qed-cat225
Gold Member
trade it in for this one XR4
H << LS Tractor USA
I though my L3400 had a pretty generous amount of wheel spacing options on the rear.
Hub can be mounted dish in or out thats two options.
Rim can be mounted two different ways on the hub
And the tabs on the rims are offset, so you can swap sides and get two more options.
2x2x2 = 8 different ways to mount. I think as narrow as 50" or so....out to 63" or so wide.
I dont think there is a huge stability difference between brands, unless specifically purchasing a LCG machine.
How are you operating the tractor? If you have the front loader on, and nothing on the rear......or rear implement in use (like a blade or mower on the ground that dont add much weight to the rear).....I think that could be your issue. The kubotas are real light in the rear with a loader on and no ballast. That puts very little weight on the rear axle, and alot of weight on the front axle that is free to pivot and roll you over.
As others have suggested, loading the tires is a great place to start. Beet-juice...AKA rimguard is non-corrosive and heavy.
I had the tippy feeling at first with my L3901. Once I filled the Ag wheels which added over 500lbs to the tractor it is so much more solid and I have not moved the tires out. Hope to do that soon...
Adding weight certainly makes the tractor feel "more solid" and of course affects traction a lot. However, fluid in the tires has only a small % effect in lowering the c.g. ... In truth, what anyone wants in that regard is not an absolute tip over prevention but rather a better margin of comfort -- the substantiated feeling that you are operating a safer machine and in better control on the steepness of ground you have to work.
We have filled tires and cast weights or centers on two of our tractors, just can't get enough weigh by one or the other.
One is a Massey-Ferguson.![]()
I tried mightily not to, but failed.
Plotman- I too have a 2015 Kubota L3301, same wheelbase as your 3901. Do you have your rear tires watered (filled to 75% capacity)? I too have nearly tipped mine over with a fully loaded FEL. My salesman tells me I need more weight on the rear (ie box Blade or whatever you can hang on the rear hydraulic lift arms).
I too am very annoyed with the HST system being so noisy. I've got 68 hrs on my "K" and I can only notice a minute change in noise but not enough to really make a difference. Now, how long it will take to quiet down the HST Tranny, if it will quiet down) I don't know. Maybe some of the other owners can lend some information on this subject. My question is this, do the other manufacturers have the same problems with their HST systems?
Failing is not so bad. Whats that they always say.....Edison failed ~2000 times inventing the light bulb :laughing:
