Order new air ride seat from Kubota today.
/ Order new air ride seat from Kubota today. #1
USCG1
Member
West Kentucky
L3560
Hated to spend the money, but what's nine hundred dollars more? Has anyone here replaced there seat with one from Kubota? If so how do you like it? Anyone want a Kubota suspension seat with less than 2 hours on it make me a offer.
/ Order new air ride seat from Kubota today. #2
Did you have to buy an air pump/compressor as well?
/ Order new air ride seat from Kubota today. #3
Maybe not a bad thing to spend money on. I hit a rut out on a rural back road road driving my Cushman mower and had hip pain for a couple of days.
Stupid question though. Wouldn't a good cushman provide at least some protection?
/ Order new air ride seat from Kubota today. #5
/ Order new air ride seat from Kubota today. #6
I believe Kubota uses seats made by Grammar. It cost me about $1100 to put one in my L5740 due to needed cutting, welding etc., but it was money well spent, it's a whole different tractor.
Congratulations, you are going to love it.
/ Order new air ride seat from Kubota today. #7
I've got one tractor with an air seat and one without. Huge difference. Worth the money.
rScotty
/ Order new air ride seat from Kubota today. #8
I like my Kubota (Grammer) seat...I'm glad I bought it! I have had four back surgeries with at least one more in my immediate future so felt that the seat was a necessity, not a luxury. The only downside (for me anyway) is that this seat doesn't tip up so that you can use the PTO while off of the tractor; I mentioned this in another thread. The reality is that it doesn't take that much weight to defeat the deadman switch but it still is a little upsetting that Kubota hasn't come up with a solution so that I don't have to use a log or cement block on the seat when I am off of the tractor.
/ Order new air ride seat from Kubota today. #9
I like my Kubota (Grammer) seat...I'm glad I bought it! The reality is that it doesn't take that much weight to defeat the deadman switch but it still is a little upsetting that Kubota hasn't come up with a solution so that I don't have to use a log or cement block on the seat when I am off of the tractor.
Maybe our JD310 has a Grammer-made seat; I don't know who JD sources them from. Maybe they make it in house. The downside is that the seat loses pressure in a few hours and needs some pumping up again. The compressor has to pump it up from full flat to full height when doing the first start each morning too. JD says, "they all do that". Well, maybe.....
Does the Kubota seat also need pumping up each morning?
Re the deadman switch, if you are going to wrestle with putting weight on the seat, why not just tape the wires together and bypass the switch altogether? Or put a toggle switch in parallel with the existing switch to defeat it whenever wished.
rScotty
/ Order new air ride seat from Kubota today. #10
Our Grammar has to be pumped up every three or four days, but I often adjust to different levels depending on what I'm doing and everyone who uses it likes a different setting, so it's hard to tell how long to a complete deflation.
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2020 FREIGHTLINER...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
PENDING SELLER CONFIRMATIONS (A59906)
PENDING SELLER...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
40' 6 Door Shipping Container (A60352)
40' 6 Door...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
