Looking to Downsize
/ Looking to Downsize #1
redlevel
Gold Member
100 miles south of Atlanta
Kubota MX 4800
I have been operating farm tractors for about 57 years.
I started on Ford N series and 600s, graduated to MF 135s and 175s, Ford 3910/3930, then various Ford, New Holland, and MF 100hp+ tractors. I figure I have at least 25,000+ hours in a tractor seat.
I currently have a JD 5105. It is a good, reliable tractor, but I'm thinking of downsizing, and moving into the 21st century, so to speak.
I have about 15 acres of pasture to mow, occasionally disc, and maybe pull a drill over. I have about 65 acres of planted pines that I sometimes need to do maintanence on, such as pushing fallen trees, mowing briars, plowing or harrowing fire breaks, etc. Not every day, nor even every week, but maybe a dozen or so times per year. I won't be doing serious farming, but pretty serious gardening-about an acre every year.
I'm thinking of stepping down to something in the 30hp range with HST. Say, something equivelant to a Kubota 3301.
My questions: will such a tractor do the things I need to do? Will I be satisfied with a compact tractor after all these years using "real tractors?" Will I have trouble transitioning to the HST transmission? Can I plow my one acre garden with a breaking plow or a subsoiler? I'm used to a tractor being a tough machine that can take some hard use, maybe even a little abuse, every now and then. Will the compacts do that?
At my age (67) I want something reliable, something with a good warranty, and a good dealer support. I want something a little smaller than the 5105 JD, and with a few more amenities, especially the HST. In short, if it proves satisfactory, this might be my last tractor purchase.
I'm liking the the 0 down, 0 percent financing from some of the manufacturers, too.
What do you think?
/ Looking to Downsize #2
What you will miss, downsizing to a Kubota L3301, is weight.
Consider, instead, one of the Kubota "Grand L" models. I have the smallest in the series, an L3560. It is slightly larger than the L3301 but much heavier. The extra weight is thicker steel. The HST+ transmission on the Grand L models is a huge improvement over the three speed HST transmission on all other tractor brands and models. Pinned stabilizers and telescoping Lower Links make mounting heavy implements relatively easy.
I am age 69. I know where you are coming from. Factor in all the options. Factor in our age. Grand L the best way to (compact) tractor.
TBN ARCHIVE "Kubota Grand L": Google
KUBOTA WEB SITE: http://www.kubota.com/product/LSeries/L60.aspx
/ Looking to Downsize #3
I pretty much agree with Jeff, I'm the same age and grew up on the older tractors and find any of the standard L Series too light for me and often lacking in some things I really like such as independent PTO, extendable lower link ends, adjustable stabilizer bars, flat, roomy operators platform, tilt steering and servo controlled HST pedals, adjustable wheel width, probably missed a couple.
In Kubota that is often going to mean a GL which means a lot more $$$$$$$$. You can get these in more economical Kioti, LS etc. models, so you will probably want to shop features over brand.
/ Looking to Downsize #5
I don't think you would be happy with a 30 hp. hst tractor. A suggestion would be a large compact such as the Kubota L6060 or Deere 4066R in new models. Slightly used Kubota L5740 or Deere 4520 and 4720 would be good too. These would be close in weight to the 5105 with but with better handling and easy to operate. Your existing attachments could be used in most cases.
I would also recommend a cab model as it will allow you to get more time in the seat as you age. There are a lot of us that are over 60 and as we age the wind, rain, dust and temperatures can cause us to lose a day in the seat. A cab tractor helps with these issues. I would rather spend a day in my tractor seat in comfort vs. a day at home in a chair in comfort.
I think you will find that an hst tractor will be much easier to operate than a gear tractor ever was. The hst+ and the ehydro transmissions make it super easy to make speed and direction changes, stopping and starting, creeping forward and back. This will be an easy change for you to adapt to.
Y'all are about to convince me to keep what I have; a good, reliable tractor with only 1150 hours.
Best thing about it is that it is paid for. :)
I have gone through this phase before. Each time, I look at the compacts and decide I just wouldn't be pleased.
Last time, even my wife said, "You better keep your tractor. You don't want a toy like that."
/ Looking to Downsize #7
Never a bad idea, I've only gotten rid of two tractors in my life and replaced them with essentially newer models of the same size, weight, power etc. I buy new tractors to fill a need, but keep my older ones.
Many years ago, against my advice, my father in law traded his open station tractor in for a cab. Less than a month later, he bought his old tractor from the dealer at a significant loss as he found no one tractor could do it all satisfactorily.
/ Looking to Downsize #8
I would not be in a hurry to trade either and if I did buy a small cut I would keep the larger tractor. If you were to trade across instead of down sizing that might work but more money for sure.
My x749 works great for the small tight quarters work in most jobs. It has 4x4 and 4 wheel steer, hydro and diesel. With the small three point hitch and 540 rear and mid pto it can handle small jobs around the house and lawns. The 110tlb and 4520 can handle jobs on small acreage with out problems but would be challenged for large acreage with heavy ground engagement. I may buy a larger field tractor (used) but would keep what I have that is paid for. I find trading up or down to be expensive so it is important to choose once and keep for many years.
/ Looking to Downsize #9
I am 10 years younger than you but your experience is somewhat similar to mine. I doubt that I have that many total hours experience on tractors but it is probably more than I want to think about. That's what happens when your father farms and sells tractors for a living.
I had used large farm tractors all my life like you but mostly in the 50-80 HP range. Once I came back home I bought a small YM1700 Yanmar and ran it for 14 years basically pulling a 5' rear finish mower. Upgraded to a nice used New Holland 1720 and added an FEL. Used it for 10 years mostly pulling a rear finish mower but did utilize the FEL quite a bit. Finally bought my first new tractor, a New Holland Workmaster 50.
I mow with it and use the FEL for the same things as before just more capacity. I looked long and hard at Kubota but opted for the shuttle shift over a hydro plus the Workmaster uses an EGR and catalytic converter in lieu of DPF.
If you want a hydro the L's are very nice and may fit your needs. If I was looking at a hydro machine it would be the MX or M. I don't know how happy you will be with a smaller tractor.
/ Looking to Downsize #10
If your 5105 is tier III I would for sure keep it. That said I have 4 Kubota's and the one that gets the most use is the Grand L 3540 with the glide shift. I've got the Patt's hooks on the links and so easy to change implements. Runs smooth and just easy to get on and get it done. Great in tight spaces. I'm 55 but I feel 75 so I hear you about the get something easy to use.
/ Looking to Downsize #11
The John Deere 3 series might fit the bill for you.
/ Looking to Downsize #12
Take a look at the Mahindra if you have a dealer close by. I was looking at the 3301 and 3901 Kabota before I bought my Mahindra. It was less cost and more weight and power too.
/ Looking to Downsize #13
If it is working don't try and fix it....
I am always disappointed with my sub-compact when it comes to trying to put the power to the ground. Like you a lot of time running old iron and this new stuff just isn't the same. HST is nice but unless you are doing a lot of speed and direction changes certainly not needed.
/ Looking to Downsize #14
I agree that 30 HP will be too small, especially coming from the larger tractors you're used to. I'd recommend checking out a Massey 1749, 1754, 1758. Feature packed, highest quality, excellent warranty, reasonably priced.
Since your main uses will still be mainly "farm" chores, you can go with their PowerShuttle option... And if you want HST (I'd prefer HST) I find that the HST pedal position on the Massey is more comfortable for me than Kubota's "rocker" pedal. (Individual user preference).
Best of luck
2021 John Deere S790 S Combine (A63111)
2021 John Deere...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
Tennant 7400 Compact Industrial Floor Scrubber (A61572)
Tennant 7400...
FORD 5 BOTTOM SIMI MOUNT BOTTOM PLOW (A63291)
FORD 5 BOTTOM SIMI...
2018 Chevy Traverse 3rd Row Seating (A63689)
2018 Chevy...
23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
23ft. Zodiac...
