marklift 42
/ marklift 42 #1
1965cobra
arcadia fl
Bolens G174
Is there anybody that's worked on the hydraulic drive on this boom lift? Travel seems slow and labored, if switched to hi, it will more often than not, stall?
/ marklift 42 #2
Have you checked the fluid level and contaminates? Next I would test the motor.
/ marklift 42
Fluids are fine and clean. Each wheel has a motor all run freely if jacked off of the ground.
/ marklift 42 #4
Did you ever get anywhere with this problem, I have one too ( 2wd ) and it sounds similar, will run more or less fine on hard ground, but if tires sink more than an inch or so it acts like the wheels are stuck, will never spin a tire either.
/ marklift 42
Sounds like you're in high speed. That is the way they are normally when they're in high. They have a week drive. Mike 715 257 7361
/ marklift 42 #6
makes no difference, does the same, seems like a fluid bypass somewhere, hoped you had come up with something with yours already.
/ marklift 42
There is a valve between the 2 drive wheels. It's under the sheet metal cover. Run it open all the way or closed all the way. I can't remember
2023 Case TV380 (A62177)
2023 Case TV380...
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
2022 EZ-GO ELITE...
2006 UNKNOWN 43' LOADER TRAILER (A65643)
2006 UNKNOWN 43'...
211453 (A62131)
211453 (A62131)
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
