country UTV trailer review?
/ country UTV trailer review? #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
We purchased a 7740UTV-BR trailer from this CMI outfit in Ohio. We ended up bending and wearing out a few parts on it over its 1st summer of use and had to beef it up some. But after that, we found it was a pretty decent trailer for our needs. I looked for reviews or discussions concerning the 7500 trailer here and found none, or did I miss them? If anyone is interested in this trailer or its repairers, just let me know and I'll post photos. Thanks!
UTV Trailers Heavy Duty Tandem Axle Model 774UTV by Country ATV.
/ country UTV trailer review? #2
Jeez la wees, who doesn't like pictures of a fix it job, I'd love to see pics of the repairs you made. When I made my ATV tandem trailer, the tandem part was the hardest to make strong and not add a ton weight. I had to do it twice, but that kind of trailer is the best.
OK here goes. We got this trailer with a hydraulic lift accessory to help us move gravel and supplies to and from a remote work site. It had a pretty high load capacity which I'd now say is unrealistic. The tandem axle bearings (walking beam) was worn out after moving maybe 30 heavy loads 1/2 a mile. I know what you mean Oldpath! In the next post I'll show how we rebuilt that and re-enforced the frame some.
UTV trailer frame and walking beam rebuild
In support of the manufactures design, we were likely loading to its max at 2200lbs. We also had one operator who drove rather fast and the box frame got bent going over bumps which was made from 1/8" 1.5 x 1.5 angles. Then the walking beam axles were worn out as well, so they were rebuilt as seen in the top photo.. (frame is upside down) The 2nd photo is a chain we added when we realized the trailer would "dump" if not loaded properly or someone stood in its back. This chain keeps it from flipping up. In the "trailer frame" photo you can see we doubled its bent frame by adding another 1/8" 1.5 x 1.5 angles which make it into a square tube frame.
In the last photo you can see some of the many tie down loops we added. The "double tube" tongue was added because we sometime move 14ft decking which will not fit or balance on the trailer. This tongue design allows us to extend it when needed.
/ country UTV trailer review? #5
Nice bunch of photos, you showed what I wanted to see, and to be brutally honest in a friendly sort of way, that walking beam is a bad design. The square stock that connect both wheels is fine, it's just in the middle where it goes up to what looks like 8" to the pivot pin which in-turn is like an upside down T. With the walking beams like that it looses a lot of true walking beam movement and produces a lot more stress on the 1" pivot pins, know what I mean Vern, probably not, but over all the rest of trailer looks good.
On my trailer the the pivot/articulation is directly in the middle on the square stock that connects the wheels. My trailer is set up for hauling wood, but a dump body could be added if I had extra cash. I have a short vid with temp side boards on getting last years firewood in, trailer was made in 1997,
Rhino - YouTube
I'll agree with the bad design of the walking beam but for a different reason. Its bearings that were just 1/4" plate with 3/4 holes punched in them, were waaaaaay to small to hold up. The trailer just wasn't made for serious loads or mileages. I'd call it a 1800lb trailer in its original format including that its box frame was so light. With all the revamping we did, maybe its now a 2400lbs trailer.
I should add that the running low PSI in those big tires, was really was nice for moving these heavy loads on rough terrain.
/ country UTV trailer review? #7
"Its bearings that were just 1/4" plate with 3/4 holes" <<<<<<<<<<< You diffidently made that better putting a pipe in between the 1/4" plates with geese fittings, was you able to up the pin size to 1''? I agree 3/4" is kinda on the small side on 1/4 plates, but anyways great repair job!
Do you like the jacking system on the trailer and what UTV are you pulling it with? cant quite make it out.
What you see in these photos was a Rhino what was subsequently retired (sold) and replaced with a can-am HD10 defender. If you care, its reviews can be read here. http://www.tractorbynet.com/forums/atvs-utility-vehicles/355357-can-am-2016-defender-hd10.html
The jack lift worked OK. We wish it went a tad higher and we also broke it once but wasn't to hard to repair. The walking beam mount pin remained 3/4 in size but what's not visible in the photos is the 4 locking collars we welded to the beams channels to lock the pins in position. The short pipes you see which got welded in to create the bearings, are dram tubing. Yes lots of messing around but by the end, the trailer was made much stronger or more durable. Not being able to weight the loads, we could have been moving 2500lbs.
/ country UTV trailer review? #9
Good review and great pics. Thanks for sharing!
Glad to see someone was interested in this trailer. We'll need this trailer again soon, so maybe I'll grab a photo of it hauling the 22ft long 4x12" full dimension timbers we need to move.. If anyone else has a UTV or atv trailer, please post how you liked it.
/ country UTV trailer review? #11
Why was the Rhino sold, broke, wore out, and why replaced with a Can-Am UTV?
I have a 2012 Rhino, low miles so far, my biggest complaint is it goes to fast in low range, wish top speed in low was 5-10/hr.
I think your trailer is a lot better after you've fixed it....
We replace all our tow machines after 5 or 6 years of age. The Rhino was at that time plus was under powered for our use. The Rhino at 45hp while the Defender is at 72 was much better for our needs, yet we've still had it max out was well. That's with pods on, in snow and towing some implement, which will make a UTV grunt. Maybe I should add that it's repairs ran about $3000 over its last season.
/ country UTV trailer review? #13
Yes, get a picture, show me that thing freighted, love seeing equipment push to the limit instead of babied.
Read your review on your other post, well put and straight forward. So if you was buying another UTV tomorrow, any other brand you might choose there are probably over a dozen big ones to pick from, maybe there's atleast 3 top brands you'd like.
Here is some loads we moved on Friday. No idea what they weighed. In the 2nd photos those timbers were 22ft long 4x12" full dimensional lumber. Yes we grunted getting them on.... You can see the adjustable hitch was extended to its max.
This deluxe trailer made a few gravel runs this week. :thumbsup:
/ country UTV trailer review? #16
Nice! Looks like it is really working out for you.
/ country UTV trailer review? #17
Looks like ArlyA has put that one through the wringer! With the mods he made it should holdup very well. I bought one of Country 7740UTV trailers this spring for use on the farm and it has been excellent for farm work. We pull it with a older Bush Hog UTV. The trailer will handle more than the UTV is capable of pulling for sure.
Thanks Dave. If you are moving serous loads with yours, you may want to watch the walking beams angle. Ours went squat, (center down, looking from the back) as the beams bearings wore out.
/ country UTV trailer review? #19
Howdy..!!! I just ordered a trailer similar to yours, but has a 7' X 4' bed with metal sides [ 7740UTV-BR ]. I stumbled onto your rebuild, and will mod mine / paint it before I assemble it, My one question is why you added the brace on the side of the channel iron between the walking beam plate and the vertical angle the bed pivot on??? [ picture #1 of the frame upside down ] I do not plan on making mine tilt and will fix the bed in place. Basically going to use mine for firewood/out in the woods behind a tractor....
/ country UTV trailer review? #20
We have been using the crap out of this trailer now for about a year. Hauling water tanks, firewood and produce across 5 acres and it has held up to the task with no issues other than a slow leak in one tire last week. I ended up drilling a hole in the front of the bed and bolted the bed to the chassis as we rarely use it as a dump trailer. Hope your's holds up well as our's has JerryK.
NEW Wolverine 84" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 84"...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
