vacuum for rear discharge
/ vacuum for rear discharge #1
sacarmic
Member
Deere 5085e, 3320
Hi, I have a Deere 1565 mower with a rear discharge I really love. The problem is I can't get a vacuum for it because everything works off a side discharge collector. Does anyone know of a vacumm or attachment for one that works on a pull behind that just sucks up the grass? Several companies make walk behinds that do just that, but my yard it too big for that. There are a few companies that make commercial units but $10k plus is out of my price range.
Thanks
Scott
/ vacuum for rear discharge #2
There are none that I know of that are not over the 10,000. dollar range.
/ vacuum for rear discharge #3
Why don't you modify a residential side discharge, It would have to be one with it's own power (engine). You would have to modify the attaching part and duct to clear for lifting the deck, but I think it could be done.
Yeah, that is my next step if a can't find one. There are several fabrication places around that could probably do it with enough time.
/ vacuum for rear discharge #6
If your still serious about doing this invest in the large Cyclone Rake model and have a sheet metal or welding shop fabricate a wide but narrow width nozzle that is connected to the impeller fans suction hose and have them build you a bracket to hang on the rear of the tractor to suck up the clippings as you mow.
/ vacuum for rear discharge #7
Maybe like leonz suggests, and then test it out to see if it works. ;)
OK, thanks for the advice everyone!
2022 EZ-GO ELITE...
Gannon 12in. Bucket with Teeth Excavator Attachment (A64194)
Gannon 12in...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
2R ROTARY HOE, 3PT (A64278)
2R ROTARY HOE, 3PT...
2003 Freightliner FS65 Thomas School Bus (A64194)
2003 Freightliner...
