Trailer overhaul
/ Trailer overhaul #1
dzljon
Advertiser
Jacksonville florida
none
My brother in law broke 3 cross members so since it was getting taken apart I decided to give it a new coat of paint. I am using the majic tractor and implement paint from tractor supply. I started by knocking off the scale rust with a wireless brush on my grinder, applied rust preventative primer and matte black top coat
/ Trailer overhaul #2
Did you replace the 3 broke / bent cross members. Looking at pic 3 it looks like you primed before replacing them. BIL must have put quite a bit of weight on to bend them.
/ Trailer overhaul
Not yet the steel yard is closed I will have to get new materials this week
/ Trailer overhaul #4
What's a wireless brush?
Jim
/ Trailer overhaul #6
looking at the way that trailer is built it looks like the 20 footer I had it was and still is a great trailer, I wonder has any body ever used composite wood to replace the floor with.
/ Trailer overhaul
Composite is a really good idea:) if it fits correctly, now I am going to do some simple math
/ Trailer overhaul #8
Composite wood would never work. The span's are too long between supports. When using it on a deck, joists must be 12 inch on center instead of 16 inch on center. It Bowes if you don't.
/ Trailer overhaul #9
good point I did not know that.
/ Trailer overhaul #10
I am jealous of the OP. I need to take the deck boards off of my 20 year old Diamond C Clipper 16ft utility trailer, clean it up, prime & paint, and rewire it. It's only time and some money, and a nice shop to do it in, which I don't have.
/ Trailer overhaul
Thanks! Here is a look at the other project, 2000 jeep tj with a 4bt cummins
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
7ft Metal Texaco Pump (A65583)
7ft Metal Texaco...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
