FEL for snow removal
/ FEL for snow removal #1
BubbaBillyBob
Rockbridge, MO
Mahindra 5545 4wd
All--
Newbie question: Is an FEL appropriate for snow (1 foot or less) removal over a dirt/rock road?
Thanks.
--Bill
/ FEL for snow removal #4
All--
Thanks.
--Bill
Yeah, as VulcanCowboy said. Works, but there's easier out there.
In order of cost (assuming FEL is already included on tractor):
FEL
Edge Tamers - Edge Tamer | R2 Manufacturing
Rear Scrape Blade
Box Blade
Front Scrape Blade
Rear Snow Blower
Front Snow Blower
This was NOT ordered by ease, some of that will be left to your discretion.
-Nelson
/ FEL for snow removal #5
Depends on your location and size of cleared area. Pushing snow makes banks which makes subsequent drifting back in worse .
A snowblower gets rid of the snow.
/ FEL for snow removal #6
I've used my 7' wide bucket once. I was not impressed. My atv with 6' blade does a better job.
/ FEL for snow removal #7
1. Blower
2. Front blade
3.FEL
4.Back blade
For number of years I attach 7.5 push blade to FEL done good job,just make sure you push snow banks back.
/ FEL for snow removal #8
Mostly it depends on location and annual snow events.
Where there is a lot of events you really want to get rid of it.
AKA snow blower, otherwise you get a drive that gets narrower as events add up.
Also the higher the berms the deeper the drifts get.
A plow is faster but a blower is done and over with.
Best of all worlds is plow up front for minor events and blower for the serous dumpings.
Must add with a gravel road you will want to create a frozen base B4 scraping or blowing otherwise you will be raking gravel every spring.
I like to drive and compact a nice base B4 scraping or blowing.
/ FEL for snow removal #9
I've done my drive and landing (about 200' worth) and all gravel with a fel and rear scraper blade. I added sides to the bucket and cut the time dramatically. Long drives would be better served with a plow and what my rear blade acts like. I have done a 1/2 mile drive once for a 15" dump with the rear scraper . It was a pain. For a deeper dump, one is better served with the fel first and to clean up with the rear blade.
/ FEL for snow removal #10
FEL
Rear Scrape Blade
Box Blade
Front Scrape Blade
Rear Snow Blower
Front Snow Blower
-Nelson
Thanks Spoon for posting this list I'm going to grab some of those Edge Tamers. I have a gravel driveway, and need to keep a good size path open to get hay to the barn over the winter. It always amazes me the wealth of knowledge in these threads (mind explosion)
All--
My 80 acres is in the Ozarks in SW Missouri. We get snow, but not great amounts. However, my "driveway" (logging road leading to the property) is a little over a mile and a half long through the forest. I have never seen it with snow, yet. (We've only owned it for about a year.)
Thank you for the recommendations!
--Bill
/ FEL for snow removal #12
Yes it will work and make you a better operator! I have aprox 1/4 mile drive and use FEL and a back blade on the long part of drive I plow then at the end I clean it up with the Front end loader and can pile it up ridiculously high I do agree with every one else get a base or you'll be raking gravel also I bought a piece of conduit pipe cut a 3/4 inch slot in it and put on my rear blade to help not dig into gravel and sod wires real well then after you get a base you can take it off if you desire so for long parts of a drive or road a rear blade or one that attaches to FEL would work also ok hope this helps is a blast just wish my tractor had a cab in winter some day!
/ FEL for snow removal #13
It depends on the snow.
I have a 7.5' SSQA plow on my loader. Works good for up to a foot, maybe foot & a half of snow, occasionally a bit more of light snow here in Colorado. However 10" of heavy wet snow will stop me dead & require the blower.
Personally ive never used my bucket. Got a 3pt back blade with the tractor & ended up building my SSQA plow pretty quickly (then sold the 3pt plow). If you are doing much clearing, especially of roads or driveways, a plow is an order of magnitude faster than a bucket. The snow just curls to the side rather than filling the bucket & needing to be dumped every few feet.
/ FEL for snow removal #14
I use a rear blade to clear snow. Drop it to the ground then raise it up about 1 inch. Angle it to the right and I'm done in no time. And I've got about 1300 feet of gravel and hills.
/ FEL for snow removal #15
FEL works for deep snows, but a rear blade is much better for about 6" and less. Rear blades are really cheap and light weight, e.g. easy to get on.
Ralph
/ FEL for snow removal #17
The problem with using a loader bucket to remove snow on a gravel / dirt road isn't the snow, it's the wear on the cutting edge of the bucket and most are welded on so replacement isn't that easy.
If it snows, I stay home, I'm retired.
Anyone want to buy a Lucknow rear mount 72" 2 stage blower? I don't use it anymore, no need to.
/ FEL for snow removal #18
Push and Pull
FEL with snow edge attached (no scraping on the driveway) and a back blade on the back with a poly urethane blade (instead of the steal so no scratching the driveway).
All done :)
/ FEL for snow removal #19
Don't want to buy it, but if your blower has the older hydraulic chute rotation with the cable and half moon setup I could really use a picture of it. I have the Lucknow kit, but I am not certain of the correct position of the tab that gets welded to the half moon shaft. If it's the same as mine, you will understand my goofy terminology :)
/ FEL for snow removal #20
I sure do and it has the hydraulic chute rotator. I'll have to go look at it and report back...
In deep wet snow, the blower uses every bit of my M9000
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
