it comes
with is not only wimpy and easy to bend, but it should also be double-acting as gravity is not
always enough to get it to go down.
I converted my cyl to DA first, then went hydraulic drive, and loader-mounted.
/ 3 PT cememt mixer cylinder #7
Hello I have purchased an older 3pt mixer. The hydraulic cyclinder was missing. Could you please send myself the dual action hydraulic cyclinder numbers or specs or company where to purchase a hydraulic cylinders
Im desperate to use this mixer. For I live in the mountains and it's freezes up here.
Thank you Sir and have a great day
/ 3 PT cememt mixer cylinder #8
/ 3 PT cememt mixer cylinder #9
Get a new cylinder from surplus center.com. there going to. E the cheapest around. But I would also check amazon.
/ 3 PT cememt mixer cylinder #10
If I wanted to use any mixer on the 3-point, I would adapt it to the hydraulic toplink you might already have.
A hydraulic toplink for use with other tractor attachments (esp. a box blade) is one of those must-haves IMO. And the SA cylinder that comes with the mixers is awful.
I buy spare new hyd cylinders from Surplus Center when they are on sale.
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
2016 TAKEUCHI TB216 EXCAVATOR (A62129)
2016 TAKEUCHI...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A61165)
2004 Freightliner...
PENDING SELLER CONFIRMATIONS (A59906)
PENDING SELLER...
2016 Chevrolet Tahoe SUV (A60352)
2016 Chevrolet...
2017 Rogator RG1300B Dry Fertilizer Applicator (A61307)
2017 Rogator...
