Considering 3 pt tiller
/ Considering 3 pt tiller #1
AJ197816134
Jamestown, PA
soon to be
While we don't have a large space we have enough and in the future I want to reclaim some overgrown spots!
Ordered a LS XR4145HC
Looking at a 72 inch tiller with width of tractor! Think 60 is too small
I will be trying to supplement the ground over next few seasons to bring up soil to par!
Here are my questions
King kutter? Vs Everything attachments or other brands.
Gear drive seems logical but is there benefits of gear vs chain
What options on reverse rotation? Pro vs cons
I plan to not only till the broken ground but till in straw, compost etc!
/ Considering 3 pt tiller #2
What is that tractors PTO hp? If your going to try to enrich the soil I would get the forward rotation as it tills in cover crops better. In fact I think reverse rotation is kinda a fad. No difference in gear or chain drive here. Both have worked great for years and years without any issues on our Rotomec, john deere 660 <chain> and our Kuhn el 62 210<gear>. The Kuhn is my best attachment. Great machine.
Having a tiller wide as your tires is not really needed. I know many disagree with that. But you can still till by lapping your previous till strip. You just leave tire tracks, ugly but so what? By the time you track it up and plant the seeds its going to lose that smooth frosting look anyhow. If you can offset it a bit you can take out one tire track and that's enough to leave the garden tilled "pretty". What you need to avoid is getting too wide of tiller so that you have to till shallow to avoid lugging your tractor. I like to till deep and get that layer of topsoil ten inches thick. I add lots of hay/straw/fall leaves to my garden and its just great soil now compared to what it was ten years ago. I cover crop also, buckwheat and rye grass.
Thank you for the reply! It looks around 36hp at the PTO
I lose more because of hydro almost went to 50 at engine
You are describing EXACTLY what we want to do till deep mix well amend the soil that needs it.
I would love to get 10 inches of great soil!
So with 36 at the PTO a 5 foot might suit me just fine?
I'm all ears and eyes here
/ Considering 3 pt tiller #4
I would still go at least as wide as the tracks. You never know what future plans hold. Sometimes, to smooth areas, I like to till shallow, like 2-3" and leave it be. If you aren't covering your tracks.....you aren't gonna be left with a smooth and result.
I agree that forward rotation mixes in things like straw better. But in certain cases, reverse rotation. Does have advantages....not just a fad.
/ Considering 3 pt tiller #5
Reverse rotation tillers require much more PTO power than forward rotation tillers because reverse rotation tines are resisting forward motion of the tractor.
/ Considering 3 pt tiller #6
Some models of tillers can be off set to cover one tire track, if they aren't wide enough to cover both.
On a "quality built" tiller, there's no advantage of side gear drive over a side chain drive. In fact, I prefer chain drive. All three of my tillers are chain drive and one of them is in it's second THOUSAND of acres of tillage, on the ORIGIONAL chain and sprockets!
It's all about buying a quality tiller in the first place, instead of a lower quality, tinker toy tiller. lol
SR
/ Considering 3 pt tiller #7
+1 on NOT worrying that you'll leave tracks with a 60" tiller ... unless all work thence will be done by drones ... :D
Don't think of chain drive tillers as inferior!! Gears can be a bear if something goes wrong, work best in matched sets, and each gear has a shaft that may bend if you stall and can compromise mesh. Chains and sprockets are easily replaced/aligned and lube level is far less critical. Their utter simplicity and ease of service are their best points. One might imagine that a chain could be another safety 'fuse' if you jam up on a rock. (got pto clutch, or shear pin anyway)
MY 60" KK has been trouble free, works nearly 8" down if the 'feet' are set for 'deepest' but I worry about gears and their lube level every time I hook up ... and when I split fist-sized granite rocks working up a new garden on a lawn.
IMO 5 PTO hp/ft of width is a bare minimum if much ground-breaking is planned. That said, it's torque that does the work and my setup (w/the NH T 1520) delivers at ~80% of 540 PTO rpm with a lot less shake & vibration. 'Reserve power' is rarely power 'wasted'. ;)
Great replies so far,
I was just torn going 60 or 72 and wanting to get max depth as the ground could use it. The problem I have is the BCS walk behind in have is great but when trying to till in straw and compost it bunches us! Granted it tills like a a bat out of h"@$. But frustrating I cannot get the mix! I figure the tiller will be great for reclaiming some ground eventually as well!
I like King kutter
Seen the everything attachments
Kuhn just browsed on the web
I am debating new or used some of the used stuff ya get lucky and the others I spend time having to bring back up to spec
/ Considering 3 pt tiller #9
Hey AJ.......check your email I gave you some more info there. Hydros make good tilling tractors as it's easy to slow up if you start to lug the engine.
/ Considering 3 pt tiller #10
<snip>
Good luck buying used. It took me about 3 years to pick up a 60" KK off Craigslist. I frequent government auctions, online auctions, Craigs List etc. and the ones that turned up were almost always beaten up badly. FINALLY just before I bought a new one (but just after I bought a new plow) a barely used one turned up for about half the price of new.
/ Considering 3 pt tiller #11
I recommend covering your tracks too. I have a KK 84" that I use on my DX55. That's about a foot wider than my tracks. I think I probably have around 45 HP out back. I have heavy, hard, compacted soil, but I have never come close to lugging the tractor. On untilled ground, the limiting factor is the weight of the tiller and the depth it can cut on a first pass. A hydro tractor could go slower than my geared one, so that would help. After that, I can bury the tiller but it does not work the tractor at all. In fact, I could till in mid to low RPMs but the tine speed is too slow so I bump up the RPMs. As a comparison, a 2 bottom plow gives this tractor all it can handle in the same soil.
/ Considering 3 pt tiller #12
Check out the Ansung Terra Force models. You can run a YJR 074 (74" gear driven) with your tractor as I am doing it with much less HP (26.5). The unit is built like a tank. Had mine 4 years now with no issues. Local AGG dealer runs them in his rental department as they seem to be indestructible. Some advertisers here carry them.
/ Considering 3 pt tiller #13
I can sell your a 6 Ft Tarter Geardrive roto tiller that can be operated in forward or reverse rotation mode for $1980 delivered to Pa. Link below. Ken Sweet
New Forward or Reverse Rotation Geardrive Tarter 6 ft Roto Tiller We SHIP Cheap | eBay
Great information so far!
I intend to use this implement in many capacities
Keep the info coming I am reading and researching
/ Considering 3 pt tiller #15
Just a thought - many places run deep sales starting in October, so keep your eyes open. Also check around for any agg rental places. My YJR 074 was in service a year, had been used 4 times and was 1/2 price to new. Happy hunting
/ Considering 3 pt tiller #16
Go with the 72". I have a 60" KK on a 28hp tractor, and have never had it bog down. You've got a lot more power, so you'll have no issue with the 72" tiller. It takes me longer to hook up the tiller and turn the tractor around that it does to till the garden. One of the best purchases I made. I got mine on CL for $900, been used once, was too big for the purchasers Ford 8N.
/ Considering 3 pt tiller #17
Tillers do not work well on 8Ns in my area because you do not have a low enough gear. Tiller will just push the tractor. This is a reason to by a reverse tiller. Even then I do not have knowledge if it would work.
/ Considering 3 pt tiller #18
^^ yep.
I converted my 54" yanmar to reverse rotation just so it could be used with dad's 8n. It worked fine with my Kubota l3400 at the time, which had a low gear of 0.9mph.
The 8n at 3 mph was just too fast. Trying to til with it, it almost looked like the pto was off, and the rotor/tines were only turning as a result of rolling across the ground
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
2022 John Deere 5055E (A64126)
2022 John Deere...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
2015 JET 42' ALUMINUM HOPPER BOTTOM TRL (A64277)
2015 JET 42'...
2008 New Holland T2420 (A62177)
2008 New Holland...
