Sharpening mower blades
/ Sharpening mower blades #21
I think it would be OK to sharpen on the deck a time or two, but the blades should be checked for balance and straightness eventually.
prs
/ Sharpening mower blades #22
None of the mowers I have seen give enough room to even consider sharpening in place.
And on my ZTR, its a whole lot easier to remove the blades than it is to remove the deck (or at least get it high enough to try to sharpen while leaving them on)
/ Sharpening mower blades #23
On the Ventrac mowers the deck will tilt up and lock in an upright position and there is enough clearance to use an angle grinder; at least on the contour and rough mowers I have, but I zip them off with an impact wrench and sharpen on the belt sander.
prs
/ Sharpening mower blades #24
AND that's ANOTHER reason I chose a Grasshopper mower!!
The "power lift deck" makes THAT maintenance job, easy!
SR
Murph,
Where you get that soft cab.
Mike
/ Sharpening mower blades #31
I would not like being in the open like that. How does the GH attach to it?
/ Sharpening mower blades #32
Grasshopper offers a cab, with heat...
Grasshopper has a 2 point, quick attach hitch, with a pto shaft to run the mower or any other attachments...
It works perfectly!
SR
/ Sharpening mower blades #33
It works perfectly!
SR
You have a pic of the QAH? Ventrac offers a Cab with heat but I'm not spending 5 k for it. As you see in my photo is my poor mans cab. I reverse the trans fan for some heat. Its better then being wide open to the mist the SB makes.
/ Sharpening mower blades #36
Last time I priced a GH cab, it was $2,500.00 with heat, lights, and a window wiper...
I don't need it, a snow suit and goggles works just fine and as long as you aren't blowing into the wind, the blower blows the snow quite a ways away...
Because it's a zero turn, you can wiggle right in close to car's, buildings ect... It works better than I thought it would.
SR
/ Sharpening mower blades #37
With the liquid cooled Kubota diesel a homemade heated cab would be an easy job.
/ Sharpening mower blades #38
The GH 725D does have a heated cab which is great for winter snow blowing but I leave mine on year round. I had an upholstery shop make the vinyl windows zippered, added nylon mesh screens to keep the bugs and added a small cooling fan like those in a truck or RV to provide ventilation in summer. A rear view camera, a holder for smart phone, passive noise reduction headset and ear buds complete the set up.
/ Sharpening mower blades #39
My blower is not a 0 turn but a regular CUT.
I simply take the door off in the summer and have 2ea 4" computer type 12 volt fans that blow air on me. They put out enough CFM's to also keep the insects from coming in to bite me.
New/Unused AGT Industrial SDA-140T Track Loader (A65583)
New/Unused AGT...
2021 Bobcat T76 (A64126)
2021 Bobcat T76...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A61573)
2023 26ft Freedom...
(1) UNUSED 26X12.00-16 TIRE W/ 5 LUG RIM (A64280)
(1) UNUSED...
2018 Colombo Twin Master (A64119)
2018 Colombo Twin...
