Hustler Fastrack SD 48" deck question
/ Hustler Fastrack SD 48" deck question #1
MemphisDan
Memphis, Tennessee
Hustler Fastrack SD
Sorry if I'm posting this in the wrong section. I just bought a Hustler Fastrack SD 48, and I just noticed this chain, attached to the deck. I was wondering if the chain, (in the picture) is suppose to be attached like this?. Can anyone explain what is the purpose of the chain?
/ Hustler Fastrack SD 48" deck question #2
Yes its supposed to be like that.
The chain is there for adjusting the mower belt spring tension
/ Hustler Fastrack SD 48" deck question #3
And if you want it to look better, just zip-tie the excess to itself so it's off the deck and not rattling around.
/ Hustler Fastrack SD 48" deck question #4
I had the same thing and this is the mod I did, just used a spring from an old cott that I took apart.
All I wanted was to stop the paint not be worn out by the chain.
/ Hustler Fastrack SD 48" deck question #5
I'd thought of using heat shrink tubing to cover the excess chain. But it still would have rubbed on the deck. Your method is a great solution.
/ Hustler Fastrack SD 48" deck question #6
I wish there was a link to show you all the Modification to the unit that I have done.
/ Hustler Fastrack SD 48" deck question #7
Do it here. I would like to see. :thumbsup:
