Tiller 3 Point Rototiller ID Help
/ 3 Point Rototiller ID Help #1
hoehj
Michigan
John Deere 790
I picked up an old 3 point rototiller a while back and have not been able to identify the make. Of course, I was not smart enough to take pictures of it before I started tearing it down to "refurbish" it, so I don't have any pictures of the entire unit handy. Here is a short list of facts I do know:
1. It appears that it was originally orange in color
2. It has a Comer gearbox, made in Italy
3. Chain drive
4. 55" working width
5. 4 tines per flange, 7 flanges
6. the back gate is positioned by a curved bar instead of a chain
Besides the gearbox, noted above, there are no readable markings on the unit. Below are 2 pictures of what remained of 2 decals:
I'm hoping somebody recognizes the decal remnants if nothing else...
Thanks in advance for any help you can offer.
Josh
/ 3 Point Rototiller ID Help #2
Think it's a Muratori? They are still in business, if it is.
/ 3 Point Rototiller ID Help #3
I think the decal says "rotovator". Think Howard brands their tillers like that. Rotovator is an alternate name for rototiller though I think so it might be more generic.
/ 3 Point Rototiller ID Help #4
Why not take some pictures of the rest? I can see anything looking at a flat orange plate
Well, mainly because it's partially disassembled at the moment. Here are a few others showing more:
I agree that the decal likely says VATOR, but it doesn't appear to be an O in front of the V.
Any other ideas? I checked out everything I could find on Muratori, but that doesn't seem to fit. I really need to get some tines for this thing, but that's proving to be quite difficult without at least knowing the brand.
/ 3 Point Rototiller ID Help #7
Regardless of manufacturer, the tines may well not be specific to that make. Take a look around online at tines, generically. You might find that they fit. Often, it doesn't make sense for smallish manufacturers to have everything be a proprietary design, instead opting for off the shelf components. I know this is the case with disc blades, and plow moldboards. It may be the case with tiller tines too.
I appreciate the advice. I have actually been doing just that and have accumulated a handful of various tines that don't fit. I found a website, Tillermaxx, that seems to have a lot of dimensions listed for different tines. I've found some that are close, and may try, but it seems none are exactly the same. I don't mind modifying a little here and there, so that's likely the route I'll go.
/ 3 Point Rototiller ID Help #9
I'm voting for Muratori, based on color and style of chaindrive cover. I had good success getting documentation for Muratori MA125, try contacting:
Anna Zirondelli, Ufficio Commerciale/Sales Department
MURATORI S.P.A.
PO. BOX 45
Via Pavarello 21- 21/ABC
I - 41051 Castelnuovo Rangone (Mo)
ITALY
Direct Ph.: ++390595330601
Fax: ++39059537259
E-mail info@muratoriequip.it
and US distributor:
Cody Brown, Garton Tractor, Inc.
Parts-Turlock
(209)632-3931 Work
(209)872-6337 Cell
cbrown@gartontractor.com
/ 3 Point Rototiller ID Help #10
MURATORI S.P.A.
PO. BOX 45
ITALY
Fax: ++39059537259
and US distributor:
Parts-Turlock
(209)632-3931 Work
(209)872-6337 Cell
I'm guessing it was put to rest over 5 years ago when this thread was last active.
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
2015 PETERBILT 389 (A67714)
2015 PETERBILT 389...
Worksaver 3pt 5' Sweeper (A64911)
Worksaver 3pt 5'...
2025 Future FT-D680 (A64912)
2025 Future...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
PORTA POTTY (A67714)
