Building a Car Port
/ Building a Car Port #21
One thing to think about in the future. Someday you may want to enclose it. If it is only 20' deep, a full sized pick-up will just barely fit in it with the door closed.
That's an excellent point! My '93 Suburban squeezes into my 20' deep garage and I have maybe 3" at the front bumper and the trailer hitch ball is at the door.
/ Building a Car Port #22
...and if I went three feet further than that I could add a third bay for my tractor... :D
If you're seriously considering adding a third bay for a tractor, check your height requirements. With the ROPs up, my
tractor height is close to 96" and just clears my carport that I built.
If you're seriously considering adding a third bay for a tractor, check your height requirements. With the ROPs up, my tractor height is close to 96" and just clears my carport that I built.
I have vacation tomorrow and will line all three vehicles up where they would be then take some final sizing measurements. Got my bonus today and it's ready for the lumberyard. :D
Sent from my iPhone 2.0 using TractorByNet
Waiting for something outside your control is usually the most aggravating part of a project. Still waiting for a utility marking company to come out and mark underground power and telephone lines. Just my luck I'd hit one if they weren't marked beforehand. They keep asking for more time and I'm about ready to say no the next time they ask for an extension.
We opted to go 24' wide, provided we don't have a post over a utility line, after setting the two vehicles side by side. If our posts are layed out over a line then we will need to make some length/width adjustments again, which is why I have not ordered the trusses yet.
Finally had the area utilities marked and laid out the post holes. Started digging them Saturday but it was too cold and windy to finish them. Will try to get them finished tonight so the inspector can visit Wednesday. Trusses on order with a four week delivery but that gives me time to get the lower end of the framing completed while waiting.
Anyone have suggestions on how best to put a 16' six by six post in a 12" hole three feet deep? Seems highly unlikely that I can safely and simply set one end at the hole and lift the other end until it falls in. There must be some interesting tricks out there that folks have used which would be cheaper than renting a crane. :D
Thank you
/ Building a Car Port #26
I recommend rock, not dirt. Post lasts a lot longer because it stays dry. Also, you don't need concrete at all because the rock doesn't frost heave like soil.
I've heard people say to use rock because it helps keep it dry but in reality it seem like a place for water to collect. That's why people use gravel around french drains to collect water from surrounding soil. But in this case there is no place to drain.
/ Building a Car Port #27
Thank you
Well I put up my last tower with my tractor and bucket put a piece of carpet on the bucket and laid the tower on top of it and strapped it loosley around the bucket and drove foreward until it was standing up maybe you could do this and have someone guide it in the hole while you drive??
/ Building a Car Port #28
Drop a four foot 2x4, 1x6 etc. into the hole for the bottom of the pole to slide down, so it doesn't scrape a huge pile of dirt from the side into the hole bottom.
Get several friends to lift the end and walk it in.
Bruce
/ Building a Car Port #29
Bruce
That's pretty clever using a board to protect the far side of the hole. I'll have to try that!!!
I dig out the side under the post a little to create a ramp, and then if I'm strong enough, walk them in. The last two 16 footers I did by myself where a little wet and pretty much maxed my strength out. When I did the 20 footers for my zip line, dug out the edge of the hole so the end of the post slid into it a bit, then got behind it with my loader bucket and lifted them while moving forward slowly. That worked pretty good.
I also agree with not putting rock in the hole. That just creates a place for more water to enter the hole, and take longer to drain through the undisturbed soil. Either pack the hole tight with the dirt that came out of there and build up a mound for water to drain away, or use concrete and create a mound. Every post I ever replaced or saw that was rotted out was right at the surface where water collected next to the post. If you can get water to drain away from it, and stay away, the post will last forever. With a covered building, this is easier since the post shouldn't get any water on it anyway.
/ Building a Car Port #30
I put them in by hand and walk them up. The board is a good idea.
/ Building a Car Port #31
Thank you
If you have the equipment this is how I put in my post. (6x6 and 6x8 18')
In this forum I have a thread called "Raising a barn" you might find the pictures helpful for your project.
/ Building a Car Port #33
And that's what happens if you don't make vertical holes.
Bruce
True and then I found this weird object in my garage. A level, and woolaw. I could have used a 3 point post hole digger but this bobcat drills a much straighter hole. And my neighbor was happy to do it.:thumbsup:
All elevations were done with a water level.
There was a lot of work between drilling holes and the end. Still not quite there but close.
jlgurr, I wish you the best it will be worth it. Even if you have a neighbor/friend/relative with the ability to lift the posts up with a bigger tractor, it sure makes setting them in place easy.:thumbsup:
/ Building a Car Port #34
True and then I found this weird object in my garage. A level, and woolaw. I could have used a 3 point post hole digger but this bobcat drills a much straighter hole. And my neighbor was happy to do it.:thumbsup: <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464643"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464641"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464642"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464639"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464640"/> All elevations were done with a water level. There was a lot of work between drilling holes and the end. Still not quite there but close. jlgurr, I wish you the best it will be worth it. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464646"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464644"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=464645"/>
Beautiful! Well done!!!
... Either pack the hole tight with the dirt that came out of there and build up a mound for water to drain away, or use concrete and create a mound. ....
Eddie,
Is this why some folks use those tubes in their holes so that the concrete surface can be poured higher than the ground surface? I haven't quite figured out if I should be using the tubes or not.
Thanks,
Jeff
Has anyone ever used an auger to drill a post hole then find out you were off on your location by less than the diameter of the auger? :mur:Am I doomed to using handheld PHD to "move" hole center or are there tricks to re-drilling off center from the original drill point?
/ Building a Car Port #37
That's what 24 inch diameter augers are for. :)
Bruce
/ Building a Car Port #38
Does the post have to be centered in the hole?
Using 6" x 6" posts in a hole that is currently 12" diameter. Not much room for sideways movement since at least one of the holes is off by 6" (I know, it's my fault. Should have measured twice before digging.)
I also think the inspector jinxed me when he informed me he was a stickler on posts being centered in the concrete in the hole. LOL!
Bruce
Good point! When I add one of these to my stable (rather than borrowing) I'll be sure to remember that. :D Was thinking of drilling right next to the current hole, break out the wall between them and using a 12" concrete tube form and backfilling with dirt around the form.
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2008 Toyota Camry Sedan (A64557)
2008 Toyota Camry...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
John Deere 772-A Grader (A62679)
John Deere 772-A...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
