Battery Booster Pack?
/ Battery Booster Pack? #1
Stubee
Mid-Michigan
LX-176 (not really a tractor)
I've searched but cannot find threads here using my mobile phone so...
I need a new booster/jump starter as my old one finally quit. I see Lithium ion ones are all the rage right now. I'll use it for everything from lawn/garden tractor thru my B2320 to my V8 Tundra. Not sure how the Li ones will hold up/work in the cold, some have flimsy cables, that kinda thing. I'll store it in a toolbox under my truck's rear seat.
Does anybody have any real world experience with a booster they can recommend? Thanks!
/ Battery Booster Pack? #2
EarthX,a little more than the others but great power/quality.Jumped my buddies Tundra(twice) with no problem.Pretty amazing for something you can put in your back pocket.
/ Battery Booster Pack? #4
I use a lot of Lithium Polymer batteries. They do NOT like cold weather. Where I live in Minnesota, they would be worthless, IMO, for winter jump starts, especially if they had been sitting in the vehicle's trunk for several hours. Coming directly out of a warm environment and put to use would probably work. I've not used Lithium Ion batteries in cold weather.
/ Battery Booster Pack? #5
If you had a good booster pack, I have taken them apart and just replaced the batteries. Hard to beat the older dependable lead acid AGM cells.
David
/ Battery Booster Pack? #6
Lithium batteries completely stop working at around -6*F....just a thought.
/ Battery Booster Pack? #7
/ Battery Booster Pack? #8
I had similar needs and looked around at all the popular brands. Already had a Lithium pack. Had to start a boat with two dead batteries (bilge pump comes first!).
After returning another brand purchased a Clore JNC660. Clore makes their own AGM batteries for this purpose and even though you are supposed to recharge every three months, it barely needs it. You can easily start 4-5-6 vehicles in a row. Has a 12v plug but not bells and whistles. Big, heavy, powerful, reliable.
Jump-N-Carry for Vehicle Jump Starting Applications - Clore Automotive | Call us at 1-800-328-2921 | Clore Automotive
I had a high opinion of EarthX when I bought my motorcycle battery. It didn't last. Now I have a BatteryTender.
Our jump pack is three years old, AntiGravity MicroStart. The first and arguably still the best. You can keep it warm in a pocket.
XP-1 POWER SUPPLY & JUMP STARTER • THE MICRO-START
I need one that will work on the cold & will just get another lead acid type. Thanks.
/ Battery Booster Pack? #10
I second the Clores
/ Battery Booster Pack? #11
I have Clores CLOES5000 and it has worked good for a few years and my sons has been good for nearly 10 years. My charger for it blew the non replaceable fuse because of a power spike & I email them. They got back to me right away and said if the booster pak was plugged in at the time this wouldn't have happened. so remove the charger from the wall if not in use. They also recommended you keep it plugged in the the booster all the time but we never have and it holds a good enough charge to boost for mons.
/ Battery Booster Pack? #14
Truck Pac.
The mechanics at work have been using one for years. You get what you pay for. Truck Pac does have 12V only units that are a little cheaper.
View attachment 479710 View attachment 479711
https://www.amazon.com - Truck PAC ES1224 3000/1500 Peak Amp 12/24V Jump Starter
12/24 volt operation
12 Volt - 3000 peak amps/750 cranking amps, 24V - 1500 peak amps/375 cranking amperes
60" #2 gauge cables
Industrial grade, Hot Jaw clamps
Have that same pack that I rebuilt, but it has an inverter bolted to the back also, so it is only good for 12v jumping.
David
Well, nobody & I mean nobody around here sells Clore stuff and after walking in/out of five places I finally got a Stanley jump pack on sale & added another year warranty for three bucks. Not quite what I wanted but needed it faster than I could get anything shipped so I'll try it out & if not right will order a Clore next and move on. Thanks for the input.
/ Battery Booster Pack? #16
Good luck with the Stanley and the extended warranty may be a good investment. In your original post you asked if anyone knew of a jump pac they could recommend. That is why I posted the Truck Pac. I had the same experience shopping for a good pac a year and a half ago. There were no Clore jump pacs available at any auto parts stores around here so my wife bought a Smart Start jump pac at O'reilly on sale for $89. The parts guy told her it was their best seller and no one ever brings them back. Well, It wasn't worth arguing about and the Smart Pac did start the riding mower most of a summer until I replaced the battery. It started my emergency generator and charge our cellphones, but when I tried to jump the 4.3L V6 in our dump runner pickup all it would do was turn on the lights. I plugged it in after every use or 3 months like the directions said. Then 3 days before the 1 year warranty expired I plugged it in and the charge light did not come on. Took it back to O'reilly, and to their credit, they replaced it with a new one which is a newer model with 3 charging lights. Will this pac last years or will it just make it till the warranty runs out I don't know yet.
/ Battery Booster Pack? #17
i have a jump n carry. i used at work, body work, jumping cars with crushed batteries, starting up to 8 dead cars when 10 degrees out, dealership cars, driven cars over 8 miles when the alternator quit charging and car died when applying brakes. jumped car, drove home on jump box and still started car when i got home and shut off.
i have replaced battery with agm battery same size and amp hour off ebay and still performs well. i bought mine in late 80s. best going. expensive but the best
/ Battery Booster Pack? #18
I have the JNC660 and it rocks
Agreed. I wanted a Clore but am hauling my tractor etc 800 miles to my hunting camp in three days and needed something quick. For $53 with a 2-year warranty this was my best shot right now. I'll give it a go and keep my eye on these better units.
/ Battery Booster Pack? #20
Looks like the biggest Stanley makes is "500 Instant Starting Amps/ 1000 PEAK Battery Amps." The Clore JNC660 is 1700 peak.
If someone is looking for a "right now" jump starter, most WalMarts stock a Schumaker 1200 peak unit for about $100. That would have been my choice if I had to get one locally.
