Subsoiler build
/ Subsoiler build
Thanks!
You mean like this?
It's hosted on Photobucket and embedded as HTML code instead of uploaded to TBN's server. I have this build on 3 sites, so it's a lot easier to just cut and paste the whole works over instead of uploading all the pics to the different servers 3 times each.
Sure is windy out there to be painting, but I don't have room for this thing inside.
/ Subsoiler build #22
OK, thanks! Makes it a lot easier and fun to follow a build thread with those large embedded pictures.
Finally got some weather where a guy can paint outside, right?
/ Subsoiler build
Yep, I don't like the way TBN's hosting works either. It's not as smooth as just reading and looking and reading when you have to click on the pics and then scroll through them to figure out which is which. The down side is that if I ever have a problem with photobucket this thread becomes worthless.
Being able to open the doors out in the shop is great. Being able to go up North and play in the woods is even better. I have my taxes, a customer's machine to finish, and a doc appt Wed, then I'm outta here! :D
/ Subsoiler build #24
I agree on viewing a thread with the large embedded pictures. :thumbsup:
The problem with offsite photo hosting is at some point in the future the pictures can be unavailable.
Here is his picture posted full size from my computer using this procedure: http://www.tractorbynet.com/forums/photos/107314-photo-posting-how-3.html?highlight=#post3967120
/ Subsoiler build
Got it put together yesterday, but I've been working on the power SSQA upgrade and parked is as far as the subsoiler got.
/ Subsoiler build
Put the SS to work Saturday.
First cut (hard to drive straight looking behind you)
Found some rocks
Lots of roots
Several stumps
Which eventually bent my cutting point
But that didn't seem to slow it down all that much. Then I tried tugging an oak stump that wasn't ground down, and wasn't all that rotten, and it broke the blade at the lower bolt hole. After that it didn't dive well at all, so I gave up trying.
I managed to bend my hydraulic top link cylinder eye during the pulling, so I'll need to fix that and as such, I left the SS up North this week. I'm probably going to get a ripper tooth for a excavator bucket to replace the cheap cutting edge. I had a feeling that one needed more support, more mass, or both.
And some action footage in 3rd gear:
I could've gone faster but I was on trails barely wide enough for the rear tires, so piloting the machine dictated the ground speed. :)
/ Subsoiler build #28
A few tweaks and you've got another nice addition to the family. Looks great!
/ Subsoiler build
Thanks!
I'm going to see if Zeigler has any used excavator teeth I can grab, and if not I've got a good bit of 1/2" AR400 drops from cutting out IPSC targets that I can use to fab up a new one.
/ Subsoiler build #30
Excellent work.
/ Subsoiler build #32
Very nice build, will be following ur builds. Keep em comin
/ Subsoiler build
Stopped by the local Cat dealer hoping to do some dumpster diving, and instead was given these after I explained what'd happened and what I was looking for to fix it. :D
/ Subsoiler build #35
You would be shocked how much those things cost new. $200 to $300 each is a wild guess, maybe more.
/ Subsoiler build
SD, I'm sure they're north of $100, but even a whole ripper shank for a D5 is only $300 (which I thought was remarkably reasonable considering it's only $2/lb). I was offered more points, but I wasn't there to take advantage of them - I really only wanted a peek in their scrap dumpster to see if there was one I could weld up. :laughing: I didn't even get dirty. :D
Jacain, first, thanks! As to spray: I have in the past but it's been several years for my personal stuff. Getting up into globular is as hot as I run most of the time. I've done pulsed spray at a job briefly, but not enough to be any kind of expert on it.
I still have my 98/2 bottle, but it's stuffed in a corner behind a bunch of brake rotors I've been holding onto for target stand bases (I should clean those out and put them in a ballast box). One of these days I'll mess around with the pulser on my MIG and work on that. I've always been more of a "I know I can make a good weld with short arc, so I'm using that" kind of guy. Getting fancy isn't as important as a good job that'll hold up to me.
/ Subsoiler build
Got the shank home and modified. Ready to go back up and get back to work. :)
1964 Ford 4000 Industrial Tractor (A61166)
1964 Ford 4000...
1653 (A62130)
1653 (A62130)
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
2007 TRAILMOBILE 53X102 T/A DRY VAN TRAILER (A59909)
2007 TRAILMOBILE...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
2025 Kivel 42in Forks and Frame Skid Steer Attachment (A61567)
2025 Kivel 42in...
