Does the MT180 have a thermostat?
/ Does the MT180 have a thermostat?
My machine has a sticker on the hood that reads Mitsubishi MT180HD.
It is two wheel drive.
I'm guessing H stands for hydro-static transmission....which it does indeed have
/ Does the MT180 have a thermostat? #12
Correct
I get my info from the factory manuals and have: owners, parts and shop manuals, but won't argue.
/ Does the MT180 have a thermostat? #13
I have manuals too. I am attaching a scan from my 470D manual that I hope will clear this up. I don't know why CooHead's decal has the D suffix unless it has been repainted and re-decaled. I will say that I don't think you will ever see a 180 (whether D or not) with anything other than a diesel engine.
/ Does the MT180 have a thermostat? #14
My MT210D was getting too hot right after I got it (230ish). I had the radiator cleaned at a shop, then I back flushed the block.
Then I popped out the freeze plug and found a huge amount of gunk that didn't come out previously. I put a block heater plug back in instead of a new freeze plug.
Today it sat right at the thermostat (190) while mowing in 95F weather. I really think taking the freeze plug out helped a lot.
BUUUMMMPPPP
Mine kept intermittently getting hot. Then I discovered that the upper hose had no pressure in it, ever.
Investigating further, the radiator cap wasn't "deep" enough to seal on the bottom of the neck, so there was no way for it to ever build pressure. I have yet to find the correct radiator cap, but a large o-ring seems to take up the gap and let it build pressure. It does build pressure now, and seems to stay cooler, though fall and cooler weather is here now, so it's hard to tell :rolleyes:
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2006 Formula 292 Boat with T/A Trailer (A59231)
2006 Formula 292...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2016 KOMATSU PC138USLC-10 EXCAVATOR (A62129)
2016 KOMATSU...
2023 TAKEUCHI TL8R2 SKID STEER (A62129)
2023 TAKEUCHI...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
