Torch info please
/ Torch info please #1
prichard
N. Georgia
B2601 FEL
Can anyone tell me anything about this torch setup?
uploadfromtaptalk1465429705827.jpguploadfromtaptalk1465429715051.jpguploadfromtaptalk1465429731885.jpg
/ Torch info please #2
Looks like a Victor Journeyman model. That is a very good cutting torch, I have the same model.
/ Torch info please #3
Victor is the local company known for quality and serviceability... I just had an old Victor medical regulator repaired... don't know much about the company today one way or the other.
My guess is that you have a 315 valve body with both a cutting torch attachment and various size welding tips.
You should be all set for gas welding and "Burning" steel.
I bought the same model when I became a certified welder in another life... also the smaller set and jeweler set too.
/ Torch info please
Thanks for the quick responses.
So what parts are what? Is the double barrel attachment the cutting torch? Are the angled tips for welding?
/ Torch info please #5
Yes... the attachment is for cutting steel... I've used mine to cut up car bodys and when I was building a trailer to rough cut steel.
The angled welding tips should be stamped with the size... like 00 or 1 etc.
I use to do body work so I used the small tips...
Are you thinking or taking up welding?
/ Torch info please #6
Hard to tell for sure if it's a medium duty or heavy duty torch. The HD is larger in size but it should have a model number on it. It's an older model without the built in flashback arrestors like the newer models but still a very good torch.
/ Torch info please
Thanks again.
My son inherited these. He or may use them. I recently purchased an everlast stick machine and was thinking about getting a cutting torch.
Should I be concerned about the lack of flash back protector?
/ Torch info please #8
You can add them if you like...
None of the victor welding torches had them in school.
/ Torch info please #11
Flashback is nothing more than a check valve.
I have them on my bigger torches and not on my small set I used for sheet metal.... found the pressure needed to overcome the flashback check valve spring would not let me get very small even flame.
2022 EZ-GO ELITE...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2019 CRUISE CAR INC ENCLOSED UTILITY CARGO CAR (A59912)
2019 CRUISE CAR...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
