Kubota Noise and Tippiness
/ Kubota Noise and Tippiness #1
Plotman
WI
Kubota L3901
I need some advice. I bought a new L3901 and am having a few regrets. We've almost tipped it 3 times on our land up north. Never had that issue with our Bobcat 235. Also very annoyed by the noise (hydrolic whining) when driving this unit compared to our old Bobcat. I know I can reverse our Ag tires to make it less tippy but I'm nervous driving it now. Debating on trying to do a swap with the dealer for a Massey with similar HP and bells and whistles. Would like to know the pros and cons of doing this. Thanks
Plot an
/ Kubota Noise and Tippiness #2
The tires can be adjusted out without reversing if they are like my 3301. The HST noise seems to calm down a bit after break in.
/ Kubota Noise and Tippiness #3
Welcome!
Are your tires filled? I would make sure the tires are filled and positioned as wide as possible.
For HST, I would make sure is has super udt2 fluid with new filters.
/ Kubota Noise and Tippiness #4
Set the tires to the widest setting, maybe even add spacers. Load them with fluid, even the fronts. Add any weights you can, as low as possible.
/ Kubota Noise and Tippiness #5
Noticed the slight "tipsiness" when going from my B2920 ( open tractor) to my new B2650 (with cab) . The dealer is looking into spacers for me and I also keep some weight on the three point al the time. If not an implement I will keep a ballast box attached. The other thing ?I have noticed is that the rubber bushings that cushion the cab to chassis mounting points have moe give than I would like giving the feeling of "tippyness" I going to tighten them down.
As for the HST noise, I had that in my B 2920 and it is more noticeable in the B2650 because of the cab. It should quiet down a little as the tractor brakes in as will the initial jerkiness starting to move forward or back as the transmission brakes in.
/ Kubota Noise and Tippiness #6
No real way handy to measure/compare the noise levels from the HST. I'd listen to others and just make sure it is within the norms and probably live with it.. Like most Kubota owners I have formed opinions long-term about them. They are such strong and reliable little beasts I am one who thinks "they have problems, just less than all the other brands." However, ... in the entire history of Kubota in the US they have never seemed to understand that our country is not really flat. Kubota is notorious above all other features for not being able to spread the rear wheels wide enough for use on steep ground. There are marginal exceptions on their newer larger machines (the M5 for example) where you can widen the tread but most are a lost cause. With the 3901 at least you do have SOME latitude for spreading the wheels. I would run them out to the max first and see if it is stable enough for your applications. I own both Massey and Kubota. If you find the Kubota is just too limited on wheel spacing, Massey is a good alternative. Most MF have lots of latitude for wheel spacing. Many people have added wheel spacers on various Kubotas. I just purchased a set of 6" spacers to give me a foot more spacing between rear wheels on my B2150. Just for supplemental pasture work in WV it was so uncomfortable in potential rollover I would not use it at all on steep ground until I add the spacers. Friends on the same terrain have added spacers to 2 of their Kubotas (an L3400 and a larger cab model M6040) needing/wanting better resistance to tipovers. Spacers are around $500 if you shop carefully and over $700 a set at the dealers. You better throw that $700 into the equation considering a deal for a Massey.
/ Kubota Noise and Tippiness #7
The same factors effect the "tippiness" of a tractor, who makes it is irrelevant. We widen the tires on all of our tractors and put fluid in the tires, even added spacers to the small ones. My HST was initially quite noise, but is fine now that it's broken in.
However, your money etc., so do what makes you feel best.
/ Kubota Noise and Tippiness #10
Sure, I understand you can work around characteristics of any brand to varying degrees. But who makes it is extremely relevant when the manufacturer fails to provide any degree of width adjustment for the rear wheels, namely Kubota. They are notorious in that regard. The make-do solution is wheel spacers that amount to a kludge to allow one to set the rear wheels further apart and cost hundreds of dollars. Yes, who makes it does matter in terms of the features on the tractor from the factory.
/ Kubota Noise and Tippiness #11
Still have to disagree, it is more about model and configuration than manufacturer. My Kubota L5740 and M8540 are full adjustable and very stable. I'm not brand blind as I've bought different brands and like and dislike some models in one or another brand. The last tractor I bought was a Deere and my brother's was a Kioti.
/ Kubota Noise and Tippiness #12
I had the tippy feeling at first with my L3901. Once I filled the Ag wheels which added over 500lbs to the tractor it is so much more solid and I have not moved the tires out. Hope to do that soon. Of course I should have done that before filling them. As for the whiny noise I don't really notice as I had an old 4 speed Ford tractor. I just really love having the HST for operating tractor. Hated the constant shifting while operating loader.
/ Kubota Noise and Tippiness #13
If you try the Massey and find the noise acceptable, and if the dealer will make the swap, I'd go for it. Hydros whine - high pressure oil and sharp edges. Can differ between different identical tractors, and will vary between manufacturers. The frequency can affect some worse than others. Tippiness is a matter of physics and others have made the usual recommendations. Do you have any idea why the Bobcat is less tippy? Lower CG, wider wheel tread?
/ Kubota Noise and Tippiness #14
Adding weight certainly makes the tractor feel "more solid" and of course affects traction a lot. However, fluid in the tires has only a small % effect in lowering the c.g. Yes it helps a little and any lowering of the c.g., even slightly, is good for anti-tipping. Getting those wheels further apart is by far the most effective means to make it harder to tip over. In truth, what anyone wants in that regard is not an absolute tip over prevention but rather a better margin of comfort -- the substantiated feeling that you are operating a safer machine and in better control on the steepness of ground you have to work.
/ Kubota Noise and Tippiness #15
Kubotas just need front end as well as rear wheel weights and then they are fine for all but severe slope applications. Yes, Many Deeres are heavier but some are not. I don't care for fluid filled rears because it rots the wheels and is non-forgiving if at some point you don't need the weight or need less of it. Cast is no problem to adjust.
For those who say things like washer fluid won't rust, I have posted pictures to show the rust. Plus it's a hassle to get rid of the fluid. As well, tractors with fluid filled tires usually sell for less at auction while those with cast weights sell for more. Weights usually resell for nearly or the same as what you paid for them.
I will admit that filled tires feel a little better than cast weights and I don't want to pay that price but that's just my personal opinion. And, like other opinions, everyone has one. Cast iron weights are your friend. Just my two cents here so relax if you like fluid.
/ Kubota Noise and Tippiness #16
six dogs is right: fluid will eventually rust through steel wheels. Our 1954 MH Pacer wheels rusted through in the 1990's, around 40 years. I agree to replace my wheels every 40 years but his point is well taken. I wonder if one can fluid fill tubes ? Good or bad idea ? By the way, it is a small factor but adding cast weights on the wheels does lower the c.g. too.
/ Kubota Noise and Tippiness #17
When I got my 6060 I thought it was really tippy. Over time I have learned that some of that was my fear of tipping. I now trust the tractor way more than I originally did and log on ground that I wouldn't have driven on before. How did I figure out where to be scared? By almost throwing it over. I've had to slam the loader to the ground several times to keep it on both back wheels. Prbly not the best way to learn, but it is an effective teaching point.
I filled my tires and it feels way more stable. As far as rusting out, use Rimguard. Not plugging them, but its non corrosive and ph neutral. The prime reason I used it was that if I puncture a tire I don't have a toxic dead space from sodium chloride.
Bottom line is that tractors this size and category are all going to have about the same CG, **** you physics!. Nature of the beast. If you want to feel rock solid on the ground, and your not doing ground implements, maybe the bobcats the right tool for you.
/ Kubota Noise and Tippiness #18
put tubes in them.
My 1952 Ferguson had the original wheels when I got it over 25 years ago. I used it until last year when I gave it to my son. Before he got it I replaced the well worn out and tubed, cracked calcium filled tires. There was nothing more that a few spots of surface rust on the inside of the rims, no more than I would expect if they weren't calcium filled. Sixty four years old and still going strong.
/ Kubota Noise and Tippiness #19
I though my L3400 had a pretty generous amount of wheel spacing options on the rear.
Hub can be mounted dish in or out thats two options.
Rim can be mounted two different ways on the hub
And the tabs on the rims are offset, so you can swap sides and get two more options.
2x2x2 = 8 different ways to mount. I think as narrow as 50" or so....out to 63" or so wide.
I dont think there is a huge stability difference between brands, unless specifically purchasing a LCG machine.
How are you operating the tractor? If you have the front loader on, and nothing on the rear......or rear implement in use (like a blade or mower on the ground that dont add much weight to the rear).....I think that could be your issue. The kubotas are real light in the rear with a loader on and no ballast. That puts very little weight on the rear axle, and alot of weight on the front axle that is free to pivot and roll you over.
As others have suggested, loading the tires is a great place to start. Beet-juice...AKA rimguard is non-corrosive and heavy.
/ Kubota Noise and Tippiness #20
put tubes in them.
All of the rusted wheels I have seen that were filled were tubed. I've seen maybe 8 to ten sets and every one was rotten rusty when dissembled even though they looked fine outside. I've seen both calcium and washer fluid filled. I've never seen beet juice but the tire guy says he saw one tubeless and it looked like the wheel was sandblasted.
This is why I believe in cast weights. It just doesn't work--for me--for the reasons stated. Even if they didn't rust, the all or none nature of the weight doesn't work for ag or utility purposes. if I lived on the slopes in West Virginia I would probably feel different.
Your Ferguson was a rare bird to have calcium that long and not rust. Great tractor too.
Here's where you can buy knock-off weights.
Wheel Weights - Lonestar Weights
1987 INGERSOLL RAND PT-125R PNEUMATIC ROLLER (A62129)
1987 INGERSOLL...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2019 CATERPILLAR 272D3 SKID STEER (A62129)
2019 CATERPILLAR...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A61567)
2002 Bobcat 863...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
