Dual Shield.
/ Dual Shield.
Keep the roll of wire in a sealed plastic bag, and in a warm area!
/ Dual Shield. #42
I thought about moisture in the flux but it was a new spool with intact packaging and a recent mfg date at the time, the guy that turned me onto dual shielded wire ran some in my machine without a problem. I'm wondering if my power source is varying a bit since it's on a sub panel.
Hopefully when I get the shop built I'll have clean 3ph and can upgrade.
/ Dual Shield.
I live in the Seattle area. It never gets too hot, or too cold here. Now it does rain every once in a while!:rolleyes: I keep my wire in a locker in the shop.
/ Dual Shield. #45
Weave width doesn't matter except that you can get a very slightly coarser grain structure in the weld. I had a discussion a few years ago about weave width so wanted to get the definitive answer. I e-mailed Walter Sperco who is one of the head guys behind the ASME codes. He said the 2 1/2 or 3 times rod diameter is a wives tale and a carry over from days gone by when some inspectors thought it made a difference.(it does on stainless) He said on mild steel he would challenge any procedure limited weave width and as long as the weld was sound with no slag inclusions the difference in grain structure/strength would be negligible. Hotter is better. I didn't watch the video in question but as long as the slag was burned out the weld should be OK. If the weld and the metal is hot, often the slag won't be a problem. Multi-pass 7018 fillet welds in the horizontal position can be done super smooth by leaving the slag on but the piece has to be hot and you have to do the next pass right away before it cools too much. Flux-core is likely similar similar but I never tried to experiment with it. Also remember that Lanse isn't a licensed welder so it just experimenting a lot of the time himself without having a ton of experience with the different processes and filler metals. I really hoped he would have got into an apprenticeship. He has a willingness to want to learn and I think missed an opportunity but if he makes a decent living doing his video's that's OK too.
/ Dual Shield. #46
I've run the 71m, like it but started getting a lot of worm tracks, never did figure out the problem. Good clean material prep. Structurally good but didn't like it for cosmetics.
This was .045 on a MM 251.
Will say one thing, you better have a good gun or else it'll meltdown pretty quick!
Pardon my ignorance but why will this get hotter than regular solid mig wire?
/ Dual Shield. #47
Luke, here's your clue - "This was .045 on a MM 251" -
The gun Miller ships with their 250 series is an M25, which gets warm even with .035 wire/20cfh gas welding 1/4" material - running near max for the welder with .045 (ANY .045) is more than the stock gun will take for very long... Steve
/ Dual Shield. #48
I wasn't referring to the ability of the m25 handling the heat.
The dual shielded wire works in spray transfer at a higher voltage, it gets hot, higher uv output.
Make sure you're covered up good and have a good set of gloves.
/ Dual Shield. #49
Thank you both for the response.
/ Dual Shield. #50
Here's another stupid question: should I expect the dual shield to sound different than solid?
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A62130)
2006 FORD F-450...
John Deere TX Gator (A60462)
John Deere TX...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
