Trailer overhaul
/ Trailer overhaul #1
dzljon
Advertiser
Jacksonville florida
none
My brother in law broke 3 cross members so since it was getting taken apart I decided to give it a new coat of paint. I am using the majic tractor and implement paint from tractor supply. I started by knocking off the scale rust with a wireless brush on my grinder, applied rust preventative primer and matte black top coat
/ Trailer overhaul #2
Did you replace the 3 broke / bent cross members. Looking at pic 3 it looks like you primed before replacing them. BIL must have put quite a bit of weight on to bend them.
/ Trailer overhaul
Not yet the steel yard is closed I will have to get new materials this week
/ Trailer overhaul #4
What's a wireless brush?
Jim
/ Trailer overhaul #6
looking at the way that trailer is built it looks like the 20 footer I had it was and still is a great trailer, I wonder has any body ever used composite wood to replace the floor with.
/ Trailer overhaul
Composite is a really good idea:) if it fits correctly, now I am going to do some simple math
/ Trailer overhaul #8
Composite wood would never work. The span's are too long between supports. When using it on a deck, joists must be 12 inch on center instead of 16 inch on center. It Bowes if you don't.
/ Trailer overhaul #9
good point I did not know that.
/ Trailer overhaul #10
I am jealous of the OP. I need to take the deck boards off of my 20 year old Diamond C Clipper 16ft utility trailer, clean it up, prime & paint, and rewire it. It's only time and some money, and a nice shop to do it in, which I don't have.
/ Trailer overhaul
Thanks! Here is a look at the other project, 2000 jeep tj with a 4bt cummins
3096 (A63117)
3096 (A63117)
2009 Ford E-350 Cargo Van (A64556)
2009 Ford E-350...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A67148)
2023 KENWORTH T680...
LOT OF METAL BEAMS (A64278)
LOT OF METAL BEAMS...
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
2003 40ft. Proclaim T/A Vacuum Tank Trailer (A64194)
2003 40ft...
