What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #81
After that, it's open season so I'll be looking for ideas since I now have the solution. :)
Here is an idea to keep in mind.
Picking up a cedar tree long ways, with the forks.
I put the forks in the limbs, the bottom of the frame on top of the trunk and curled back.
   / What else do you do with forks besides lift pallets? #82
Doing suspension work.
Even better are two.
   / What else do you do with forks besides lift pallets? #83
My forks are made of 1 1/2" round stock (actually old truck axles). A lot of my "stuff" has sections of 2" square stock welded in strategic spots so I can just run the forks in and carry it around, such as my 9' long wood splitter.
xfaxman--The more I look at your Bobcat, the more I admire it and wish I had a reason to get one.
   / What else do you do with forks besides lift pallets? #85
Well I didn't have any reason to keep my tractor after I got my first Bobcat compact telehandler, so sell one of your tractors and get one.
People think of telehandlers as big machines, I need to figure out a way to take some pictures that show how small it is. Maybe could park it next to my truck.
EDIT 8-10-2021:
   / What else do you do with forks besides lift pallets? #86
Well I didn't have any reason to keep my tractor after I got my first Bobcat compact telehandler, so sell one of your tractors and get one. People think of telehandlers as big machines, I need to figure out a way to take some pictures that show how small it is. Maybe could park it next to my truck.
I have seen a V417 on the back of a semi and a different brand compact telehandler at the local rental yard. They aren't nearly as big as I expected. The full size ones on the other hand are huge.
   / What else do you do with forks besides lift pallets? #87
That sounds like a PITA to line the forks up with 2" tube.
   / What else do you do with forks besides lift pallets? #88
Just a Big Pallet
   / What else do you do with forks besides lift pallets? #90
I raised a neighbors shed with mine. He had hauled in dirt and that put the shed below grade. We lifted it straight up and put solid 4" blocks under it and set it back down.
2009 Jeep Grand Cherokee 4WD SUV (A59231)
2009 Jeep Grand...
2003 Big Tex 10PI...
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
Hyster 60 6,000lb Diesel Forklift (A59228)
Hyster 60 6,000lb...
2007 Peterbilt 379 T/A Day Cab Truck Tractor (A60460)
2007 Peterbilt 379...
