Tiller 3 Point Rototiller ID Help
   / 3 Point Rototiller ID Help #1
hoehj
Michigan
John Deere 790
I picked up an old 3 point rototiller a while back and have not been able to identify the make. Of course, I was not smart enough to take pictures of it before I started tearing it down to "refurbish" it, so I don't have any pictures of the entire unit handy. Here is a short list of facts I do know:
1. It appears that it was originally orange in color
2. It has a Comer gearbox, made in Italy
3. Chain drive
4. 55" working width
5. 4 tines per flange, 7 flanges
6. the back gate is positioned by a curved bar instead of a chain
Besides the gearbox, noted above, there are no readable markings on the unit. Below are 2 pictures of what remained of 2 decals:
I'm hoping somebody recognizes the decal remnants if nothing else...
Thanks in advance for any help you can offer.
Josh
   / 3 Point Rototiller ID Help #2
Think it's a Muratori? They are still in business, if it is.
   / 3 Point Rototiller ID Help #3
I think the decal says "rotovator". Think Howard brands their tillers like that. Rotovator is an alternate name for rototiller though I think so it might be more generic.
   / 3 Point Rototiller ID Help #4
Why not take some pictures of the rest? I can see anything looking at a flat orange plate
Well, mainly because it's partially disassembled at the moment. Here are a few others showing more:
I agree that the decal likely says VATOR, but it doesn't appear to be an O in front of the V.
Any other ideas? I checked out everything I could find on Muratori, but that doesn't seem to fit. I really need to get some tines for this thing, but that's proving to be quite difficult without at least knowing the brand.
   / 3 Point Rototiller ID Help #7
Regardless of manufacturer, the tines may well not be specific to that make. Take a look around online at tines, generically. You might find that they fit. Often, it doesn't make sense for smallish manufacturers to have everything be a proprietary design, instead opting for off the shelf components. I know this is the case with disc blades, and plow moldboards. It may be the case with tiller tines too.
I appreciate the advice. I have actually been doing just that and have accumulated a handful of various tines that don't fit. I found a website, Tillermaxx, that seems to have a lot of dimensions listed for different tines. I've found some that are close, and may try, but it seems none are exactly the same. I don't mind modifying a little here and there, so that's likely the route I'll go.
   / 3 Point Rototiller ID Help #9
I'm voting for Muratori, based on color and style of chaindrive cover. I had good success getting documentation for Muratori MA125, try contacting:
Anna Zirondelli, Ufficio Commerciale/Sales Department
MURATORI S.P.A.
PO. BOX 45
Via Pavarello 21- 21/ABC
I - 41051 Castelnuovo Rangone (Mo)
ITALY
Direct Ph.: ++390595330601
Fax: ++39059537259
E-mail info@muratoriequip.it
and US distributor:
Cody Brown, Garton Tractor, Inc.
Parts-Turlock
(209)632-3931 Work
(209)872-6337 Cell
cbrown@gartontractor.com
   / 3 Point Rototiller ID Help #10
MURATORI S.P.A.
PO. BOX 45
ITALY
Fax: ++39059537259
and US distributor:
Parts-Turlock
(209)632-3931 Work
(209)872-6337 Cell
I'm guessing it was put to rest over 5 years ago when this thread was last active.
New Holland TS 75 Front Loader Utility Tractor (A53421)
New Holland TS 75...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
Selco V5-HD Vertical Hydraulic Baler (A55851)
Selco V5-HD...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
