Is it time for a gasoline engine tractor?
/ Is it time for a gasoline engine tractor? #281
I like a motor with a lot of oomph.
Not sure which scale applies...;)
IH and other tractor manufacturers made a big deal of torque amplification, TA, thirty years or more ago.
How did that tech work, and is it now standard?
If one has a variable turbo, one could just dial up the amount of boost needed.
The question is what's the top limit set at.
I'm pretty sure there is a reverse relationship between amount of boost and longevity of the engine.
/ Is it time for a gasoline engine tractor? #282
if the hand throttle was actually maxing out the carb butterfly, with nothing to add, and she wasn't loosing rpms steadily, but instead, maintaining, and dipping in thick and recovering.. then I'd call that 100%
Well, I don't recall a carb on that diesel but I get your point. :thumbsup:
She'd pull down, wrestle through, and recover.
/ Is it time for a gasoline engine tractor? #283
what causes the increased black smoke at that very moment? Lot of fuel going in, just more exhaust pollutants?
Or is something else going on
/ Is it time for a gasoline engine tractor? #284
Black smoke is unburnt fuel going out the exhaust.
If you're black stackin then you're dumping more fuel into the cylinder than the motor can burn. Good for starting but you don't gain anything pulling. But you are making max power for the setup.
To get rid of the black smoke you must increase the amount of air in the cylinder either with larger Pistons or a turbo.
/ Is it time for a gasoline engine tractor? #285
The excess of fuel is used for cooling. It takes significant amount of heat to turn it ti super-heated gas.
2019 VOLVO VNL TANDEM AXLE SLEEPER (A59911)
2019 VOLVO VNL...
1062 (A63291)
1062 (A63291)
2015 Ford Escape Titanium AWD SUV (A61574)
2015 Ford Escape...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
