Buying Advice Toolcat F or G
/ Toolcat F or G #1
jturbo68
Georgetown, KY
TC-35D
Hi Everyone, new around here.
Im starting to look for a Toolcat 5600 or 5610 either an F or G series.
Asi I understand from these forums, the G has better traction with the traction control option.
Is this available on the F series?
As I understand, the G series began production at the start of 2014. Correct?
What was the first year of the F series?
Lastly, is anyone running their toolcats on biodiesel? Trying to figure out if the F or G will work on Bio, or mabe if a D series would work.
Does the F or G series need DEF Fluid?
Thanks
John
/ Toolcat F or G #2
Bio diesel :alert: Bobcat only allows up to 5% . No DEF on any of those models. G series has the new Doosan engine. :thumbsup:
/ Toolcat F or G
Thanks, I understand the manufacturers position. Most of my current equipment TC-35, RTV900 an so on have been running on biodiesel for years without issue despite non-approval.
I was curious if anyone out there was successful with bio in the Toolcats even though unsupported.
/ Toolcat F or G #4
I've heard no issues with the bio fuel or seen any service bullitins. :confused3: Your are talking about "BIO fuel" yes? Not french fry oil. That will destroy your engine. :eek:
/ Toolcat F or G
Good Info, thanks.
Yes, I mean Biodiesel, not Waste Veg oil.
/ Toolcat F or G #6
Is this available on the F series? Limited Slip was an option.
Thanks
John
Looks like the F series started in 2007: Bobcat Historical Specs - Bobcat Company
/ Toolcat F or G
Thanks Xfaxman, I have enjoyed your F series Pics throughout the forums. Thanks!
Based on my poking around, it seemed like the Limited Slip was different than the traction control option. Looking thru listings, I have seen F series with Traction Control
listed as an option. Based on that, it seems like there were options to purchase an F series with Traction Control.
I had seen the Historical listing on Bobcats site, showing the F series in 2007. I am wondering if this is erroneous as The forums seem to announce the 5610 first in 2008 as a D
series. Also, I think that I have seen references to the 5600 D series announced in mid 2007.
Thanks for the help.
/ Toolcat F or G #8
I took delivery of my 2009 D series in Nov. 2008. I'm pretty sure the D series became available in 2007.
DEWFPO
/ Toolcat F or G
Hi Guys,
Im still looking around at used toolcats, thanks for the help.
Question. Is there a way to adjust GPM flow on toolcats with hi-flow hydraulics?
When I get a machine, id like to be able to get a hi-flow model, but still be able to operate lower flow attachments. Is there a way to
run the machine in low flow or hi flow mode, or manually adjust the flow based on some sort of Hydraulic profile?
/ Toolcat F or G #10
Hi Guys,
Our F Series runs in low flow until you push the rocker switch to turn on hi-flow.
You increase or decrease the RPM to get the needed flow in either mode.
/ Toolcat F or G #11
My 2009 D series operates in Low-Flow mode until you hook up a High-Flow attachment or push the High-Flow switch. If it's a Bobcat High-Flow attachment the need is automatically sensed by the Toolcat and it goes into Hi-FLow mode on it's own.
DEWFPO
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64277)
KNOW BEFORE YOU...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
Frontier 6' 3Pt Mower (A66408)
Frontier 6' 3Pt...
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
10' Rotary Hoe (A64126)
10' Rotary Hoe...
