What else do you do with forks besides lift pallets?
/ What else do you do with forks besides lift pallets? #61
And for something completely different, a box blade on the forks.
Pictures from 10 years ago. A 4' cat0 box blade bolted through existing holes in the forks.
Spreading a pile of loose dirt/grass.
Turned it around with the rippers down, loader in float.
I'm the OP on this and here's how it turned out. I finally got a set of forks. They are rated at 3500 lbs and while a bit much for the JD 790, will fit fine on my 90 HP Deere 5520. This thread convinced me of all the uses and , frankly I should have bought them last year. I dawdled around looking at light duty forks that would work on the smaller Deere 790 but be lacking when it came time to pick up the ton pallets of fertilizer and jostle them around. Those sold in the $425 range and looked light.
The forks I got came from an Amish shop in Ohio that builds really nice stuff. I bought my loader to skid steer adaptor from them for $750 and it's built like a tank. They make three sets of forks; light, medium and super. The light ones were too light and the big one too big but the mediums were just right. Cost was $685 and they are rugged with beautiful welds. Anyway, here they are.
EDIT--It's somewhat ironic but the first task I have for these forks is to lift some pallets.
/ What else do you do with forks besides lift pallets? #63
I have that same model Blazer! mine has 250k+ mi on it, & is pretty worn out.
This might be of limited use to the lighter rigs, but I made my extended forks for things like this, where you need the reach. A board across the front where the doors are open and one across the back with some padding lifted the body off without a bit of damage, as if it really mattered.
Thought of this when reading the pickup canopy thread, as I used this technique to load one of the older wooden framed ones that was too heavy to manhandle around.
/ What else do you do with forks besides lift pallets? #64
Gooder-un :thumbsup:
Now we need to know "What else do you do with forks besides lift pallets?"
Moving some rocks for the wife. Big uns that she seems to think can be placed within 1/4" of her command at 1000 lbs and up. Then moved a few more times back and forth like furniture. A tractor bucket wouldn't do that, and neither will the forks but that's first on the list. But before that, some pallets of fertilizer are on the way and then there are some trees that need to be cut down and moved. Forks really are the easy way. Then I have to plant some ball and burlapped trees and the forks are just the ticket for easy entry into the hole in the ground.
After that, it's open season so I'll be looking for ideas since I now have the solution. :)
/ What else do you do with forks besides lift pallets? #66
. The forks I got came from an Amish shop in Ohio that builds really nice stuff.
Last time I looked Amish do not have electricity, but the Mennonite's do. The Mennonite's maker some great stuff.
/ What else do you do with forks besides lift pallets? #67
Worked great for lifting a 8x14' cargo bed from an M923 5 Ton 6x6. I'm working with a buddy to shorten it. For his M931 tractor
Yeah, well look harder. These are old order Amish but hire others to do the welding. I was surprised too but they can do whatever the local Bishop says they can do. An old order Amish guy I know has a cell phone while my Mennonite neighbor does not have a television. It all what the Bishop says.
The old order guy that loaded my forks used a gas powered skid steer but was carrying a two way radio and wearing a western cowboy hat. I felt like I was in the Amish twilight zone.
/ What else do you do with forks besides lift pallets? #69
Local Amish shop I use has a 200 Hp engine in the back powering the hydraulic system to run their mills, their air compressor, and a generator to provide electricity for their welders and even high bay flourescent lights they installed a few years ago. they used to have a diesel engine but a few years back they changed to a natural gas powered unit.
I know of an Amish woodworking shop that powers big saws and planers and such with belts that run through holes in the floor to a bigger set of belt gearing in the basement that is powered by a generator. All that yet 12 volt lights upstairs.
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
2011 Deere 50D (A60462)
2011 Deere 50D...
Rooster Weathervane (A55853)
Rooster...
(APPROX. 20) 4' X...
We do NOT accept credit cards as payment. (A60462)
We do NOT accept...
14in Digging Tooth Bucket Excavator Attachment (A60352)
14in Digging Tooth...
